Question about Toshiba Computers & Internet
Bios setting hi how can i get into my bios setting to change various setting like hard drive or cdroom to dvdrom date time etc etc
    Genius:
  • 1,056 Answers
Depending on the model, changes the possibilities.
Here's a list from Toshiba
http://uk.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/faq.jsp?service=UK&FID=0000000401
Posted on Aug 30, 2008
Vostro 200 vos200
One possibility is a dead BIOS (CMOS) battery. If you open the case to expose the motherboard, searching you should find a flat silver battery, about the size of a quarter. On the surface will be a number, likely CR2032 (maybe CR2025). The current from this battery refreshes and maintains the volatile data in BIOS, such as date / time etc. If the battery died, the BIOS will return to factory default settings. In the event the system has been altered in some way (replaced hard drive, custom RAM with different voltage requirements...), default BIOS settings may block boot-up. How to test? Power up, enter BIOS, check time. If time/date are off, the battery has likely died. How to fix? The batteries are available many places (Radio Shack, Amazon.com, maybe Walmart.. ) for less than $1. Replacing the battery, powering up, entering & refreshing BIOS {AKA "setup"}, saving settings & exiting BIOS MAY trigger the system to boot, as BIOS is capable of self detecting settings for certain components.
{Note: replacing a dead battery first is recommended but is not technically required while testing. If plugged in, BIOS should retain settings between boots).
Depending on the BIOS and any hardware changes made "post-factory", booting MAY require determining and manually entering BIOS settings for non-factory components(e.g.: RAM voltage, timing, etc.). Custom BIOS settings and other complicated solutions are beyond the scope of this introductory "Quick Fix" solution.
Nov 05, 2013 | HP Compaq dc7100 PC Desktop
Clock changes time
The BIOS battery keeps the Date & Time and the BIOS settings from changing. If the BIOS battery is flat then these settings are changed to the factory settings.
Yuo need to insert a new BIOS battery then go into the BIOS setting to set the Date & Time etc.
Sep 16, 2012 | Computers & Internet
How can i reset the cmos in my ms200 all in one computer?? it shows that my hasrd drive is not working, and it is really working in other computer
To reset the CMOS the easiest way is, remove the motherboard battery for ten minute then install it again. It will clear the CMOS. Then reset the CMOS/BIOS setup, date/ time etc. Another way to clear CMOS is, reset the CMOS Jumper in motherboard.
To detect your hard drive you can try to check by change the hard drive cables. Change the port in motherboard. Check the BIOS setup and reset it if need.
Jul 06, 2011 | HP Pavilion AllinOne MS214 185" Desktop PC...
How to change bois setting
Hi, Welcome to FixYa!
Please follow these steps,there are different way od going to BIOS depending on the brand of the laptop.
1 Turn on your computer
2 Hold down F2, this will take you into BIOS. On some computers it might be the DEL key, or F1.
3 Change the settings in BIOS to what you desire. You will see parameters for various devices, if your BIOS allows it, you can even overclock the CPU.
4 Look at the BIOS menu. You will be able to see the make, model, and capacity of your hard drive, processor speed, time and date, among many other settings.
5
Click "exit without saving changes" if you make a mistake, and nothing will be changed.
Hope this will help...Thank you for using Fixya...
Jun 19, 2011 | HP Compaq Presario v3000z Notebook
Installing window 7 but cd pc not booting from cd
Windows 7 installer is not a CD it is a DVD installer. Cd drive can not read a dvdrom (dvdr or dvdr/w). You must have DVDrom drive to install the windows 7 installer. Here is the video tutorial on how to install windows 7 have a nice a day!
May 27, 2011 | Computers & Internet
How do you view the bios settings on the dell precision m4500?
Please follow these steps,there are different way on going to BIOS depending on the brand of the laptop.
5
Hope this will help...Your response is very much appreciated...
Feb 16, 2011 | Dell Precision M4500 Notebook
I have Sony vaio vgn-nr21z how can I go to the bios setup which key to use
5
Feb 15, 2011 | Computers & Internet
Hi I have a Sony vaio vgn-nr21z I don't know how to go bios setup pls tell me how to do that
5
Feb 15, 2011 | Sony Computers & Internet
Clearing cmos
The BIOS battery maybe under one of the panels on the bottom of the laptop or under the keyboard.
To reset the BIOS ack to the default settings, go into the BIOS configuration and look at the various configurations, usually there is a setting to load the Default settings, then save and exit, and this would not change the Date & Time setting.
The other way to set the BIOS default setting is to remove the BIOS battery (it is probably a lithium 3volt button battery), wait 1/2 hour and replace the battery, the go into the BIOS configuration and set the Date & Time setting etc.
Jul 04, 2009 | Compaq Computers & Internet
Thinkpad 380ed
1) This is a typical problem when the CMOS battery is very weak or dead, it will continually display the date and time and reboot with the same errors until you change the CMOS battery. On this model it is behind the door that houses the memory chip, above the battery, if you have the laptop turned over and battery closest to you. <--best bet, its a dead CMOS battery.
2) You can get to the BIOS to run tests, one of 2 ways, either hit the ESC key and other keys to get a 301 error or hold the F1 key and boot, you should get into BIOS. (You probably won't be able to do this until you replace the CMOS battery.) From there you can run diagnostic tests on various components.
3) Lastly, you can update the BIOS. From inside the EASY-SETUP bios you should be able to copy the BIOS part number, date, etc. Look for the BIOS update based upon model # either thru a search on the web or directly on the IBM website (a search on google of "bios update thinkpad 380ed" will bring up a link for the IBM page.) If you choose to do a BIOS update, read the directions carefully and remember not to power off the machine while the update is happening. If you've never updated a BIOS before, get someone who has to walk you thru it before attempting it by yourself.
GOOD LUCK :)
Sep 19, 2007 | IBM ThinkPad 380ED
Computers & Internet Logo
821 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
