Question about Apple iPod touch
NOT WORKING ,NOT CHARGING UP...
It isnt charging up.i tried so many times.i holded the menu for about 10 secondd or 1minutes.pls help me
  • boysarehot Mar 20, 2009
    it worked for me thankyou for you helpp aswell :) xx
  • 50 Answers
Have u tried holding the menu and the center of the pad at the same time? hold it for about 10 seconds and you will see it will then turn on.
make sure that everytime you unplug your ipod to your computer make sure to click the "safely remove" so it will not crash your ipod. :)
Posted on Aug 31, 2008
The on button on my phone wont work why?
Try turning your phone on and off. If that doesnt work. Try reseting the phone by holding the home and power button down for 20 secondds
Dec 07, 2013 | Apple iPhone 3G
Samtron 56v monitor control is locked
hold the menu button for 10-15 seconds.this shld unlock the menu. if the menu window still keeps popping up then u shld change either memory ic or power regulator..
Jul 17, 2009 | SAMTRON 55V 15" CRT Monitor
My baterry dosen't charge
hi
try the classic electric jumpstart
take a source like an adapter or some which has an output voltage of atleast 3 times that of the battery like say if you have a AA size NIMH battery then try using a 5Volt adapter with atleast 500MA
now hold the positve wire to the +ve of the batter and negative wire to the - ve of the battery (BE SURE OF THE POLARITIES esle u'll destoy the batery completly) and hold it for not more than 10-15 secs and then quickly place for charging in the battery charger
do this in 2 - 3 charge discharge cycle
cheers
pls rate if it was any help
Jul 05, 2009 | Cameras
Ipod 20GB screen stuc on picture of charger and socket???
do a reset. i believe it is hold center and play at same time for 10 seconds or it is the center and menu buttons at same time for 10 seconds to restart it. I hope this helps. This will not erase anything it is like restarting your computer. Good luck
Feb 19, 2009 | Apple 20gb Ipod Mp3 Player With Click...
LG studioworks problem of display
this is because some dust might have gone inside your monitor so only you are getting this problem..... If you just remove it. It will work fine..
Feb 12, 2009 | LG Studioworks 45 14" CRT Monitor
My ipod chromatic just stopped working. i unplugged it from my computer and forgot to eject it first now it is frozen onto the screen that says connected eject before disconecting and it says its still on...
Toggle the 'hold' button on and then off... then hold down the menu button and the centre button at the same time for 10 + seconds... an apple logo should appear, this should restart your ipod... if i doesn't go back to normal, from the apple screen just plug it in to your computer again and it should work!!!
Hope this helps!!!!
Nov 25, 2008 | Audio Players & Recorders
Not woking ,not charging up,nothing
you might need to restore it then.put it in DFU mode while connected to the computer. to do this, hold the home and power buttons for ten seconds and then let go of the power but keep on holding the home for 10 secs. the screen will be black and nothing will show up. go to itunes and restore it from there
Aug 30, 2008 | Apple iPod touch
Not working
are u having problem with ipod freezing?
if this is the case, hold the menu together with center of the keypad of ur ipod for about 5-10 seconds.
make sure that you have charge your ipod.
hope this would help solve your problems.
thanks.. :)
Aug 29, 2008 | Apple iPod touch
My nano ipod locked up by itself. i have no idea on how to unlock it
Hello kabob4life,
Make sure that the hold button isn't on. If it is you will see a lock icon on the display. If you do see this icon, just move the hold button to the off position.
If this doesn't work you can reset the unit by turning it off and then holding down Menu and the center clickwheel button for approximately 10 seconds. The iPod will power up and reset. If this doesn't work try charging the iPod and then resetting it again.
Hope this helps.
Ken
"Go Ahead. Use Us."
Jun 18, 2008 | Audio Players & Recorders
Click wheel
Try to restart the Ipod.
Hold the select button and the menu at the same time until you see the screen go off.
If still does not work then try to enter disk mode and see if it works.
Disk Mode:
Reboot the ipod via Select and menu, right away hold the select and play button and hold until disk mode comes on. Does the wheel work?
If still does not work then reboot the ipod again and let it reboot normal to go back in apple firmware. If all buttons are working and none of the above works, I would assume it is not software related.
Nov 12, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod touch Logo
786 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
