Question about HP Office Equipment & Supplies
Colors are not correct - green and blue when what I am printing is browns, beiges, etc.
Changed the cartridge
Posted on Aug 31, 2008
Danco instructions
Umm, yeah I think so....
Nov 10, 2013 | Danco Home
Colour prints coming out with a lilac hue
check whether the printer is in proper mode or not
Feb 29, 2008 | Epson Stylus Photo 950 InkJet Printer
Handset setting are embeddeon my phone for my MMS & mobile internet
Apr 22, 2011 | Computers & Internet
Wall Plate teminals have the colors of Green, Red, Black, Yellow, White, Blue, Brown and Tan. Cable has the Colors White/Blue, Blue/White, White/Orange, Orange/White, White/Green, Green/White,...
see the table on this link:
http://www.server-servers.com/ge-cat5-network-wall-plate-straight-through-cable-setup/
GE Network Wall Plate Cat5 Ethernet Cable 1 Blue 2 Orange 3 Black 4 Red 5 Green 6 Yellow 7 Brown 8 White White / Orange Orange White / Green Blue White / Blue Green White / Brown Brown
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 15, 2011 | Computers & Internet
I have a cat5e wall plate(tph552) a cat5e wire4 colors don't match and 4 colors do ( brown,orange,blue,green,) are ok then wire has 4 that are white with (brown,orange,green,blue,)stripe. and wall plate...
The wires/colors in a category 5e cable run in pairs. They should be tightly twisted together, mostly white with a blue tracer. mostly blue with a white tracer- mostly white with an orange tracer- mostly orange with a white tracer, mostly white with a green tracer- mostly green with a whte tracer, and mostly white with a brown tracer- mostly brown with a white tracer.The jack you have sounds like a standard telephone or cat. 3 jack. If the jack is being used for a standard telephone line, you'll need to connect one of the wire pairs(usually the white/blue pair) to the green and red terminals on the jack.Make sure that the same pair is also terminated at the main telephone junction.
Aug 08, 2010 | RCA Computers & Internet
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Trying to wire in a new stereo into nissan largo, found power but cant find speakers. is there an in line amp that i need to power up to make speakers work?
This might help.
Wire colors in your car might be different than colors described here. Use the given colors for reference purposes only. Always test wires to make sure they are correct.
NISSAN P o w e r Memory (+12v Constant) Red Ignition (+12v Switched) (varies) Brown or Green Ground (-) Black (varies - most don't have one) Illumination Red/White Dimmer Red/Black Power Antenna Green S p e a k e r s Right Front (+) Brown Right Front (-) Brown/White Left Front (+) Black Left Front (-) Black/White Right Rear (+) Blue Right Rear (-) Pink Left Rear (+) Red Left Rear (-) Green
Mar 28, 2009 | Car Audio & Video
Speaker replacement
They still follow the GM standard:
LF+ tan
LF- gray
RF+ light green
RF- dark green
LR+ brown
LR- yellow
RR+ dark blue
RR- light blue
Note that if you're looking for them behind the radio, some of the same colors may be used on other wires. The speaker wires should be placed side-by-side for each speaker.
Also, if you're replacing the factory radio, I highly recommend buying a wire harness adapter instead of cutting off the factory plug.
Jun 05, 2008 | 2005 Pontiac Sunfire
Cat 5 Issue you replied to
The color is not so important as the cable follow the same standard on both ends.
It has been my misfortune to find non-standard wiring in a facility, so long as they keep the relationship of the pins the same it will work, if the installer did not then you cannot trust any of the work and MUST either redo it all or have it all tested and certified by a cometent network cable installer.
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Apr 21, 2008 | Computers & Internet
Print quality and color
go into your canon control panel and hit align ink
that should solve your problem
Dec 13, 2007 | Canon PIXMA MP780 All-In-One InkJet...
90 people viewed this question
Ben Johnson
