I have a pioneer projection TV #SDP62A5K. The tv was on and made a pop noise and went off. Now the tv will not come back on. When you press the main power button, it goes to green and clicks and goes right back to the red.
  • 2 more comments
  • sweetnlow585 Aug 30, 2008
    I have a pioneer #SDP62A5 projection TV. Recently in the past week we would be watching tv and it would go off for no reason. We would press the main power button and it would come back on. Yeasterday, we had it on and it went off, and now won't come back on. when you press the power button, it goes to green makes a click noise and goes back to red.
    We have unplugged the Tv for several hours, and it still will not come on.
    We have unplugged the Tv for more than 4 hours, and it still will not come on.
    what kind of hardware may need to be replaced and how much could it cost?
  • 446 Answers
After all things said and done, im afraid the problem is realy the power supply, no other way around it, in some instances you can still have a tech to inspect this but they'll recommed a replacement of the same.
cheers
Posted on Aug 30, 2008
    Master:
  • 638 Answers
Your power supply board is very perfect.so the power is coming when you press the ON button the red light and green light comes .but its the faulty capacitor on the main board.which has blown off and made the bursting noise, when blown.just check on the main board for that capacitor, and replace it.this will solve your problem.
thanks.
please rate the solution.
    Genius:
  • 1,011 Answers
Sir,
We generally will, but the boards are ungodly expensive and take TIME to get from the manufacturer. They aren't fast with parts.....
SOMETIMES all you need is to have all the power and signal boards resoldered.....but that takes DAYS / 6-7 hours to do that work !!
Find a Pioneer authorized servicer in your area....
thanks
good luck
  • 2,071 Answers
The TV made a pop noise maybe came from the capacitor or from a fuse. This is a power supply section problem. Pioneer recommends replacing the whole supply board not attempting to repair it. The power supply module number is AWV1622 with a retail of about $500 or so including the "DUD" charge. The DUD is an extra charge that is refunded upon receipt of the old module. In other words, if you return the part to Pioneer, you will receive a refund in the amount of the "dud".
The other possibility is that the convergence ICs are bad. These are large black ICs attached to a heatsink and should be marked STK392-xxx or something similar. Check the connections on these ICs as well. If they look good, replace the ICs before you replace the power supply. The ICs are about $25 each.
Hope this may help;
Regards,
VOTIT
    Genius:
  • 1,269 Answers
That's a power supply problem or just the fuse that might have been burned. Better check the circuit board of your tv for some blown internal components.
    Master:
  • 521 Answers
Http://www.repairfaq.org/sam/tvfaq.htm#tvtvrep
the link will guide u solve ur problem.
    Sergeant:
  • 241 Answers
TRY THESE STEPS
>Check the buttons on the TV make sure they are clean and not sticking.
>Check the Remote Control buttons and see if they are sticking
>Clean the Face of the infer Red lens to the remote and the TV...
clean them with a small rag or paper towel (Do Not USE Abrasives to clean any part of your Electronics)
>Check the plug for any defects
>Reset your tv back to it,s factory settings
>And if any thing locate your user manual and find the 1-800 number
  • 19,396 Answers
By unplugging it for a while and draining power from TV you reset it, this can solve the problem if some chip is jammed with wrong settings.
If this first attempt did not work, then as already state, the TV safety protection circuit is turning TV off to cause further damage.
Common reasons for TV turning off after 15 20 minutes are overheating, or overvoltage from one of the boards or of the ICs.
With no diagnostic code (eg. blinking code) it is impossible to troubleshoot in detail from here.
As said you need a technician to fix this.
You can call the phone number listed in your owner manual, call a local TV repair, or tell us your city and get a repair phone number in your area.
  • 1 more comment
  • Ginko
    Ginko Aug 30, 2008
    I did not find your model number, if screen picture went down with a popping noise it is likely the lamp .
    This is not very difficult to replace, but the part is expensive.
    Here is an example.
    I did not find your model in the part list, provide all possible details on your model and we will give you right replacement.
    To replace the lamp you access the back of the tv, the procedure is illustrated in service manual that can be bought from part seller.
  • Ginko
    Ginko Aug 30, 2008
    Here are all your parts for your model
    Here is Pioneer replacements page
    The fault was a loud pop.
    This can be a short, the power supply or CRT has blown.
    If it is CRT, parts are over $500,
    if it is power supply it will be over $ 300 whole part or some technician work to fix it.
    If it is a short there may be no need to replace parts.
    It is worth to call a technician to have the job done. A call to diagnose the broblem usually cost $80 or so.
  • Ginko
    Ginko Aug 31, 2008
    You do not know what part to install until a technician test the TV, expert saying "the power supply module board" must ahave been just taking a guess.
    Master:
  • 763 Answers
Get some service on this one. a proffessional technician will solve this problem to be fix some hardware.
cheers
CHARCOIS
  • 435 Answers
Yes, it probably is tripping the protection safety circuit.
Try a hard reset to see if that will restore its functionality. Just unplug the power cord for 4 hours - the try it again. About a 10% chance this will restore it.
If the hard reset does not help the set will need to be diagnosed by a tv tech who can get inside and take voltage measurements and look at waveforms on the oscilloscope.
There are many sections of the tv that can cause such a problem and they are usually expensive to repair.
You will need a tv tech; it is not a home remedy type failure.
Thanks for your question,
  • 6,487 Answers
The clicking sound you hear is the ON relay that is going OFF. The power management system in the tv has a protection circuit which has the function of monitoring current from the various sections of the tv. If it detects excessive current it immediately sends a signal to the power management circuit to shut the set off or power down.
Do a hard reset - this will just make sure the power management system or the protection circuits have not gotten corrupted. Unplug the line cord for 4 hours. That will reset all the internal codes to factory defaults.
Hope that helps..........
  • Mark Gil
    Mark Gil Aug 30, 2008
    Open the set with your fist thing to do back, top, sides If you have the back cover off, using a long wooden (non-conductive) stick, probe around gently to see if you can find a place that brings it back to life. This testing is for loose wires, poor connectors, corroded pins, cold solder joints. that my be acting up.
    If the above two procedures provide no indications, then the set has something internally that needs mending. The excessive current that is causing the protection circuit to go into action could be from the high voltage section, the vertical or horizontal deflection amplifiers, the audio amplifier or the main power supplies. Unfortunately, it is impossible to know without a hands-on diagnostic. The most common is high voltage generator failures and/or deflection amplifier breakdowns.
    If still cannot figure out what is the problem tech it to a repair center..
    Good luck.........
  • Mark Gil
    The cost will be for a house call and repair labors. Maybe as much as $100 - 300 for repairs just an estimate...
    Genius:
  • 2,920 Answers
Your power supply went out get it to a shop they will tell you the same.
Pioneer Rear Projection TV problems
a 240 ac voltage appliance will run happily on 220 volts but ther is obviously a fault as the green spark was possibly a fuse blowing
ie main fuse as power is not reaching the tv
Aug 14, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
Tv went out after loud pop and has clicking noise does not turn on
If you have a Sony DLP, then the loud pop you heard is your lamp.  The lamps last approx. 4K-6K viewing hours.  Read your manual for replacement part number to reorder and very simple to replace yourself.
Apr 22, 2009 | Televison & Video
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
Dec 20, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer projection tv will not come on
Let me know if your question is un-answered in the other thread.
Regards
Aug 30, 2008 | Televison & Video
I heard a pop noise then picture went out. when i power on tv i get a red flashing light instead of greenlight in left corner of tv. I have a 2002 pioneer 50 inch plasma
The 'POP' noise was likely a capacitor saying farewell.
If you are able, AND confident with electrics - take the TV apart (UNPLUG)
These TVs are very heavily populated with Surface Mount components - I suspect that you will likely find - what looks like a small can (half a centimetre in diameter, with 'candyfloss' coming out of it..)
YES - You could get a replacement from somewhere like Maplin / Radioshack......
Replacement will work - However...you really need to establish WHY it went Pop, and get to the root cause (Excess power feed / drain)
Realistically - without sounding too negative . . other components would have also been affected but not necessarily killed.
Good Luck.
Aug 19, 2008 | Televison & Video
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Tv went out, made a pop sound and won't turn back on
Sounds like the flyback went out. Your set is a CTC195 you can get a replacement flyback for it at the following link. They also provide free instalation instructions and free on line tech support.
http://servicemanuals.vstore.ca/
Apr 30, 2008 | RCA P56950 56" Rear Projection Television
No picture
Bad IHVT ( flyback transformer)--need complete service
number off back for part #-----------Let me know...T.
Oct 15, 2007 | GE 46GW947 46" Rear Projection Television
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Electro Med Services...
