Question about Sharp AL 1631 Copier
SHARP AL 1644
My photocopier roller got burse and i replace it but i need the error code to clear the 2 and h that appear on it.
    President:
  • Sharp Master
  • 1,447 Answers
I want free solve side
Posted on Dec 04, 2008
  • Sazeed Computer
    Sazeed Computer Nov 22, 2009
    what is code? please send me ,I shall help you
Hello , I am told that I need a new ‘power board ‘ for my sharp al-1644 copier after a surge after a power cut? I am getting an H4 fault . Can you help with this , Thanks Terry
H4 indicates a fuser (the rollers near the exit that are hot) error. The power supply could be the cause but its doubtful. Try pressing #,*,C,*,1,4,1,enter(or copy button) to reset it. Good luck !
Mar 03, 2017 | Sharp Office Equipment & Supplies
Solution for system error [H4-00] on sharp photocopier machine
Replace the Heat Roller and Enter into Sim mode to clear the Error Code.
Jul 01, 2014 | Sharp AR-M160 Laser Printer
I have a Sharp Al 1566 Photocopier,Printer,Scanner and it has encountered a problem which is SYSTEM ERROR (H4-00) so how can I fix the problem?
H4-00 = Low heat roller temperature detection. This is usually caused by either a blown heat lamp or a blown thermal fuse.
Sometimes the error can show up for no particular reason. Try resetting using the following sequence:
#,*,C,* (hash, star, clear, star) then enter '14' and then press the start button.
The machine will reboot. If the code comes back you'll need to check the lamp and fuse for continuity (having removed the fuser from the machine first!)
Hope this helps.
Feb 02, 2011 | Sharp AL-1655CS Copier
Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
Jan 12, 2011 | Sharp AL-1641CS Laser Digital Copier
Reset drum counter on Sharp AL-1644
This works on MOST sharp AL series copiers.
Press these keys in sequence:
Clear → Density select → Clear→ Density select
display should go blank. Then enter:
24 as if you were making 24 copies then press print
then enter 7 as if you were making 7 copies then press print
if successful you should see flashing 000
turn machine off then on again and the drum light should be gone.
Good Luck
Nov 03, 2009 | Sharp Office Equipment & Supplies
SHARP AL-1644
To enter the serviceman simulation mode, press the keys as follows:
To cancel the simulation mode, press the clear key. Then enter code 14 then hit start.
Jul 28, 2009 | Sharp AL 1631 Copier
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp al-1644
H4 is a fuser roller heating issuse. The temperature isn't hot enough. May need new fuser roller assambly or a thermistor.
Jun 03, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp al-1644 photocopier
Usually CH indicates that one of the doors on the copier is not closed properly, if it is a flashing CH then there is no toner cartridge in the copier or the cartridge is of the wrong type for this machine. A lot of toners for this machine look alike but are not the same for the machine.
May 26, 2008 | Office Equipment & Supplies
AL-1000 Sharp Photocopier
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 11, 2008 | Sharp AL-1000 Laser Printer
Sharp AL 1631 Copier Logo
77 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
