Question about Palm Treo 650 Handheld
Limited synch
I do not want to synch me entire outlook file, only selected contacts. Can I do this?
    Master:
  • 473 Answers
Create a sub-folder in your Outlook Contacts. Place the contacts you do not with to sync in the sub-folder.
Posted on Sep 11, 2005
Contact list doubled entrys
One entry is most likely sim card and other is synched from outlook. You can usually chose contacts to display and select one or the other in contact settings.
Nov 16, 2012 | Samsung Galaxy S 4G Cell Phone
How do I synch outlook 2003 with iphone
You didn't say whether you're trying to sync everything (mail, calendars, contacts) or just some things or one thing (like contacts only). I don't know if you're using an Exchange server or even if you have the info you'll need to sync with an Exchange server.
I have a Windows mobile device (AT&T Tilt) running Outlook 2007 and everything is sync'd. We also started purchasing the iphone for our employees and sync their email, calendar and contacts to their phone.
I could probably give you step-by-step information (based on how I do this for my users at work) if I knew whether you'll use iTunes to do this or Exchange Active Sync and what you want to sync between your phone and outlook. One method (iTunes) will only update your data between Otulook and the phone when you connect it to the computer with Outlook configured on it but, the way we do it at work, they receive email, data, changes, etc in real time.
Try using this link http://www.apple.com/support/iphone/mail/
What you will find here is support topics and instructions for Exchange Active Sync, setting up email accounts, troubleshooting for contact and calendar syncing.
You can also search support on Apple's Web site. Entering the keywords: iphone outlook 2003 will bring up a lot of support info.
You can use iTunes or MobileMe for synchronization. If using iTunes then try this:
You can configure which items are synchronized during a one time set up process. After initial set up, each time you connect the iphone to your computer, the changes made on your computer or device are synchronized.
  1. Connect your iPhone to your computer. iTunes should open automatically.
  2. In iTunes, in the source list, under Devices, click the entry for your iPhone.
  3. Click the Info tab.
  4. Select which items you would like to sync. For example to sync only calendars, under Calendars, you would click Sync calendars from, and then click Outlook.
  5. Do one of the following:
  • To synch all calendars, click All Calendars.
  • To limit the calendars that are synched, click Selected calendars and then click the calendars you want to sync.
6. Click Apply.
Hope this helps!
Thanks for using Fixya and you can let me know how helpful I've been by rating this solution.
Apr 03, 2009 | Apple iPhone Smartphone
Sync Problems
Lower right corner of PC,
1. right click on red/blue arrows
2. select custom
3. select direction of synch
4. Go into desktop
5. Click file/ Import/ Outlook
Jan 06, 2009 | Palm Tungsten E Handheld
I have a Dell Axim x5 ith Pocket PC 2002(I know, I know) just want to get this serviceable for my wife to use as a planner. Problem is the active synch 4.5 won't synch the calendar and contacts any ideas?
You must be using Outlook 2000. Outlook express will not work.
Select the "options" button on Activesync and verify that the items you wish to sync are checked.
Nov 26, 2008 | Dell Axim X5 Pocket PC
Pairing tungsten t3 with newer cell phones
I use Bluetooth to synch to my Sanyo cell phone, so I would think you could do the same. I maintain my Contacts in Outlook and synch with my Palm. I then synch my Palm to my phone.
1. Make certain that your Contacts (in Outlook, Palm Desktop, or whatever you use as your source to feed data to your Palm) contains ALL the phone numbers you want in your phone.
2. If, like me, you have a lot of contacts and a limited number (500 in my case) of contacts that can be stored on your phone, you will want to erase all contacts on your phone first.
3. On your Palm, go to Preferences
4. Select Bluetooth -- Bluetooth should be ON, Discoverable (Yes) and Connectable (Yes)
5. Turn on your Bluetooth-enabled cell phone -- I believe the range is 20-30 feet but I have not tested that. When I synch, I have them both on my desk because I want to see that it is working.
6. Select Trusted Devices. Hopefully, your Palm will detect the cell phone. When it does, add your cell phone as a trusted device.
7. Select Contacts on your Palm and use the pull-down menu to select Send Category.
8. Select Bluetooth
9. Select your phone
10. Your phone will probably indicate that it is receiving data. You should soon have all phone numbers stored on your phone without using a direct-connect cable.
Oct 01, 2008 | Palm Tungsten T3 Handheld
Sync Outlook Contacts & iPhone
When you create a new Contacts Folder you have to make sure that you create as a subfolder of the main contacts folder (in the create window you are shown the file tree).
I had the folders moved in different groups as well but I am not sure that it made a difference.
Please note that you have to leave outlook and itunes on for a few minutes before they synch and iTunes see the new folders.
Oscar
Sep 07, 2008 | Apple iPhone Smartphone
Downloading contacts from Palm to iphone
Just save the contacts as described above "Bring up Palm Desktop. Make sure your Palm phone is sync'ed up. Show the Address page, select all contacts (Ctrl-A), and export them with File, Export vCard... This puts all contact information into a single file as a sequence of vCards."
Then send the file you saved as an e-mail attachment - using any mail (i.e. gmail, yahoo, outlook, etc) - to your i-phone e-mail. Open this email on the i-phone and push the attachement - it then asked you if you want to add these, click (push?) yes, and select eithr merge or new and voila you got them.
Jul 27, 2007 | Apple iPhone Smartphone
Can't synch notes or contacts from outlook to Palm Tungsten C
Right click on system tray icon of synch (Red and Blue Arrow) Select custom and see what you are synching
Sep 12, 2005 | Palm Tungsten C Handheld
Microsoft Outlook data won't synch
In ActiveSybch there is an option of setting the priority of either the PC, the PDA or leaving the items unresolved. You can either change this of follow another route. With the device off the cradle delete the partnership WITHOUT deleting the partnership folder. Place the device on the cradle & let AS find the device & setup the partnership. Once setup remove the device & go to options & set all the required options. Replace the device & it should synchronise. If you still have problems please contact me directly through email.
Sep 06, 2005 | Casio Cassiopeia E-105 Pocket PC
E-125 Getting attachments for emails
What can & cannot be downloaded will be determined by your setup in ActiveSynch on the desktop. When connected right click on the Inbox on ActiveSynch main screen & select settings. Check mark the "Include File Attachments". If you are downloading the jpg files uncheck the "Limit Attachment size to" so complete attachments will be downloaded. On the PDA start the inbox, tap on Tools - Options - Storage. You should get the option of saving the attachments on storage card if one is available to save on main memory usage. But this might not be an option if you use a CF wireless ethernet card for connecting & Synching. If it does show up you will have to uncheck this option to save the attachments in main memory. Hope this helps.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
Palm Treo 650 Handheld Logo
63 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
