Question about Canon iP4500 Photo Printer
Casnon IP4500: low ink detection
How do I turn this back on if it has been turned off for an ink cartridge please?
  • Anonymous Dec 16, 2008
    correctly
  • 3 Answers
You will need a resetter. Some vendors of ink refills sells the resetter. But csot about US50.00. If in UK there are ink refill companies that will do it for you at a service cost.
Posted on Mar 29, 2009
After changing the ink of my printer, (PIXMA ip4500) I experience the following problems: 1) green and the yellow light keep flashing non stop when the printer is turn on. 2) No lights show to...
Replace the applicable ink tank with a new
one, and close the scanning unit (printer
cover).
Printing with a once-empty ink tank can
damage the printer.
To continue printing without replacing the
ink tank(s), press the Resume/Cancel
button for 5 sec. or longer to disable the
function to detect the remaining ink
amount. After the operation, it is recorded
in the printer EEPROM that the function to
detect the remaining ink amount was
disabled.
Aug 23, 2011 | Canon Pixma iP4500 InkJet Printer
I put in a new ink and my canon ip4500 came up with service error 5c20 and the orange light started flashing how can i fix it?
It has not detected the cartridges correctly or it has a waste ink problem, not sure which. Are they genuine Canon carts? I hope this helps will you let me know how you get on please?
reseat all the cartridw0zz_3.jpgges and read the attached which should work with the 4300 (thanks also to tech1569 for this)
Jan 26, 2011 | Canon Pixma iP4500 InkJet Printer
Yellow light flashing saying replace cartridge that is flashing when I replace it the yellow light is still flashing
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Install the print head and ink tanks correctly iP4500
Reseat the Print Head and ink tanks iP4500
Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Jan 17, 2011 | Canon Pixma iP4500 InkJet Printer
I only want to scan but need a new cartridge - do i have to replace cartridge before scanning is enabled.
You will need a new cartridge before you can scan.
What you could try is to remove both ink cartridges.
Turn printer off and unplug from outlet.
Wait at least 30 minutes, this will let the printer to reset
Turn your ink cartridge upside down for 2 minutes before installing.
This will let some of the ink from the bottom to reach the printhead.
Plug printer back in and turn on and install ink cartridges.
This might work if your printer only detected a low ink condition at first.
For the scanner to work, the printer must have no alarm.
Jan 14, 2011 | HP PSC 1315 All-In-One InkJet Printer
Mx328 disable check ink how to do this or disable ink low
To disable ink low detection, do this steps:
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
To disable detection of reused cartridge, do this step:
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence
Please find the complete explanation in my tips in this link
http://www.fixya.com/support/r5191523-canon_pixma_mx320_disable_ink_cartridge
May 20, 2010 | Office Equipment & Supplies
I disabled ink monitoring on my Canon IP4500, how do I set it back to factory default so that I can monitor the inks again?
It will set itself back as you install new Canon inks, but will be turned off for the remaining inks until they are used up.
Aug 28, 2009 | Canon Pixma iP4500 InkJet Printer
Even with brand new ink, my canon iP4500 won't work
A few basic causes.
1. The cartridges you bought iwere not proper HP ones and many "clone" cartridges are known to have problems with the ink level chips
Take them back and get them replaced with a different brand
2. They are original cartridges but may still be faulty (rare but possible)
3. Your print head is clogged or faulty
Run your printerthrough the head cleaning process a few times and see if it clears up.
4 your cartridges are out of alignment
run the cartridge alignment process
if this information was useful please click below
Aug 12, 2009 | Canon Pixma iP4500 InkJet Printer
Hi I Have a Canon IP4500 and have fitted new inks however error message says an ink tank error has occured.Open the printers cover and replace the ink tank on which the ink lamp is off. I Have tried...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 26, 2009 | Canon Pixma iP4500 InkJet Printer
Ink not working
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Dec 30, 2008 | Canon Pixma iP4500 InkJet Printer
Pixma IP4500 Ink Tank Reset
GET ON TO YOUR GOV' REP AND KICK UP A STINK.
PEOPLE POWER. HEARD OF IT . DON'T EVER FORGET IT .
PETER
Apr 12, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon iP4500 Photo Printer Logo
256 people viewed this question
old marine
old marine
