Question about Lexmark X2500 All-In-One Printer
Printer not working at all
I noticed the other day that my printer was not powered on. I tried to turn it on, unplugged and replugged all connectors, checked the power supply on the surge protector and reinstalled the software all to no avail. Is there anything else I can do or can I buy a new power cord?
  • 48 Answers
Remove the surge protector, plug your printer direct to the wall outlet and try to power on again. try to apply a bit more pressure on the power button or try holding in down for 5 seconds, temporarily unplug the computer connection too.... if it still will not power on, try a different power cord.... if it still will not turn on with a new power cable, then check your warranty status with lexmark, this one needs to be replaced or repaired
Posted on Sep 04, 2008
My printer will not turn on it worked yesterday and i've done nothing different. could it be the "brick"?
Try to unplug the power adapter from the printer.
Check if it's warm or cold. It could be a defective power adapter issue. Unplug and replug the power cord into the power outlet to reset it. Bypass any surge devices or power strips. Replug the power adapter into the printer. The printer should automatically turn on, otherwise press Power button.
If problem continues, then it could be a faulty power adapter problem. I'd suggest you to contact Lexmark technical support for additional assistance.
May 17, 2011 | Lexmark X2500 All-In-One Printer
Good morning, i was printing and the printer shut
Try to unplug the power adapter from the printer. Unplug the power cord from the power outlet in the wall. Replug the power cord after at least 10 seconds - bypass any power surge devices or power strips. Replug the power adapter into the printer. Your printer should automatically power on, otherwise, press the power button. If the printer still won't power on, please contact Lexmark technical support for additional assistance.
May 12, 2011 | Lexmark X5470 All-In-One InkJet Printer
Our canon MP560 printer will not turn on - it was plugged into a surge protector and we have tried moving the plug to alternate outlets just to make sure that wasn't the problem...help!
This is what worked for me. I had a similar setup and could not get the printer to turn on. Remove the power supply from the back of the machine. It is a very simple process: pull apart two small plastic connectors with your fingers to remove power supply. Disconnect internal blue cable from power supply.
Replug blue cable and be sure it is plugged in tight.
Push power supply back into place, be careful of blue cable when pushing it back into printer.
Plug in and printer just may work...good luck!
Jun 28, 2010 | Canon MP560 All-In-One InkJet Printer
Will not turn on after unplugging from wall
At what situation it has gone....may be power supply problem it has gone......first check power cable and power point supply ....still its not work call any printer service engineer
Mar 28, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I turned off d7360 printer. Next day it refused to
unplugged printer and discounected the usb cable from computer. Waited 2 minutes and replugged. Turned on PC and the printer responded. Thank you for the info.
Jan 20, 2010 | HP Photosmart D7160 InkJet Printer
Service Error 5100 Prints part of page then stops. Tried the suggested solution by Canon at the time of service error notice (turn printer off then back on, unplug from power source then replug, etc.) to...
5100 is a carriage error, usually caused by grease on the clear encoder strip behind the carriage assembly. You can clean the strip with a damp Q-tip just damp with plain water.
Nov 25, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Grinding noise in cartridge for hp laserjet 1200 series printer. I replced cartridge and still hear noise sometime worse and then not so loud.
I have the same problem and I know what is causing my problem. It's not in the cartridge. You're laser scanner is going to go bad. I had the problem 3 months ago. I would only make the grinding noise when it powered up. Printing was okay. I don't use the printer that much. Then about a week ago I notice only the bottom diagnostic light was on. I unplug the power and powered it back up. The grinding noise got louder and wouldn't stop. I unplugged the printer an replugged. Same thing.
I was bored (christmas day) and decided to open my printer to see what the root cause problem was. I removed several screws and once I got all the printer naked (removed all the plastic outside). I plugged it in an tried to listen where the problem was. I notice a vibration at the laser scanner (top black piece). I unplugged the printer. I unplugged the power source to the laser scanner. Replugged the power and saw all the gears move with no noise. Powered off. Replugged laser scanner. Powered on. Noise back. Defective laser scanner. The laser scanner has a ribbon cable, and four purple wires going to it, oh yeah there is a big yellow warning label, so you can't miss it. I hope this helps.
Nov 26, 2008 | HP LaserJet 1200 Printer
HP 7410 - No display and orange exclamation point is lit
Unplug your power supply and leave it off for like ten minutes, then replug it and see if it will initiate itself, if not it sounds like serious malfunction.
Aug 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Copy
- try doing the power cycle.
- unplug the power cord w/o turning off the unit
- wait for about 2 minutes.
- replug the power cord.
- then try to do copy again.
- if still not working, try to press set-up go to tools and clean the printheads. if still not working go to next steps.
- took all the cartirdges out.
- clean the electrical contacts of the cartridges and the carriage with a lint free cloth moisten with an alcohol.
- wait for 30 seconds
- replug the power cord and install the ink cartridges if the printer ask them to install
- try to do a copy
- is still not working
- try to do a reset
- unplug the power cord again
- then press and hold the # and 6 key while the printer is unplug
- and while holding them both replug the power cord
- then do not yet release the two buttons, wait for the printer to start up and if the screen turns off thats the time you will release the two buttons
- then follow the on screen instructions.
Aug 25, 2008 | HP Officejet 6310 All-In-One InkJet...
HP 8150N ERROR CODE 79.060E
Power off the printer. Unplug the printer's USB cable for 5 seconds replug turn on the printer. If that fails power off the PC and printer unplug the USB cable at the PC and printer replug and power back on the PC. After PC is fully booted turn the printer back on. If this keeps reoccurring please replace the USB cable and or try different USB ports.
Mar 18, 2008 | Computers & Internet
Lexmark X2500 All-In-One Printer Logo
135 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
