1. You may have old gas in the tank.
2. Fuel mixture may not be quite right. Pour out and put new in it. Otherwise you may need to clean the carburetor.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will
need to disassemble the carburetor and spray with carb.cleaner. Make
sure the small screen is free of debris.(Should be able to see daylight
through it.)
Use a Den Tek Brush, (
http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Changed spark plug, tried starter fluid
