Question about Meade LX200GPS Telescope
Problem with lx200gps meade telescope
I am facing a problem with my lx200 14inch meade telescope. While doing the alignment the telescope is detecting the home position and true north. but after that it is not doing the mount tilt and gps fixing. the telescope rotates till the motor stops.....what is fault with the telescope ....please give a suggestion.
It might be a voltage or electrical current problem. Make sure your DC power supply is between 12 and 14 volts. Make sure all electrical connections are tight. Where the power cord plugs into the connection panel, make sure the center pin on the panel fits tightly into the plug. It is a Radio Shack type "N" plug. If tou still have a problem, remove the bottom plate from the scope base and make sure all the connectors are properly seated on the circuit board. Check the connector on the end where the black and red wires are. That is a main power connector and if it is too loose it will not conduct enough current. There can be enough voltage drop that the drive motors won't operate, or they will and the scope will slew uncontrollaby. Be careful handling the wires so that you don't damage them. Good luck, Dave
Posted on Sep 26, 2008
How or can I fix my meade lx 200 gps that is not sensing the home poisiton. It also rotates past the point wheree there should be a stop.
This can be caused by:
a bad hand controller cable (buy a new one)
a blown circuit board (only Meade can repair)
Improper setup-- read the manual and do all the setup, and initial alignment.
Nov 15, 2010 | Meade LX200GPS Telescope
My telescope does not pick up gps signals i get a message on the hand controller saying the sensors can not detect home postion. how much wouuld this cost to repair
Could just be a DEAD battery-- check the manual and replace the battery. If this does not work then it may need to be sent back to Meade for repair:
Here:
http://www.meade.com/support/index.html
Nov 08, 2010 | Meade LX200GPS Telescope
My meade LX200GPS can't track the stars? wheater the bad weather of observation points will affect the accuracy of automatic alignment? how can I improve the tracking
You must Calibrate motors using the same power source as you use at night outside, then do a TRAIN drives. Some of these scopes also have a Calibrate Sensors -- and some do not.
Then do a two star alignment and center both alignment stars. Daylight Savings Time = Yes right now in the USA, check that it is set to YES.
Oct 13, 2010 | Meade LX200GPS Telescope
My LX200GPS fork is blocked and cannot rotate manualy while the RA lock is loose. Could anyone help please?
This is a major project. You will either need to return it to Meade for repairs, or be ready to almost completely disassemble the telescope to get to the motors.
Contact Meade first:
Oct 02, 2010 | Meade LX200GPS Telescope
Meade LX200GPS The scope does not complete the 'Auto Alignment'
Once the scope has taken a GPS fix and knows TIME, and SITE, and you do a two star alignment your alignment stars overide any automatic alignment issues.
You could turn off the GPS put in Time, Date, and Site, do a two star alignment and everything would be fine. Centering the alignment stars is the "trick". Apparently the scope also finds NORTH OK, or the alignment stars would be way off. Since you pre-level the tripod already the software can FAIL on "tilt" and you still get good gotos.
I would not worry about it, especially since your gotos seem perfectly fine.
May 28, 2010 | Meade LX200GPS Telescope
Gear needs to be replace in the DEC. drive LX200GPS 10"Where can I find the gears?
Maybe Meade will sell you the part?? Usually they want you to send back the telescope.
Call them at this phone number:
Aug 16, 2009 | Meade LX200GPS Telescope
I've made every possible alignment on my 10 inch Meade LX200GPS telescope, training,set-up, calibration, etc...but when I slew to a star....it is ALWAYS very far off in Dec....though RA seems to be well...
You might want to join the following Yahoo group:
http://tech.groups.yahoo.com/group/LX200GPS/
I am not familiar with the LX200, but there are probably folks on the Yahoo group that can help.  The only thing I can think of is if you are using a wedge and the wedge isn't at the correct angle (should match your lattitude).  Or you are not using a wedge and the Meade controller thinks that you are.  But one would think the calibration would solve that.
Apr 26, 2009 | Meade LX200GPS Telescope
Azimuth motor stalling missing the electronic home sensor
Check for binding in the gears; my 10" had aluminium chips in the fork base that jammed the gear. Cured by removing the RA manual adjust assembly - was useless anyway, as it could only be used with the RA unlocked. One setscrew in the fork base holds it in place,just loosen and pull up.
Apr 16, 2009 | Meade LX200GPS Telescope
Meade LX200GPS Telescope Logo
391 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Geoff
Rich Lewis
Are you a Meade Optic Expert? Answer questions, earn points and help others
