Question about Samsung PCN5425R 54" Rear Projection Television
Toshiba p503sgf convergence reprogramming
I have a toshiba p503sgf rear projection arcade machine with a convergence problem. i have replaced the chips but the colours still are not converging (it looks like 3D without the glasses) i have been told it needs reprogramming but have not been told how to do so. can you help?? Tv looks like its i'm watching 3d. Blue convergence will not move with remote. What part do i need?
My Toshiba 53H71 rear projection TV's picture looks like double vision with a heavy tint outline how can I fix this???
Double vision/ picture problem occurs due to failure of convergence output ICs in rear projection tv and it is common problem of projection tvs.
Please replace convergence output ICs in tv to solve the issue, there is convergence repair kit available for $70 on This Site that has required parts/ ICs, instructions about how to replace ICs etc for a handy person.
Hope these info will help.
Thanks.
Jun 11, 2011 | Toshiba 53H71 53 in. Rear Projection...
57H81 rear-projection Toshiba red un-aligned
sounds like to me that you need to replace the convergence IC's.
Apr 06, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
I just replaced the blue projector. How do I set
Coarse adjustment is done by adjusting the convergence coil on the neck of the tube, also the skew is adjusted there. The user menu should have a convergence adjustment option.
Jan 07, 2010 | Toshiba 50H72 50" Rear Projection...
Rear projection
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 12, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba Rear Projection Tv 40WH08B
If the convergence on one or more color does not align using the convergence setup procedure, that means that one or more convergence ICs must be replaced, that is the reason why you get bad picture.
That means that the convergence ICs are bad and must be replaced, the job is about $200/$300.
Here there is an example of the repair needed: Fixing Convergence problems in RPTV's
Mar 10, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba rear projection 57H81 Model
most possible cause is failed convergence ICs. Unplug the three wires for the convergence yokes then try powering up the set if it powers up the Convergence Ics need replacement
Mar 04, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 42 WH36 P REAR PROJECTION
You have a convergence problem. Need to replace convergence IC's.
Jun 02, 2008 | Toshiba 42H81 42" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
167 people viewed this question
Henry  Thomas
Henry Thomas
