Question about Xerox DocuColor 12 Color Copier
Ripples down the sheet
On the non operator side of the copier, when we run cover weitht stock.
The sheet is nice and flat down the operator side and the paper has waves all the way down the other side. We mostly run 12 x 18 heavy weight setting through tray 5. I believe it is a pressure problem that is out of adjustment from side to side.
    President:
  • 2,072 Answers
That is a problem with the fuser. More than likely both the heat and pressure rolls need replaced. They wear and develope flat spots and get out of round and cause those problems.
Posted on Aug 30, 2008
Tyre pressure on Isuzu bakiie 245x75x15 4x40tyre
welcome to the Fixya USA forum. (we call them Tires)
the famous (choke) forum with Zero KB, nor Bakiee trucks
not a single one,
nor books on same.(for same reasons, wink !)
if running non standard tires, (in USA the law requires stock tire data
on the dirvers (left) door jamb)
but when you dont use stock tires, then you get to be mr. engineer.
in that case every tire maker in the world publishes,
a tire TABLE (paper) sheet, called a data sheet.
this sheet, covers weight of car, and proper pressure to match it.
there are only 2 ways to do this. (above)
google how to measure tire foot prints.
getting the pressure correct, allows for maximum traction
under inflated, causes cupping of the foot print
over inflated cause crowning... both are a danger, on wet roads
or driven too fast like that.
tire.101, end.
Dec 05, 2016 | Isuzu Cars & Trucks
Guess I'm not too bright. Have a pack of GBC SelfsSeal Laminating Sheets, 9 x 12. Instructions say "Center item face sown on the clear non-adhesive." "Peel away the liner and...
It's not you, it's the instructions. They are just wrong and will not work as directed. However, I have found a way to use these sheets that works for me, but it is still not particulary easy.
Step 1) Lay the 1st sheet on a flat surface, adhesive side up. Pressing down on the small 1/2" strip of backing, peel away the large backing sheet exposing the adhesive. Holding the sheet you want to laminate face down and at an angle to the work surface, carefully align the material by "bumping" it up against the edge of the 1/2 strip. Once aligned, carefully and gradually lay the item onto the adhesive. Like I said, not particularly easy, but if you are careful, it will work.
Step 2) If you want to double laminate, which I usually do, the second laminate sheet seems easier to me. Leave the Step 1 laying flat on the work surface. Take a second lamination sheet and again, hold it down on a flat surface and peel away the large backing sheet, leaving the small 1/2" backing attached. Take this 2nd sheet and holding it over the 1st, face down and angled up from the work surface, align the 1/2" strips of both sheets together and again carefully lay the 2nd sheet over the first single-laminated item. The two 1/2" strips don't stick to one another allowing a bit more flexibility for alignment.
Press all of this together and work out any bubbles or wrinkles. Once that is done, pry the two sheets apart at the very edge to remove the two 1/2 strips.
Unless you are incredibly lucky the edges will never align 100%. I use a paper-cutter to trim off any irregularities after I finish laminating.
Apr 11, 2011 | Gbc Selfseal Letter-size Laminating Sheets...
Error code 6A00
This error indicates a paper jam. Something is restricting the paper path. Check the paper path from the Automatic Sheet Feeder (ASF) side, raise the cover and visually check the paper path. Try running a thicker sheet of paper through the printer (card stock will work) to see if you can dislodge the restriction.
Let me know if this clears the problem. If not we can try something else. Thanks.
Feb 27, 2011 | Canon PIXMA MP830 All-In-One InkJet...
C9600 OKI.....On the printed sheet there starts to be a light layer under the text. I goes from side to side on the sheet although the backround ought to be quite white. Any information of the end of the...
Perhaps drum exposed to sunlight too long. It will ruin drum.
Could be foreign material inside drum or printer.
Run heavy stock through printer with nothing on page, to do this-
Open up Word. type a period, or a comma.
Print 10-20 copies.
This may clear it up.
Mar 26, 2010 | OKI C5400 Laser Printer
I need help. I'm running 12x18 cover stock. The
it sound like you are taking the machine to its limits... if its going to be possible... you need to call a tech and have him upgrade your rollers and see if there are any setting changes that need to be made for your particular situation... there is no way around that...
Dec 18, 2009 | Canon CLC 1140 Copier
1998 4.0: splash guard damaged.
use bigger washers ,or cut up a old plastic bucket to make a nice square to cover the damaged parts
Nov 15, 2009 | Jeep Cherokee Cars & Trucks
Non visible paper jam
Fixed the problem by running two sheets of heavy card stock through at the same time.
With the machine off, positioned the two sheets in the feeder so that they would be pulled in when the printer was turned on. When turned on the printer, it drew the two sheets through and this reset the paper sensor. Previously found that only one sheet at a time did't work.
Aug 10, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Polyester labels from tray 1 4 labels per sheet right side color
It says on the website the labels are 56lb (I guess cover weight). The only way the stock will run right (ie) fuse correctly is in the mp tray using one of the thicker settings. Also if you run labels out of the tray you run the risk of them peeling off making the turn out of the tray and into the machine. All non standard paper is better off using the mp tray.
Mar 29, 2009 | OKI C5150n Led Printer
HP 2600 ghosting
It is a massive pain but a solution that worked for me is to run a 'clean' after every card stock sheet. I know it's wicked awful but it actually worked and I had to run 100 times (one for each good color card stock)
First put plain paper in tray 2
Next
Hit left arrow until you get to 'system service' and press green check
Next
then go to 'clean' and press check
Now it should print a clean image without ghosting
May 29, 2008 | HP Color LaserJet 2600n Printer
Problem printing business cards
in your program adjust the pic your printing to fit in yours sumtimes u have to adjust your print in preview box your card u made down or up whole thing so it fits in nice for u sumtimes they just dont line up right i had same issue just move your project up with it ok to make it print in box cards u need ok
Mar 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
Xerox DocuColor 12 Color Copier Logo
62 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
