Question about RCA F36668 36" TV
Color is all red - picture hard to see
The TV powers on but the screen is completely red and it is hard to see anything. Adjusting the settings in the Menu does not help any.
Not sure if it needs a new picture tube or something else.
Bought a new TV since it wasn't worth it to fix the old one.
Posted on Aug 31, 2008
Tv come on but cant clear the picture from turning red and black how can I get a clear picture?
Without knowing anything about your Tv make or model this is hard; but there should be a reset button in your menues to restore all settings to factory default. Find and use that. However I am suspicious and think the set needs reapir.
Jan 02, 2015 | Televison & Video
Red tint on screen
u shoud reset your setting try to on
Jul 27, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
I have a phillips rear projection tv model no 55PP8620/79. Its showing a a red haze and poor picture quality. How do I fix this?
If the red haze is not convergence---that requires parts.
The set has three picture tubes---with set unplugged and back cover removed clean the three large lens that are topside---as for the red haze a quick way to know what is wrong is with set on turn the color to zero----what color is the screen? Should be black and white--if red to some degree tracking or screen controls may need adjusting inside the set---Yellow picture in that situation is a different issue.
Jun 05, 2012 | Philips Televison & Video
Zenith TV has me seeing red.
The red gun in the picture tube itself is shorted on. You will have to replace the picture tube itself to fix the problem. Probably want to just buy a new set. Sorry!
Mar 16, 2010 | Zenith B25A10Z 25" TV
Magnavox 51" 51MP392H seems not to have any reds in picture.
his is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
Also - Dull video problems...
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 12, 2009 | Philips 46PP9302 46" Rear Projection...
TV shows red
It sounds as though the color settings have been altered or that the tv is going out. Assuming this is a crt unit, you might try adjusting the color or unplugging it for a few minutes.
Good Luck,
BB
Jan 06, 2009 | Sony KV-32FS13 TV
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
There is no red in the picture
you might have it in component cables in the rear and one of them is not all the way in. sometimes these cables are a bit hard and may think that its all the way in and its not. check it out.
Apr 09, 2008 | Televison & Video
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Picture is VERY dark...
zenith have many problems with crt (picture tube) they comes be short or one or more canon fail, there are nothing to do, replace the picture tube, and thats a lot of money for an old tv...good luck ps adjusting the screen and resoldering the picture tube card could help but remember there are many dangerous circuit in a tv...
Aug 10, 2006 | Zenith C27A24T 27" TV
RCA F36668 36" TV Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
