Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Cooktop wont unlock
Kenmore electric/gas range. I punched the self cleaning button and the cooktop locked and wont turn off.
  • dixiedinah Sep 20, 2008
    Yeah, I can't get the lock on the cooktop to turn off. And can't find my book.
  • Anonymous Mar 17, 2014
    kenmore electric range cooktop won't turn on
Press and hold that button for five seconds. Another poster gave me this solution in September!
Posted on Nov 01, 2008
Press and hold the "Top" button for five seconds. It worked.
Posted on Oct 27, 2008
Why is door locked and will not self-clean?
Hey Kimberly, thank you for your inquiry!
I understand that the door on your Frigidaire range is locked and it will not start a self-clean cycle, it is also displaying an error code of "F91". The "F91" error code means that the door has exceeded maximum oven door unlock time. This means you could be experiencing an issue with your door latch, control panel, or a miscommunication within the range. To clear out a miscommunication within your range you need to disconnect power from it for at least ten minutes. I hope that this information is helpful to you. -Matt
Feb 11, 2016 | Frigidaire Gas & Electric Stove/Oven/Range...
Oven door is locked out - Sears no help
      1. Step 1 Read the display on the electronic oven controls, where the clock and timer normally appear. If the display reads "CLN" while the "Door Locked" light is on, the Kenmore range is in self-clean mode. When the Kenmore range is in self-clean mode, you must stop the cleaning process before the door will unlock.
      2. Step 2 Stop the self-cleaning process by pressing and holding the "Stop/Clear" button for three seconds. The oven lock should disengage after three seconds. In some cases, a malfunction between the control panel and the locking mechanism prevents the door from unlocking.
      3. Step 3 Hold the light switch for several seconds if the "Stop/Clear" button fails to unlock the range door. Engaging the light switch for several seconds resets the entire locking mechanism and overrides the "Stop/Clear" button.
Jul 03, 2015 | Kenmore 30" Freestanding Electric Range...
I cannot unlock the cooktop on my Kenmore gas range. There is no lockout button, only Select Clean and Stop/Clear. Neither one of which unlocked the cooktop. There is a little padlock looking symbol t
I'm sorry, but the model number given in the question is either wrong or incomplete. Please check that model number. Usually, on Kenmore ranges, you can find the model # and serial # on either the left or right side of the storage or warmer drawer. Open the drawer and look on the frame of the range for a label. On a few ranges, the label is affixed to the frame between the oven door and the drawer.
As an alternative, please post a clear picture of the control panel.
Oct 20, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Older kenmore electric stove
You could try to restart and stop clean cycle. Otherwise unplug stove and remove back panel to access locking mechanism.
Jun 24, 2014 | Kenmore White Electric Stove
Managemylife com
From the manual:
To turn the Cooktop Lockout Feature OFF:
1. Press and hold (_ until "CLO" appears (Figure 3). Continue holding
until a second beep sounds (after 3 seconds). I_1will disappear from
the display indicating the cooktop may be used normally (Figure 4).
Note: Starting a Self-Clean cycle will automatically turn ON the Cooktop
Lockout feature. The cooktop will remain locked until the Self-Clean cycle
has completed and the oven door has unlocked. If a power failure occurs
after the Cooktop Lockout has been activated, you must turn OFF the
Cooktop Lockout feature before being able to use the cooktop features
again.
Dec 14, 2013 | Stoves Kitchen Ranges
After self- cleaning my Kenmore Gas Range, I have not been able to get the 'Cooktop Lock' light turned off! So while I can use my oven for baking I can't turn the gas on the top of my stove! I have...
This may be a silly question but, did you just try turning off the circuit breaker for a couple minutes to see if it resets itself when you flip it back on?
Nov 21, 2010 | Kenmore Kitchen Ranges
Dacor smooth cooktop lock light flashing... nothing works!
Hold the lock button down for 5 seconds to see if it will unlock
Jan 20, 2009 | Kenmore 78823 Gas Kitchen Range
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
How to Unlock the Cooktop?
The manual should tell you how to lock; do the same procedure to unlock. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
"Cooktop Locked"
We found the manual. Held the button down for 3 seconds and it turned off. Felt like idiots!
Jul 19, 2008 | Kenmore 78823 Gas Kitchen Range
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
222 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
