Question about GE WCVH6260F Front Load Washer
Clicking when drum rotates
Last night our 18mos old GE washer started clicking each quarter roation of the drum. Not a large load, nothing has been out whack at all....any ideas?
  • 6 more comments
  • chumphrey47 Aug 30, 2008
    I have tried to run without a load as well as moving the drum mannually yet the noise is still there. Any other help?
  • chumphrey47 Aug 31, 2008
    We opened up the machine and looked at the drain pump and couldn't find anything. The noise does sound like its coming from the outside of the drum but in the upper left of the machine, although I am sure that the accoustics are not necessarily going to give a true clue to where it is.
    Does anyone else have any ideas?
    It's not a thumping, its a clicking. In addition, the load was not heavy when it started and the noise is still there while its empty. Thanks though....
    How would I check the motor pulley?
    Thanks for the suggestion, where would this belt be and how do I find and access this? I am worried of damaging the machine while takeing the outside panels off as well.
    I was already on that site with no help, thanks though
    I want to thank everyone for their help with our clicking noise...while I did not think that the drain issue was the problem from all of your posts it sounded like a future problem so we went through this and found a fist full of change. The clicking noise was still there so we opened up the back and looked...the belt was on and in great shape...the noise sounds like something got caught between the drum and then plastic tub around the drum but we couldn't access...after just pushing and pulling on the drum in many different directions and trying to feel around the water seal in the front of the drum with no real cause found...the noise stopped. We have no idea what caused the problem or how we fixed it but our washer seems to be fine for now. So THANK you all!
    Thanks so much!
    Genius:
  • 1,665 Answers
Remove covers and check drum support springs and hinges to be in place.
Posted on Aug 31, 2008
  • 2,071 Answers
It sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the machine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys.
Hope this may help;
Regards,
VOTIT
    Master:
  • 521 Answers
Www.applianceaid.com
the above link will guide u to solve your problem.
please do rate the solution,
thanks.
regards,
fixya expert team
    President:
  • 1,952 Answers
Every washer ll give noise after a year..its because of motor pro...coil may be affect for long run...load or no load are not apro of this noise..if it happen again..just switch off everything and run ur washer ...intially it wont make noise..but after the motor runs at certain rpm..it ll make noise...try ti chek ur motor coil and shaft connection..noise wont damage ur ur washer...don worry..
    Brigadier General:
  • 6,966 Answers
May I offer an alternative possibility...
Check the belt, it is possible that though not cut, there is a loose piece/slice along its length that slaps on to any of the other components.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Genius:
  • 1,847 Answers
The motor is suppose to move freely.
Check the motor pulley it may be melted.
Posted on Aug 30, 2008
    Genius:
  • 1,142 Answers
If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
    Genius:
  • 3,422 Answers
HI,
The problem most likely is something stuck in the water port of the drain pump. My machiine would not empty once and I found a 12 penny nail that had made its way from the drum though the drain line to the the pump, where it was wedged against the impellers that spins to draw out the water through the pump. The pump is located in the front right bottom of the machine and accessible by removing the lower front panel, It is held in place by 4 small screws and is connected to the drain lines. Disconnect the plug for the outlet, then disconnect the power connection from the pump. Disconnect the drainlines after removing as much water possible from the drum as the water will come out of these liines when you remove them. Remove the pump, open the cover to see the impeller and hopefully the bobby pin, nail, screw, or whatever else is stuck there will be visible and easily removed. Put the pump cover back on, replace the drain lines and screws, and reconnect the power connection to the pump. Then do a better job checking your pockets.
  • GE Master
  • 19,396 Answers
Try running for a short time with no load, it looks like you have a foreign object stuck inside.
  • Ginko
    Ginko Aug 30, 2008
    Check the water port of the drain pump, often you find small coins and other object there, if it is not there then the object is stuck in the trap that is located between the tub and the basket.
    To access the trap you need to remove back panel and open the tub, this job is better done by an expert.
    If you want to do it yourself we can provide more details no the problem.
    Start fist checking the drain hose, if you need to call a technician there is a number listed on the owner manual.
    Regards
  • Ginko
    Ginko Aug 30, 2008
Kenmore HE2 problem
Blocked filter/pump probably,,,won't spin unless water been emptied out
Jun 17, 2013 | Kenmore HE2 Plus Front Load Washer
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
My GE front load washer is thumping when the washer basket is at a specific spot in the spin. It sounds as if something is hitting in between the washer basket and the drum at the lowest part. I can turn...
first watch the drum as you rotate it,if it runs out of round,its not the bearings,but the spider on the back of the drum that holds it on the drive spline,if you notice strips of plastic in the pump this is a good sign of a bad sapider,dont use as if this shatters it can throw the tub out,call g.e. and get a recall on the tub,i got a customer a full refund on a g.e. like this and a new washer call them dont use for your safety
Jan 01, 2011 | GE WSXH208A Front Load Washer
GE top loading washer Washer wwse5200- Agititation?
it is a "trany" problem...just buy a new washer or it is a plastic cap inside that spiral part, that cap have groves...it is maybe goes bad....
GE as a brand has a lot of problem with washers, dryers, microwaves and fridges...and dishwashers so try to stay away of repairing or buying a new GE....
Sep 05, 2009 | GE WWSE5200B Top Load Washer
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
Changing the belt on a GE front loading washer
Hello , i can try to help , I have always got these belts on by starting the belt on the small pulley/motor , then rolling it on the large pulley , kinda like putting a bike chain on. Let me know if you have any other questions and how it turns out.
Phil
Jan 07, 2009 | GE WSXH208A Front Load Washer
Washer does not wash or spin
the electronic module who drives the motor its the problem . you can order and replace find part at partstore.com go by brand and model let me know if you need more help thanks
Jun 20, 2007 | GE WSXH208A Front Load Washer
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
GE WCVH6260F Front Load Washer Logo
132 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
