Ups how to convert computer ups to run fan and inductive flourecent lamps?
  • tkondago Sep 08, 2008
    inductive load like Fan and flourescent tubelight with ballast is not working with comuter UPS. How to convert it to make it run fan and other inductive devices?
  • ricky8205 Feb 08, 2009
    just now my APC smart -UPS 1000VA UPS sysytem got a problem it was overheat can u help how to find the problem and what should i do to remain a good condition of my UPS.. pls help me to solve this problem.. thank you very much.. more power..
    Genius:
  • 1,198 Answers
I use my ups to run a fan, a lite, and my computer while I shut it down. An ups is only as good as it's battery. The larger the ups and it's battery, the more watts you can use. The battery will determine how many watthours you get. Some people will put a car battery to an ups. The ups may overcharge the battery and dry it out. The battery may be too much for the ups charging circuit and burn it out, dead ups. I put a 12 volt computer fan on my ups to keep it from overheating, another problem that comes up when you overuse an ups. Where I am, you have to deal with a power company that is not reliable, so I go the extra mile to get more comfort when the power is out.
Posted on Sep 08, 2008
Carrier troubleshooting furnace
If the thermostat isn't selected for "FAN" then the relay is stuck. In heat mode the thermostat opens the gas valve and starts the igniter and the induction motor. If the induction fan isn't running, the flame will stop.
Jan 28, 2014 | Office Equipment & Supplies
Lamp turns on lamp light starts blinking then turns off
Check the lamp ballast, it works just like a flourecent light if the ballast is bad it will turn the light off. It comes on a board try searchinng ......ebay or thetvdoctor.comXHRWN5
Feb 23, 2012 | JVC HD-56FB97 HDTV
My Tn111 timer is running hot with just a fan running
TN111 timer should not be hot.
All electrical devices generate heat, but the clock motor inside TN series is around 3Watts, and should put off same heat as 3 watt light bulb.
This timer is rated for inductive loads like a fan, up to 1/3 HP (horsepower). Some timers are incandescent only and are not rated for fans or HP loads.
1) Try plugging timer into different outlet and to different Load (light, fan)
2) Test outlet with cheap circuit analyzer from home center to make sure outlet is wired correctly.
3) This line of timers has limited 1 year warranty
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
Jul 24, 2011 | Intermatic TN111C Standard Lamp &...
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
Acer aspire 1640
start up the computer and while its running, hold a flash light to the screen. If you can see any graphics on the screen, your lcd converter burned out. If you can seen nothing, its possible that the back light lamp burned out and the best option would be to replace the screen altogether
Jun 27, 2010 | Acer Aspire 1640Z Notebook
Canon pc720 makes "crackly" sound, randomly shuts off mid-print, and displays error code E240
Your scan lamp is going bad. It is the flourecent type lamp that lights up under the glass. You can try making a copy with the top cover open and watch it. You will see it flickering before the code comes up.
$75 from precisionroller.com Part#L5180 or the canon # FH7-3272-000
May 01, 2010 | Canon ImageClass D861 Printer
Sir, I have the error message E803 in IR400 How can i solve this problem
hai,
its a low voltage proplem, check power outlet (110/220)
OR replace the low voltage power supply board.
best of luck
Apr 23, 2010 | Canon imageRUNNER 400S Copier
Fluorescent dimmir
The dimmer you purchase needs to be compatable with the ballasts of the C.F. light. A compact flourescent potlight has a ballast, if your replacing incandescent bulbs with compact flourecent lamps
you still need a flourescent dimmer. Remember a ballast is like a transformer! If you compact flourecent fixture has a ballast by Lutron. then you need a lutron dimmer as there ballasts are not officially compatable with other dimmers, allthough I've seen them work. My advise is buy Pass & Seymour (Legrand) or Leviton.
Jan 21, 2009 | Pass & Seymour / Legrand DFB600-M 600VA...
Use of computer ups for lighting purpose
To your concern of using a computer type UPS to power other devices:
  • If the light is incandescent type, yes;
  • If the light is florescent type, depends on the design. Some yes, some no. If the ballast is electronic, yes; if the ballast is inductive, no;
  • on the fan, no.
To my knowledge, most low-end commercial UPS produces a square wave. Only high end (expensive) models produces true Sine wave.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 17, 2008 | Computers & Internet
Computers & Internet Logo
283 people viewed this question
David Payne
David Payne
