Question about Palm Tungsten E Handheld
How do I get outlook & my palm to sync?
My Tungsten E palm was given to me and unfortunately I did not receive the cd that came along with the palm. I downloaded information from the palmOne website. I was able to get hotbar to sync, but it will not completely sync with microsoft outlook. So, I have not been able to get my calendar, contacts and other information to sync with my palm. As a result, I downloaded a temporary program that allowed the information to sync, but I want to be able to do this without the program and the fee attached. PLEASE HELP!!!
    Master:
  • 473 Answers
Hi, if u want to sync with outlook , u would either have to buy the installiation disc from palm online store or call up tech support , it will cost u, or if you want u call also chapura and buy the outlook conduits from them , u dont get the outlook conduits on the website . In the installiation disc u get the outlook conduits . Regards
Posted on Sep 11, 2005
SOURCE:
My T5 will not synch my calendar in Outlook
Welcome to Fixya
Double check the Palm or palmOne program in Windows. Click Start then All Programs then Palm or palmOne. You should see an icon in there called Sync with Outlook or something similar. Click that icon and the Outlook conduits will replace those for Palm Desktop. Some conduits, like Media/Photos will continue to sync with Palm Desktop, but Calendar, Contacts, Tasks, and Memos will sync to Outlook.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Aug 10, 2011 | Palm Tungsten T5 Handheld
Transfer calendar info from Tungsten/E Palm to iphone 3GS
The best way is to transfer the Calendar and Contacts to Outlook. The iPhone can then be synced with Outlook.
Unfortunately, tasks and memos do not transfer. You will need to find other 3rd party apps that are supported on the iPhone and transfer your data to them.
Two examples are:
1. Evernote - This is good for memo. You can export your memos and then import them into Evernote. unfortunately, when I did this, it was a bit tricky. I even had to write a little PERL script to create the format that it wanted.
2. RemembertheMilk - this is a todo application
Jan 03, 2010 | Eforcity Apple iPhone 3GS 16GB / 32GB...
I cannot sync my Palm Tungsten E with MS Outlook.
  1. Step 1 Install the Palm Tungsten software. This software is required in order to sync Palm Tungsten with Outlook Express. To install the software, place the CD-ROM in your PC and follow the on screen instructions.
  2. Step 2 Use the HotSync cable included with your Palm to plug into the USB port of your PC. You will then plug the other end of the cable into your Palm Tungsten.
  3. Step 3 Open the HotSync Manager program on your PC through the "Start" menu or clicking on the icon. You can manage the different programs available for synchronization through this program. Select Microsoft Outlook as one of the applications that you want synched onto your Palm Tungsten.
  4. Step 4 Turn on the Palm Tungsten. You will see a star icon on the menu of your PDA. Tap this star with your stylus to start syncing Microsoft Outlook Express. A dialog box will appear on your PC during the process to know the progress of the synchronization.
  5. Step 5 Unplug the cable from your PC and Palm Tungsten once the sync is completed. As the Palm resets, you will now notice that Microsoft Outlook Express is available on the PDA.
Jun 25, 2009 | Computers & Internet
Can I sync an Ipod touch with my Palm Desktop for windows?
I don't believe that the Palm desktop manager is compatible with Ipod. Unless you have your contacts associated with Microsoft Outlook, that should work.
Dec 27, 2008 | Palm Tungsten E2 Handheld
Need Hot Sync module on backup PC
Plug your E2 into your pc and when it says new hardware found, install the cd. Do not continue till you have verified sync connection between pc and pda
Dec 11, 2008 | Palm Tungsten E2 Handheld
Switching to the MS Outlook Conduits using the Palm Installation CD
Search Installation Disk, I had this same issue. The Outlook conduit is on the installation guide, you have to search for it. 1. Insert the installation disk. 2. Open My Computer 3. Right click the drive that contains the disk. 4. Click Search. 5. Enter the conduit name for your device (ex: Pocket Mirror) 6. The search results should contain the executible file that you need to run to sync with Outlook. Hope this helps.
Sep 13, 2005 | Palm Tungsten C Handheld
Switch from outlook to palm desktop
Remember to change (HotSync, Custom) settings before you perform your sync or else you will get duplicate records as I did. Good luck. Support Knowledge Library Click here to go back Click here to print Solution ID: 25263 Switching between Outlook and Palm Desktop synchronization Depending on your device, you might be synchronizing with Outlook using the Palm™ Outlook Conduits, or PocketMirror conduits from Chapura (find out which). Both of these types of conduits are installed and activated when you run the CD-ROM that came with your device. What do you want to learn about? * Switching synchronization: Palm Outlook Conduits * Switching synchronization: PocketMirror Conduits * Synchronizing partially with Palm Desktop, partially with Outlook * Note about data transfer * Macintosh information * Multiple users on the same desktop computer Switching synchronization: Palm Outlook Conduits These instructions apply to the Palm Outlook Conduits that are included with handhelds released after late 2003. The Palm Desktop installer determines which conduits are activated during the installation process. If you want to switch synchronization from Palm Desktop to Outlook, or vice versa, you'll need the original CD-ROM that came with your handheld. 1. Insert the CD-ROM into your computer. A window should open, containing the contents of the CD-ROM. 2. From the Discover Your Handheld screen, select "Install Microsoft Outlook Conduits" or "Change synchronization method" (depending on which device you have) 3. Follow the instructions for switching synchroniztion from or to Palm Desktop or Outlook. 4. See our note about data transfer Remember: Some applications will continue to synchronize with Palm Desktop. Use Palm Desktop to manage applications such as Photos and VoiceMemo
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Cannot hoysync with outlook 2003
After installing, reinstalling, deleting, hard resets, hitting head against wall... I tried installing the Pocket Mirror conduit as a last ditch effort. An error message popped up saying it could not find the mapi32.dll file. I looked at another PC, located that file in the windows32 directory, copied it to my PC, and I was able to hotsync with Outlook. To test this, I uninstalled the Pocket Mirror and Palm desktop SW, then deleted the mapi32.dll. Installed the Palm 4.1.4 sw, outlook 101 update, plus the conduit update, had same error messages. Added the mapi32.dll to the windows32 directory - was able to successfully sync with Outlook!
Sep 11, 2005 | Palm Tungsten E Handheld
Outlook will not sync with Tungsten C
Check you sync part of your desktop program and make sure you have outlook checked for transfer. Right click on Synch on bottom tray and select custom set uo
Sep 11, 2005 | Palm Tungsten C Handheld
Change hotsync
Changing back to Palm Desktop Software from Outlook with Tungsten E 1 Place the Installation CD that came along with your handheld onto your cd-rom. Wait for it to load after which you’ll see a splash screen with different menus. Note: If the cd does not automatically load, double click on my computer then click on the cd-rom drive icon and finally click on the first icon (looks like a cd) labeled ‘autorun’ 2. Select ‘Install Microsoft Outlook Conduits’ 3. Click on ‘Install’ 4. Click on ‘Yes’ 5. Click on ‘Yes” 6. Click on ‘Ok’ 7. Click on ‘Back’ 8. Click on ‘Exit’
Palm Tungsten E Handheld Logo
178 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
