Question about Palm Vx Handheld
Vx to Outlook 2002 failed - no connection Established
My hotsync has been working fine through Pocket Mirror and literally one evening it worked and the next morning it didn't. My IT staff claims they didn't change anything on my PC, however I have no explaination. The following is the message I get: "The connection between your handheld computer and the desktop could not be established. Please check your setup and try again." I've uninstalled and re-installed Palm Desktop and Chapura Pocket Mirror and I've checked the connectivity of the cradle. The connectivity is fine, but the PDA still won't connect to either the Palm Desktop software or Outlook. Any suggestions?
    Master:
  • 473 Answers
Hi, on ur palm tap on home , u would see hotsync icon tap on that , on the hotsync page , u would see ur name on top or just welcome , make sure u see direct serial on the same page , tap on the top left corner where it says hotsync in words , in the drop down , tap on lan sync prefs , make sure local hotsync is darker in shade. on the pc make sure u see the hotsync manager at the bottom right corner , if not , click on start , click on all programs , choose palm desktop , inside that u would see hotsync manager , left double click on that , if it doesnt appear at the bottom right corner , try 4times , then if it still persists , restart the pc and try again. Once u see the hotsync manager at the bottom right corner , right click on that , left click on setup , left click on local , choose a different com port , reduce the speed to 9600 , click on ok restart ur pc and try hotsyncin , if it doesnt work try the previous step again and do not forget to restart ur pc , and then perform a hs , it will work .... Regards
Posted on Sep 11, 2005
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
I can not connect my pocket PC
you connect by blue tooth wifi or cable ? check there setting too zonealarm block network access check its setting
Apr 20, 2009 | Computers & Internet
Unable to sync with outlook 2003
Try to change conduits to hotsync with PDS, if it will work then the problem is with the MSOutlook.
Sep 12, 2005 | Palm Treo 650 Handheld
Compatablity with Exchange 2003
I believe you will have no problems. HotSync talks to the Outlook client rather than the server.
Sep 12, 2005 | Palm Vx Handheld
Original sync worked all others failed with 650 and Outlook 2003
I was ready to give up completely. Uninstalled, reinstalled, nothing worked. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now. This worked for me. I hope it helps with your errors.
How can I hotsync both ways?
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Sep 11, 2005 | Palm Zire 31 Handheld
Cannot establish connection with desktop.
Try to connect it not through the hub, but standalone ... could be a power issue from the hub ...
Sep 11, 2005 | Palm Tungsten E Handheld
Cannot hoysync with outlook 2003
After installing, reinstalling, deleting, hard resets, hitting head against wall... I tried installing the Pocket Mirror conduit as a last ditch effort. An error message popped up saying it could not find the mapi32.dll file. I looked at another PC, located that file in the windows32 directory, copied it to my PC, and I was able to hotsync with Outlook. To test this, I uninstalled the Pocket Mirror and Palm desktop SW, then deleted the mapi32.dll. Installed the Palm 4.1.4 sw, outlook 101 update, plus the conduit update, had same error messages. Added the mapi32.dll to the windows32 directory - was able to successfully sync with Outlook!
How do I HotSync a Palm Vx with Outlook 2002
You'll need a softwre like Chapura PocketMirror that you probably have on your IIIc CD-ROM
Sep 11, 2005 | Palm Vx Handheld
Update to MS Outlook 2003 causes Hotsync error
delete local user name in desperation, after removing the user name from the handheld and still not getting any results or ANY syncs, I launched Chapura Settings from My Desktop, deleted my user name, re-created my same user name, same spelling, and then everything worked first time every time. I have the latest Pocket Mirror PMStdUpdate3171.exe loaded on top of what came on the installation CD. to sum up, I deleted the user name from both handheld and PC and recreated it only on the PC, then sync'd with outlook 2003 without even a reboot. good luck
Sep 11, 2005 | Palm m130 Handheld
Palm Vx Handheld Logo
96 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
