Question about Sony Playstation 3 (PS3) Console
Ps3 40gb i have wireless internet and my ps3 keeps telling me it cant find ip address can you help me? desmondholliman@yahoo.com
  • 55 Answers
Try do let the system do the scan.
Input the network key and hope it works.
If not it may be that your wireless addapter went bad.
Did you tried maybe at one of your friend''s house to see if you can connect there?
Posted on Sep 02, 2008
Why will it not connect to the internets IP address?
If you reset the modem and ip address will not change and remains same hence it is static ip address.If you reset the modem and the ip address change ,it is dynamic ip address.
You can get the Ip address from your internet service provider.you can check the ip address using the site Ip-details.com .
Jan 25, 2013 | RCA DCW615R Wireless/Cable Modem
Recent got the wireless usb adapter for my Dell Desktop. I have run the software and the device is detecting the internet but it keeps telling me there is a problem because it is unable to renew the ip...
First, make sure that that wireless card is configured to obtain an IP address automatically, unless you are at work and they give you a static IP address. You can check the configuration by going to the properties page of the wireless adapter. You get to this page through Control Panel > Network and Internet(or something similar depending on version of windows) Right click on the wireless connection and go to properties. Right click on TCP IPV 4 and the settings should be set to auto obtain ip address.
If you are using a static IP address, then you have to manually type in the ip address in the window above.
Try the following to renew the IP address.
Turn off the cable modem, the router and your computer. After 10 seconds, plug in the cable modem, after 20 seconds, plug in the router, after 20 seconds, turn on your computer and see if this helps.
Another option to renew the ip address is the following,
Go to Start > Run and type "command" or "cmd"
Then type "ipconfig /release" once this is done type "ipconfig /renew"
If this helps thumbs up my solution!
Regards,
G33k
May 04, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
If I lock my router, will my IP address be undectectable to any website I visit?
No. But first some clarification...
If you are connected to the LinkSys through a home network your computer will be getting an IP address of either 192.x.x.x or 172.x.x.x. This IP address cannot be seen by servers on the internet. However, the one that is for your household which is provided by your ISP can always be seen. This is how the internet knows where to send the information that you request back to you.
Feb 28, 2011 | Linksys Wireless-G WRT54G Router
I keep getting Error Code 1
1) Clear your cookies and temporary internet files (AKA cache), exit from the browser, then restart the browser.
2) If you are a home user and do not pay for a static IP address, get a different dynamic IP address; do
[Start] > [Run] > cmd > ipconfig
{{write down the IP address, then disconnect from the Internet with}}
ipconfig /release
{{wait a few minutes and then reconnect with}}
ipconfig / renew
{{compare the new IP address to the old to make sure your IP address changed, then try again}}
If you are an office user, try someone else's PC which will have a different IP address.
3) Log into Yahoo through a different country's server. I.e. if you usually log into Yahoo via http://login.yahoo.com/ or http://mail.yahoo.com/ then tryhttp://login.korea.yahoo.com/ or http://nz.yahoo.com/
4). Access your Yahoo mailbox via http://wap.oa.yahoo.com/
5) Use a different browser. Use Firefox (free download from mozilla.com) if you normally use IE or Safari.
6) If you have a web accelerator (mostly an affliction of dial-up users) then try turning it off.
7) If you use a proxy server (mostly a corporate user thing) then try turning it off.
Jul 05, 2010 | Yahoo Mail
I cant connect internet through hardwire(ethernet) but i can connect to internet by wireless... and it keeps on telling me Unidentified network.
Not really ...
1 thing that should not be in common between your wireless and modem is GATEWAY...
Your default modem gateway will be 192.168.1.1
change your router gateway to 192.168.2.1 or 192.168.3.1
to do this ...
1. click on start menu , type cmd , enter
2. COMMAND PROMPT dialogue box opens .
3. type . IPCONFIG
3. note your Default gateway.
4. open internet explorer
5. type your default gateway in browser address
6. it will prompt you to give user ID and password .
7 Your USER ID and password is ADMIN .
8. your router setup page opens .
9 change your local IP address to 192.168.3.1 .
10. Check mark on BRIDGING MODE .
11. Disable and enable your ethernet .
12 . now try connecting to INTERNET .
It should work . .
May 22, 2009 | D-Link Vonage-enabled Wireless Router...
Ping www.yahoo.com - FAILED
try to check the ip address before accessing the internet.
if you not getting a valid ip address then try to reset you d link router.
Apr 13, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Acer 5000 wireless is not working
1. What is the model of the router you have? Can you check the IP address that your laptop is obtaining? Make sure that the TCP/IP setting of wireless is set to automatic.
2. Try pinging yahoo.com and see if that will give you reply.
start>run>cmd>ping yahoo.com
then press enter
3. Are there any other wireless device connected to your network?
4. Have you tried connecting your laptop in a different wireless network?
Oct 04, 2008 | Acer Aspire 5003WLMi Notebook
Belkin router and ps3
Hi Srini here ,
There could be a problem with the wireless configuration on ur belkin router.
Go ahead and type the following in the command prompt of ur computer.
ipconfig
:-This will list out the ip address and the default gateway of the computer
:-Make a note of Default Gate way.
:-Type the default gate way address in to the address bar of the internet explorer.
:-It will take u to the router configuration page.
:-it might ask u to enter router password.(Enter it)
:-In the router page u could see wireless settings options on the lefthand side of ur router confiuration page.
:-Make it appropriate accordingly
:-if u do not know what to do with wireless settings ..then send me ur product details ..will tell u further querries..
Most of the time the wireless device do not connect to router due to wrong "Wireless network key"
:Make sure you have same wireless netwrok settings in the devices as in the wireless router.
:-Send me ur product details and ur setting details like
ISP(Internet Service Provider):-
Brand Name of the modem:-
Model no. of the belkin router:-
If u would like to resolve ur problem soon then send me all details..
Apr 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless computer won't connect to internet
Somewhere in the network connections settings I recall seeing a checkbox to tell the laptop to automatically determine the IP address when connecting (as opposed to using the same one every time). Sorry I don't recall more specific directions ....
Jan 01, 2008 | Belkin (F5D7230-4) Router (587009)
Linksys router befw11s4
The easiest way to sort it is to enter your routers settings page in your internet browser or desktop icon and make sure you enable DHCP which will give your pc an automatic ip address. Make sure WEP or similair is off until the set up is sorted out. Next go to your properties of your wireless adapter(Card) and go to internet TCP/IP and click properties and make sur 'Obtain IP address automatically is ticked. No click Start, then Run then type:- ipconfig /flushdns then press enter.(note the gap between ipconfig and the /). Restart your pc and router and try connecting again
Jan 31, 2007 | Linksys (WMP54GS) 802.11g/b Wireless...
Sony Playstation 3 (PS3) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
