Question about Whirlpool Duet GHW9150P Front Load Washer
GHW9150PW3 I am getting an F6 code at the very beginning of the wash cycle. It stops working before it really starts. What do I do?
  • 5,911 Answers
The "F06" error code is a motor speed problem. The following link explains this for you:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Before assuming you have a failed component, however, UNPLUG the washer for at least 30 minutes to reset the computer. In may cases a momentary glitch can generate false error codes. If the problem reappears, follow the advice provided. The most common cause is a failed MCU, but doublecheck everything to be sure.
In the event that you require parts, you can find replacements at searspartsdirect.com. Just type in the model number you provided and you can find the parts you need under the "Pump and Motor Parts" heading. The MCU is listed as item number 1 (part #8182706), and the Drive Motor is listed as item number 16 (part #8182793). You may also try repairclinic.com. Just use the same part numbers for your search. They carry the same parts for less in some cases. I this case, they have the Drive Motor listed for a better price, but Sears carries the MCU for a better price.
I hope this information is helpful to you. Please let me know if you require additional assistance.
PS Even though these parts seem expensive, a service call can cost you twice as much with the labor costs included.
Posted on Aug 31, 2008
LG washer makes start/stop sounds at beginning of cycle. Is this normal?
If it works and washes the cloths most likely it is normal.
Oct 07, 2016 | LG Washing Machines
What does and F6 error code mean on a whirlpool duette front loading washing machine mean and how do I fix it?
Error code F06 means Drive motor tachometer error.
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
1/ Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
2/ Check the Drive Motor
3/ Check the MCU
4/ Check the Wire Harness
Replace failed component or contact an authorized repair agent.
Oct 15, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Fagor dishwasher showing f6
Please check fault codes on page 70 in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
F6 would mean the water is not getting heated. I am not sure which model you have but if there is only a cold water inlet connection then either heater or thermostat is faulty. If you have both hot and cold water inlet then you may have to check if hot water is getting in at right temperature. Easiest way to confirm is to run dishwasher in cold cycle (short rinse) and see if it goes through. The heater would get used in warm/ hot wash cycles and drying.
Sep 19, 2014 | Fagor Dishwashers
I HAVE A WHIRLPOOL WASHER GHW9150PW3 FRONT LOAD WASHER AND THE CODE F 05 IS BLINKING
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the “F/05” error code
will be displayed.
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Refer to the
“Water Temperature Sensor” section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
Or just call service! (:
Feb 16, 2010 | Whirlpool GHW9150 Front Load Washer
Kenmore HE4t Won't continue drain cycle Code F6 & beeping
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
Feb 03, 2009 | Kenmore 46462 Front Load Washer
Kenmore Elite Oasis HE/ Error Code F1
Sorry to tell you but you have a faulty control board. It is a bad part from the factory. They know that its bad too! They have completely remanufactured the part. There is lawsuit against whirlpool (whirlpool made the oasis) for the problem. Some people have been able to call and complain to whirlpool and got them to pay for the repair. Complain a lot. Good luck. sorry for the bad news.
Nov 20, 2008 | Washing Machines
F6 Code
f6 communication error in ht emotor controll board, located in the lower left front of machine
Nov 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
302 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
