Question about Saeco Incanto Classic Espresso Machine
Stuck grinder Today I have not been able to use my Saeco Incanto. First, I thought there was not enough beans - however - it seems that there is a problem with grinder. It does grind and it sounds weird, after just a few seconds after I have pushed the coffee button, the grinder stops and the red light starts flashing. What shall I do?
  • birkeboy Aug 31, 2008
    I opened the machine in order to identify the problem. I removed some beans, but I could not find a more direct cause to the grinder problem. It seems that the grinder is totally blocked, the engine stops after one second and when I was trying to move the brass arm manually with tongs it was completely stuck. I did not want to use too much force.
    What shall I do?
Thanks! It does not seem to be damp. I emptied the bean box and vaccum cleaned the grinder - I did not see any beans blocking the grinder. What would the next step be?
Posted on Aug 30, 2008
  • 515 Answers
make sure you not get any damp into the grinder. If you have damp in the grinder then it do not grind the beans.
  • Mirko Blas
    Mirko Blas Sep 06, 2008
    Take off the wire from the grinder and try to get power to it to see if the grinder works, make sure to use the same volt that shows on the grinder.
Why aren't the beans being ground?
try pushing the beans into the grind mechanism while it is grinding or turning the grinder knob but only when grinding, or try different beans
Jun 10, 2014 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Deluxe won't dispense coffee while it making a sound of brewing coffee
try to make pregroun coffee ,but without beans,just press pre groud button -if water comes out then yuor coffee beans are too fine- turn to hight number the grinder
Aug 21, 2013 | Saeco INCANTO DELUXE Espresso Machine
The plastic shield in the coffee container on my saeco incanto de luxe broke yesterday and fell directly onto the beans, but I was still able to make my coffee this morning, but this afternoon, the...
Vac out the bean chamber, then remove the 2 or 3 screws and carefully lift the bean hopper off the machine, then continue cleaning the grinder, careful not to lose the gasket around the top of the grinder. When done reassemble and try to brew but do not add beans to hopper as yet. Until you are sure all the plastic pieces are out.
Sep 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Machine won't grind beans "says beans empty" it is not
This manual above should help you. It has pictures and steps to follow.
Jun 08, 2010 | Saeco Incanto Classic Espresso Machine
Beans don't seem to go into the machine upon use
The grinding burrs need cleaning if we consider that nothing have damage them.
First and simple advice is to use the vacum cleaner and try to s**k everything from the grinder and try again the machine. If the problem is insist then you need to resasemble the grinder and clean the hole grinder with the vacum and also with a wire brush.
Good luck
Mar 22, 2010 | Saeco Incanto Classic Espresso Machine
Grinder Blocked said on screen. Any Quick fixes?
This has happened to me twice. Usually caused by a trapped bean in the grinder. Here is how I fixed it. It is easy.
Inside the plastic bean hopper is a screw located in the bottom. Remove it and lift off the hopper. Have someone help you as you turn the machine upside down to remove all the beans. Use a tooth pick or a wooden skewer to pick out any beans lodged inside the grinder housing. Once completed, return the unit to its upright position.
Look inside the hopper and locate the grinder stem which is gold colored. On top of the stem is a hex bolt. Take a hex wrench with a 7/16 hex socket, connect it to the grinder hex bolt and turn it "counter clockwise" about half way which is the same direction the grinder turns. Add some beans and see if it works. If not, turn the hex bot "clockwise" a half to a full turn. Add beans and check.
This helps move the grinder out of its "stuck" position.
Nov 03, 2009 | Saeco Incanto Sirius Fully Automatic...
Brand New Incanto, Grinder Doesn't Work
If you look at the adjustment knob in the bean hopper, make sure it is in the middle i think it will be "8".
Make sure you not get any damp into the grinder.
Try to make 2-3 cup of coffee.
Let me know if i can help you more
Best regards
Nov 08, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco grinder
What kind of Saeco machine do you have, and how old is it?
Jun 27, 2008 | Saeco Incanto Classic Espresso Machine
Incanto-classic coffee beans do not flow to grinder
The machine automatically stir the beans since the blade make vibration and doing that shake the bean all around.Make sure the the tank is half full so the weight will help on that.If the container is almost empty the bean will fly around and don`t get in the grinder.Back up the machine to the original factory grinding and try to adjust again the wheel
Jun 07, 2008 | Saeco Incanto Classic Espresso Machine
Incanto de Luxe always tells me there are no beans in container
I do have the same problem.
I have removed and cleaned the grinder mechanism.
Being an electronic technician I did have a look and tried to find what method they use to detect that the new beans reservoir is empty and I did not see any kind of detector.
I suspect that they monitor the motor current to do this. If it is so would'n it be possible to desable this fonction since it is more then evident when the reservoir is empty or about to be?
Any body knows how they do monitor the status of the new beans reservoir?
Dec 18, 2007 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
908 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
