Question about Toshiba Satellite A60 Notebook
Laptop does not boot....invalid system disk...
I had my Toshiba Satellite for repair because the operating system failed. When I got the laptop back, I wanted to re-install the driving system by using the product recovery disk (Vista Home Premium). But the Laptop does not react, i.e. it does not read the recovery disk.
What to do?
    Genius:
  • 2,028 Answers
Is it just the recovery disc, or is it all discs?
Posted on Aug 30, 2008
How can I fix reboot and select proper boot device or insert boot media in selected boot device and press a key on Toshiba satellite C55D-B5308
A number of things can cause this:
1- Your Hard drive is\has failed (meaning, the the computer can't read the Hard drive)
2- The OS (Operating system) is not installed\corrupt.
3- There is a disk in the CD-Rom and your laptop is set to look at the CD-Rom for a OS
Some suggestions:
1- Replace hard drive
2- Try reinstalling the OS or doing a "repair" (Turn off, then back on, press F8 while it's booting up until you get a safe mode screen, chose the option to repair)
3- Check your BIOS settings (Press F2 or delete while booting it up)
Nov 19, 2017 | Toshiba Computers & Internet
Toshiba laptop restarting
The loop on your Toshiba Satellite laptop refers to the computer not booting properly.
During the loop, the computer will try to boot the Windows operating system and keep restarting over and over again.
This is not a hardware issue with your Toshiba Satellite A106.
The issue resides in the startup files on your computer's hard drive.
You can fix this by running a repair tool that comes with your Windows operating system.
This repair tool will fix your startup disk and allow you to get your computer back up and running.
Insert your Windows 7 installation disc into your computer's optical drive.
Start your computer and wait for it to boot from the install disc.
Choose your language from the menu and then click the "Next" button.
Click "Repair your computer" from the menu.
Choose the operating system you are using and then click the "Next" button.
Click on the "Disable Automatic Restart On System Failure" button to disable the startup loop.
Click the "Startup Repair" tool from the menu and wait for the computer to fix your startup disk.
Wait for the computer to finish repairing your startup disk and then allow it to restart automatically.
Wait for the computer to boot correctly to your login screen.
Hope this helps
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
Oct 23, 2012 | Toshiba Satellite M35X-S311 Notebook
I have a Toshiba laptop with a Windows 7 operating system AND A BLACK SCREEN WITH AN ARROW(curser) ON IT
Try running the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 21, 2012 | Toshiba Computers & Internet
My tosshiba satellite A665-55186 wont go in to windows boot, what can i do??
Just like other computers, your Toshiba laptop may start failing to boot the operating system completely, or may fail to boot up at all. Boot problems are caused by virus infections and issues related to hardware and software. With the proper troubleshooting techniques, boot problems can be remedied to get the laptop into good working condition.
1. Perform initial hardware checks. Ensure that the laptop has enough battery life to boot up. Charge the laptop using its AC adapter and then try to boot the laptop again. If nothing happens, plug the AC adapter into another power outlet. If this does not help, check to see if external drives (flash drive, external hard drive, etc.) are connected into one of your USB ports. Unplug it from the laptop and press the laptop's power button. If the laptop powers on but fails to load the operating system, proceed to the next step.
2. Ensure that the hard disk is not disabled in the boot sequence in your BIOS. Otherwise, the laptop will fail to fully boot the operating system. Reboot the computer and press a key that will lead you to the BIOS page. Set your hard disk as your "first boot priority," or first in the "boot sequence." Note that the steps on loading the BIOS as well as navigating throughout the BIOS pages will depend on what brand of BIOS is installed in your laptop.
3. Choose boot to the "Last known good configuration" if you get an error page before the operating system boots up. If after choosing this option the computer reboots again, choose "Start Windows Normally," if this is in the list of options.
4. Consider repairing or reinstalling the operating system if the computer still fails to boot after the steps above. Repairing the operating system will retain your current data and settings. Reinstalling the operating system means reformatting or deleting all data in your computer and installing a fresh copy of the operating system.
I hope you find it very helpful. Best regards from fixya
Aug 15, 2011 | Toshiba Satellite A660 Series Notebook
A disk error occurred now i'ts on the bios and won't boot program
A disk error means your hard drive has failed. You will need to replace it. This model laptop uses a Serial ATA model drive.
Your operating system that boots the laptop is stored on this drive.
Mar 25, 2010 | Toshiba Satellite L35-S2366 Notebook
Formatting problems.
Remove any 3.5" diskette from the diskette-drive in the computer.
Insert the Recovery Disk into the CD-ROM device.
Restart your computer, and *FORCE* it to *FIRST* try to "boot" from the CD-ROM drive, rather than trying to boot from the 3.5" diskette or from your C: drive.
Nov 26, 2009 | Toshiba Satellite A75-S226 Notebook
Toshiba Satellite 1800 Disk Drive Problem
There's an issue with the way yout laptop is booting, either its set to the incorrect boot device or windows cant properly access the hard disk. Take it into a PC repair centre.
May 17, 2009 | Toshiba Satellite 1800-S253 Notebook
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite
Even when booting from the WIndows CD and pressing " R " to repair? Then going to the recovery console?
Jun 04, 2008 | Toshiba Satellite A15-S127 Notebook
Laptop windows root exe file problem
it is saying no kernel is found in the boot path,, this either means the boot path is damaged or the file is missing,,, place the restore disk in and recover your operating system,, or you can put an operating system disk in and try and repair the operating system
Jul 10, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Toshiba Satellite A60 Notebook Logo
184 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
