Question about Sony Cyber-Shot DSC-F505V Digital Camera
F505V can not auto focus red object
I tried many times to have my 505v auto focus this Red Ginger without success. As if the camera could not see red object. I finally 'have to' use manual focus. Actually I love to use manual focus. But it is strange that the auto focus coukd not see dark red object in low light. Ruchai
    Master:
  • 551 Answers
There are two main types of autofocus sytems, active and passive. Active systems use a beam (usually IR) to calculate focus and the passive systems (which is what the F505 uses) use contrast differences. Both systems have weaknesses. The Active systems have limited range and can be fooled by shooting through glass which reflect the focus assist beams. Passive systems need good vertical lines to compare and they can be fooled by bright light behind the subject. In this case, you can see the sunlight just behind the flower and that probably attracted the attention of the AF system. One thing you can do to help in a difficult situation is to hold the camera at an angle (even 90 degrees) lock the focus and then return to the correct angle. In this case, a repositioning of the photographer to eliminate the backlighting would probably work as well.
Posted on Sep 11, 2005
    Master:
  • 551 Answers
Hello Ruchai - Do you mean specifically that it will not focus on these object specifically when in DIM light, or do you mean that it will not focus easily on red objects at all? This is important, because many of the flowers in people's gardens, including my wife's garden, are red. I shoot these all the time, and I have no trouble focusing at all. Now, if you are talking about dim light, it may be that the problem is the dimness of the light more than the color of the object. Pondria has done some interesting work studying that the camera's focus system may be 'seeing' everything as a b&w or grayscale tone in order for its autofocus system to work properly. I do not know if this the truth or not. But it the red color truly is a problem, perhaps there may be a workaround. Focus the camera upon a nearby portion of the plant -- the leaves, a stem, another flower of a different color, etc. Then half-press the shutter button. Finally, reframe the shot and fully depress the shutter button. I will try this today in my garden to see my results with red flowers and autofocus. I will attempt both the regular Autofocus as well as our lauded Spot-focus technique. :) Thanks for more interesting comments.
SOURCE:
Olympys fe-270 takes blurry pictures
Try this. Aim the camera at the person/object you want to take a picture of. Press the shutter button "HALF WAY DOWN" wait 2 seconds then complete by pressing all the way down to take the picture. The auto focus works on the "half way down" stroke. Some cameras have a light that goes from red to green to let you know the focus was completed. Or, just wait the 2 or so seconds.
Dec 22, 2009 | Olympus FE-270 Digital Camera
Indoor shots are out of focus at distances of 20 feet or more
Your auto-focus mechanism needs light to see the detail. Most flash units have a pre-flash(usually red) or if your not using flash, the camera has  a kind of red flash light that turns on to provide some light. And even that only reaches out so far.  in a darkened room, try pressing the shutter button down to see if it has this "focus illuminator" (you can usually figure out where it should be on the front of the camera). if it doesn't light in a darkened room, it's probably broken, which means 1 of three things: get it fixed, focus manually, turn on some lights
Aug 29, 2009 | Fuji FinePix S1000FD Digital Camera
505V owners please help me! 505V noise?
I don't know if it's considered "normal" or not, but my F505V does the same thing. The original in the msg above was only 2 seconds -- take a look at it and see how it compares to yours.
Sep 11, 2005 | Sony Cyber-Shot DSC-F505V Digital Camera
F505v ISO
You really can't change the ISO, but you do have some control over it, by being aware of how the program AE modes affect the camera's ISO settings.
505V lattice-type background
You may sometimes see this. It is normal, when it does occur. I believe this has something to do with the fact that the F505V relies upon a diamond-shaped shutter/aperture design rather than having more leaves. This leads to other interesting effects with diamond-shaped lens flares, etc. Not ideal, but nothing to worry about, really. It won't detract from the beauty and sharpness of your images.
Dim LCD Display on F505V
I own a 505V. I tried the S70 at local store just shortly. I didn't notice that one has dimer LCD than the other.
I can't upload 505v movies to PC?
Did you go to Mssony directory and Moml0001 folder to look for the mpg file? I have a F505V and it works fine with my USB in Windows 98.
F505v AE lock
Unfortunately the 505V has no AE lock.
505v battery
If you're talking about digitalkamera.de info, I believe it's incorrect. SONY japan's web page states 1300 shots and 1 hour life for the battery and it still uses the same battery from 505k, NP-FS11. I think it's possible they have reduced the internal circuitry power consumption (in 505v) to reduce battery drain, but the battery itself seems to be identical.
Red-eye problem still existant in the F505v?
Reports thus far are very favorable with regard to a lack red-eye problems and the red-eye reduction system. Many have said thus far that they usually do not need to engage the red-eye reduction flash.
Sony Cyber-Shot DSC-F505V Digital Camera Logo
67 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
