Question about Keurig B60 Coffee Maker
Keeps tripping GFI outlets
Everytime I plug my Keurig into the GFI outlets on the counter it trips them. Up until last week I have used those same outlets for the entire 18 months that I have had the Keurig.
  • rbeers Sep 02, 2008
    Thanks Rickzilla. It blows both GFI outlets in my kitchen. It works in a non GFI though.
  • Anonymous Mar 20, 2014
    this morning I plugged my keurig in, pressed the button and the machine is completely dead. It will not turn on. I tried other outlets and time to warm up but no luck.
  • 706 Answers
The key here is to identify the problem as being either the coffee maker or the GFI receptacle... a simple test can be done as follows...
Try plugging the Coffee Maker into another GFI receptacle .. you may have one in the bathroom? If it trips that too, then you have an internal wiring problem with your coffee maker.. if it doesn;t ..then your GFI receptacle may be bad or on the verge of going bad .. either way..this should narrow the problem down to one or the other.. hope this helps..
Posted on Aug 31, 2008
  • Rick Gelin
    Rick Gelin Sep 02, 2008
    If it blows both GFI breakers... there is leakage current internal to the coffee maker and I would discard or replace it. Normal (non GFI ) receptacles do not sense any leakage current and will only trip the main breaker if it draws in excess of that breakers rating.. The fact that it trips multiple GFI receptacles is an indicator that there is an internal problem and it may be a shock hazard if left as is..
  • Shaun H
    Shaun H Apr 24, 2014
    Blowing a GFI doesn't mean there is an internal current leakage...speaking with Keurig they said just plug it into a non-GFI and if it powers up there then the problem is most likely you haven't descaled it like they recommended. You can either follow their video herehttp://www.keurig.com/descaling or run 48 ounces of undistilled white vinegar through til empty, let it sit 4 hours powered on, rinse water through system til you don't smell vinegar then try plugging into the GFI again.
My refrigerator keeps tripping my gfi out let.
This is a problem I have encountered before. When compressors start they sometimes trip gfi. Plug unit in different outlet or replace GFI with regular outlet
Jun 22, 2011 | GE Refrigerators
Our Keurig keeps kicking off the GFI outlet when turned on. Worked fine yesterday. When the outlet is reset I can hear a click insied the machine. Any help would be great. Thank You Kevin McShera
This is not an exact science. The GFI is trying to trip when it thinks you have a dangerous short. But a powerful device will require a surge when it starts up that is always pretty close to what appears to be a dangerous short. You could switch the GFI out with one rated higher, like 20 amps instead of 15 amps. It would be harder to tell if the Keurig is drawing excessively, because it would only be a transient, for a fraction of a second. You would almost need an oscilloscope to tell what it was doing accurately.
My advice would be to try a surge protector, such as:
http://www.hardwareandtools.com/invt/u720584
The idea being that a surge protector has capacitors in it, to slow down or clip rapid current flow or voltage build up. Which should reduce any eroneous tripping. Basically this one is a plug in version of what you have in the wall, but higher quality and easier to install.
Jan 22, 2010 | Keurig B50 Coffee Maker
My electric smoker keeps tripping breakers
My Brinkmann 810-7080-4 Gourmet Electric Smoker was tripping my GFI after it sat for the winter. Would heat for about 3 minutes then trip the GFI. would keep tripping GFI until it cooled down and once again would trip after about 3 minutes.
--SOLVED: took 00 steel wool and olive oil to the heating element and removed what looked like a green fungus. Element is working fine now, not tripping the GFI and will run a full four hours for smoking!
Hope this helps save someone some money in purchasing a new heating element ($40).
Nov 26, 2009 | Brinkmann Smoke' n Grill Electric Double...
When i plug it in it trips my gfi and it is not on
This can be caused by one of two things. (1) The GFI plug has a problem: it could be broken behind the face plate, or some of the wires in the box are so close that when you push a plug into the outlet, they touch and trip the GFI. (2) The other source is due to a defect in the appliance between the cord and the power switch. That is why the GFI faults even before it the coffee maker is turned on.
Have the outlet checked thoroughly and make any needed adjustments / repair /replacement and reconnect the coffee maker again. If it trips, the coffee maker will need to be serviced. DO NOT use the coffee maker in another non-GFI outlet until it has been checked out. The chances of electrical shock or burns is significant until the problem is found and corrected.
Oct 02, 2009 | Bunn Coffee Makers & Espresso Machines
It keeps tripping a GFI outlet
GFI outlets tend to wear out very quickly with a refrigerator running on them,most Manufacturers do not recommend plugging any major appliance into a GFI outlet.If you plug it into a non GFI outlet and it works fine the problem is in the outlet.
Sep 06, 2009 | Refrigerators
I have a model 50 Keurig that started tripping the 15 amp GFI in the kitchen. I went to the opposite counter with out the GFI and had no further problems with power.This a.m. the machine was trying to heat...
most Keurig cofee makers will trip 15amp GFI'S .
So you should unplug the machine take all the water out wait about 1/2 hour . Then plug it into an outlet that has at least 115volts and 20 amp breaker or fuse . You can purchase plu in testers at radio shack or electrical supply store.
let me know.
Jun 27, 2009 | Keurig B50 Coffee Maker
My under counter Uline refrigerator/ice maker suddenly trips GFI
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
Jun 10, 2009 | U-Line Uline Origins Series...
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
GFI for pump keeps tripping...
no you need to put 60amp breaker in house panel box
Jan 15, 2009 | Beckett Water Gardening Beckett Statuary...
Freezer GFI reset
no what rpobebly happened is that your freezer fillefd up with humidity and now its shorting out and tripping the breaker. make sure that theres no ice in the freezer also you should not really have it plugged intoi a gfi outlet.if its in the garage near the breaker panel i would add a dedicatefd outlet for the freezer from the electrical box.
Jul 01, 2008 | Frigidaire FRT15G4B Top Freezer...
Keurig B60 Coffee Maker Logo
2,562 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
