Question about Dishwashers
AEG Favorit 50730 Sensorlogic Dishwasher:
Keeps running on continually, until we switch it off manually. Does not always dry, pots sometimes cold & wet, but washed.
  • 3 more comments
  • alistairnp Oct 21, 2008
    My AEG Favorit 50730 runs longer than it should and does not seem to move into the drying cycle leaving the items cold and wet.
  • Anonymous Mar 27, 2009
    same problem
  • Anonymous Mar 18, 2014
    dont wash
  • Anonymous Mar 22, 2014
    AEG PROCLEAN LEAVES DISHES WET
  • Anonymous Mar 23, 2014
    always washing cold
Get a new dishwasher
Posted on Nov 06, 2008
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Disconnect ignitor
It may be best just to unplug the stove. The burners can be lit by a lighter or match until the service man comes. Sometimes the igniter switches get wet from cleaning the stove and they dry out overnight and are fine. if it continues to ignite then one of the switches is stuck on usually from the shaft being stripped.
May 25, 2014 | Brown Stove Works Kitchen Ranges
During the dry cycle, it seems as if water is continuing to be added. A few times i minute, at least 5 cups of water is pumped out into the drain. This continues for the 3 hr dry cycle. When done the...
could be one of your water solonoid valves is leaking by, where hot and cold hoses hook up in back, they get energized when calling for water then shut down when fill level is reached, some valves have filter in it, both valves come apart and can be cleaned, make sure no debri is caught in valves to prevent from closing fully
Oct 18, 2013 | Washing Machines
Aeg electrolux dishwasher wont wash just keeps beeping
well there are several possibility's. What was the washer doing? Rinse or cleaning? If there is standing water in the tub, then the pump went out or is clogged.
Dec 04, 2012 | Dishwashers
My electric igniter keeps sparking
Hello, Did you clean the cooktop recently? Sometimes water or cleaner can get into the spark switch causing it to spark untill it dries out. The same if a boiling pot spills. If none of those happened one of the burner switches is bad.
Jun 07, 2011 | Maytag Cooktops
Our AEG Favorit Sensorlogic dishwasher has had no power to it
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
Mar 26, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
Mar 04, 2010 | AEG 24 in. Favorit 80860iW Built-in...
Dishwashers Logo
1,773 people viewed this question
Top Dishwashers Experts
