Question about Sony Cyber-Shot DSC-F505V Digital Camera
505v battery I saw that the battery life for the 505v is 2 hrs. Will this battery work in the old 505k? If so, will it get 2 hrs or is that also due to the ccd difference? RON C
    Master:
  • 551 Answers
If you're talking about digitalkamera.de info, I believe it's incorrect. SONY japan's web page states 1300 shots and 1 hour life for the battery and it still uses the same battery from 505k, NP-FS11. I think it's possible they have reduced the internal circuitry power consumption (in 505v) to reduce battery drain, but the battery itself seems to be identical.
Posted on Sep 11, 2005
SOURCE:
Why it takes for 36 hrs to fully charged my palm treo750.sometimes its slow in charging the battery
This could be due to a faulty charger, or a software problem. Check whether the phone gives the same battery life after charging it for 4-5 hours. If so then it's probably a software problem and you can ignore it. If that doesn't work then try replacing your charger or battery.
Jul 03, 2011 | Palm Treo 750 Smartphone
Tip
Better Battery Life Span
Rechargeable batteries can be maximized to its usage.This pertains to mobile phone re chargeable batteries. If the uses reaches to the point wherein batteries are easily drain. You can solve the problem and resuming back the batteries to its normal capacity and performance.HOW? You need to put your old batteries in a freezer for an overnight. But before doing this, you need to be sure that your battery is in an empty status.
1.Pack it with a newspaper or a masking tape and be sure that it is fully packed that no water can wet the battery.
2.Put is inside the refrigerator freezer and let it stay overnight or at least 8 hrs.
3. After doing no.2 Remove the packing and let it dry under the sun. make sure that it is fully dry.
4. Charge the battery for at least 6-8 hrs.
5.Then the battery will resume its full performance as good as new
You can now use it in your phone again.
on Apr 08, 2010 | Cell Phones
Milwaukee tool 18 volt nimh battery won!t charge
If the battery pack is more than 2 years old its time for a replacement. The typical charge/discharge life cycle of a rechargeable cell is 500 - 700 times and the shelf life is about 3-4 years from the date of manufacture. If the charging indicator lights up when you dock the battery on to the base and still does not work after 5 hours - its due for a replacement.
Apr 08, 2011 | Dewalt Accessories Batteries 18 Volt
I Use a fully charged(more than 14 hrs charged) New Sanyo battery 2700 mAH Ni MH rechargeable on my Sony Cyber Shot DSC-W5 Digital camera, when the power is on the battery display shown fully...
may be batteries you brought are old try with normal ( not rechargeble ) batteries. it would not last long but you can take atleast 30 to 50 photos. if it works it means new batteries are faulty.this type of problem i never saw in camera.use SANYO harmolattice HR-3UQ batteries.
Jun 22, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
ASPIRE 4530 laptop. It is 11 months old. Battery life is 20mins
http://shop.ebay.com/i.html?_nkw=ASPIRE+4530+battery+&_cqr=true&_nkwusc=ASPIRE+4530+batterry&_rdc=1
Apr 19, 2010 | Acer Aspire 4530-5889 Notebook PC
Battery Life is VERY short. refuses to last longer than 10 minutes on its lowest power setting. Why is this happening? Does this happen with them all?
No generally Sony VAIO battery should last upto 1.5-2 hrs ..So your battery needs to be replaced ...
Thank You..
Dec 03, 2009 | Sony VAIO VGN-N250E/B Notebook
What is the battery life
It sounds like you need a new battery.
I would have thought the battery should go for 8 hrs before recharging.
Batteries are available in most supermarkets.Hopei`ve been of help.
Nov 25, 2009 | Panasonic KX-TG2224 Cordless Phone
Battery
The battery on this model tends to last between 2 to 4 hrs dependant on use. Does yours only work uoto about 2 hrs or does it sometimes last longer? If the battery is more tham 5 years old it MAY be worth changing.
Jun 19, 2008 | HP Compaq nx6110 Notebook
Sony Cyber-Shot DSC-F505V Digital Camera Logo
89 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
