Question about HP Vs17 17" LCD Flat Panel Monitor
Dark picture Picture is dark brightness control has no effect
  • jaygavin30 Sep 02, 2008
    dark screen even though brightness up full
You probably have a bad capacitor on the invertor board. try shining a flashlight into it to see if you can see anything. if capacitors are good, you might have some burnt out backlight bulbs. i just had the same problem, replaced the capacitors but messed something else up on the way i guess cause now all i have is a bright white screen with a few colors here and there.
Posted on Sep 14, 2008
Top left and right corners are dark on my 55 inch seiki tv
The picture tube could be getting old.
Normally this effect can also be due to alignment with the magnetic meridian.
You can try to de-gaussing with a high voltage gun.
http://www.repairfaq.org/sam/crtfaq.htm
see section
CRT Age Resulting in Dark Picture
Aug 20, 2016 | Televison & Video
Samsung dlp 1080p picture is dark and brightness control is at max
I am hoping somebody will answer this because my TV is dark and I played with the controls and it is still dark!
Sep 24, 2012 | Samsung HL-S6187W - Rear projection TV -...
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
Picture get dark than light
On your remote control, press the huge circle, which should be settings or menu, there, go on brightness, put it up to max if u want bright, and low if u don't .If the problem still happens, ask customer service to help, or return it!!
Feb 19, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
PS2 Picture Problem
Hi MG86,
Most PS2 games are dark and auto brightness controls will casue your LCD tv to brighten up automatically in response the dark video coming from PS2 games. I suggest you get into the menu settings of your TV and find a setting that will shut off the auto picture controls.
Nov 23, 2007 | Sony PlayStation 2 (PS2) Console
Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Oct 15, 2007 | Toshiba 32AF43 32" TV
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Mar 03, 2007 | Zenith B25A02Z TV
Panasonic ctp2780sf Picture very dark
check the ABL at the flyback and solder any bad connections there. U can increase the brightness at the flybacks buttom control .
Dec 29, 2006 | Panasonic CT-27SF25 27" TV
HP Vs17 17" LCD Flat Panel Monitor Logo
131 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
