Question about HP LaserJet 3055 All-In-One Printer
Printer can't send or receive faxes
My HP3055 will not receive or send faxes. I have a voip line that is supposed to be able to use a fax machine but it does not work. Printer just keeps saying communcation error...Pls help...
Same problem here - I got it work:
- Error Correction: off
- V34: off
(both Menu -> Fax-Setup - All Faxes)
- detect-dial-tone: off
(Menu -> Fax Setup - Fax Send setup - detect dial tone)
:-) Stefan
Posted on Sep 05, 2009
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
How do I change the setting in order to use fax on voip line?
Hi
The data transmitted during a voice call and a fax transmission are converted to digital pulses in the same way, so sending is not the problem. The problem is at the receiving end. A receiving fax device has to be set to pick up the call before the voice call device, as it is the prompt of the fax transmission signal that makes the receiving fax switch from send or idle to receive mode.
So, if you are faxing over the internet the intended recipient's setup is a complicating factor.
Since faxing to landline fax machines via VOIP would incur a charge, you might consider a cheaper software solution such as eFax (www.efax.com), which enables the receiver to receive the fax as a PDF document attached to an e-mail.
I hope this helps
Aug 26, 2011 | Ricoh AC104 All-In-One Laser Printer
Can dial out and receive incoming calls but will
Are you connected to a VOIP line for your fax?
A VOIP line can come from a company like Vonage or your local cable co.
If so:
Unfortunatly, faxing over VOIP (Internet) is not always successful. You might want to talk to your VOIP provider if they have a solution.
If not:
Are you trying with the same fax to send and recieve? Some traditional fax machines have probles connecting to fax modems, which is what you have in an Office Jet.
Try having someone else send you a fax and try sending to another number. Otherwise, you might have a defective fax modem.
Nov 07, 2009 | HP Officejet 7210 All-In-One InkJet...
Comm error on a VOIP line
Fax cannot send on a VOIP line unless the VOIP line has T.38 fax protocol service.
Sep 25, 2009 | Brother FAX-575 Plain Paper Thermal
I have two problems with my OfficeJet 6310: 1. The fax screens appear Hebrew. Similary, If I try to use the copier from the printer. This is continuously caused by HP Update 2. I can not send out a...
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax
Jul 05, 2009 | Computers & Internet
Cannot send or receive faxes
Use the HP Fax Test
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Someone is faxing me iam getting commerror283 how to fix it
This error typically indicates a problem with the line. Sometimes it's caused by noise (like from DSL on the same line, or alarm systems/home automation systems that use the same line).
Try other devices on the line, like a standard phone or modem and see if you can detect the noise issues. You may need to order a separate POTS line for faxing, especially if you are using the aforementioned services or VoIP systems.
Hope this helps!
Mar 29, 2009 | HP LaserJet 3055 All-In-One Printer
How can send fax thru internet
You can not send faxes thru the internet unless you use a service such as E-Fax.
Faxes usually are sent via phone lines only.
If you are asking anything else then you have to be more precise in your question as it is not exactly clear as to what you are asking!
Good Luck!
Rich Lilja
Dec 04, 2008 | HP LaserJet 3055 All-In-One Printer
HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
the 5610 will send & recive with comcast try to do the test from the unit itself. Try to send a test fax to HP 1-888-473-2963 it will send you a return fax
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Can't send fax
Greetings,
Seems that you accidentally ended the chat session.
Here's what i got, your phone service is on VOIP
VoIP is voice transmission over a broadband Internet connection instead of a standard phone line. Basically, Vonage converts your voice into data and sends it like an email.
Fax machines, like yours, are designed to work with the regular phone lines. As your phone line is digital, the functionality of your all-in-one printer & fax cannot be guaranteed.
Vonage also offers a dedicated fax service and you might want inquire them about that.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 05, 2008 | Canon PIXMA MX310 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
591 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
