Question about Philips Magnavox 51MP392H Rear Projection Television
62 inch philps magnovox faded
I have to turn up brightness to see picture but now picture is faded/blurry, could it be a bulb?
    Genius:
  • 1,139 Answers
I would suggest that you check the HV output first this could be a sign of a decrease in HV and or a focus problem. Check the trippler, The IHVT, and the focus block (this is usually attached to the IHVT). Then I would check the actual CRTs (items to check: filament voltage, HV at the HV anodes, and screen grids of the CRTs). If you do not have a background in electronics, I would suggest that you have a qualified TV technician examine your TV set.
I hope this helps
Thank you,
Shuttle83
Posted on Sep 20, 2008
Why has the picture on my samsung 62 inch dlp been getting increasingly darker
Projection bulbs provide a high-intensity light. Most have an approximate 2000 hour life. This can vary greatly depending upon factors such as how often you turn it on and off and how often and how well you clean the filters. As the bulb begins to reach its life expectancy, it will start to get dimmer. A 2000 hour hour bulb, if it reaches that time frame, is expected to be putting out 50% (half) of the brightness that it did when new. It may simply be time for a new projection bulb.
Sep 03, 2014 | Televison & Video
Our picture suddenly changed drastically from a clear sharp picture to a blurry, faded looking picture. Some colors are extremely bright, others are faded out. It is so bad it is not viewable.
Please check the flat cable connections between TCON board and the LCD panel. If this is ok, then it is either the TCON board or the LCD panel itself. Good luck.
Jan 02, 2014 | Samsung LA Televison & Video
The color is kinda faded an blurry (sorta) its a 50 inch JVC projection TV..... i have tried to go into the menu screen an change the color the brightness an all that but when i do it doesnt change it...
Well, the bulbs can be up to 260 dollars per lamp, depending on the TV and if the bulbs are separate.It's not very hard to change them out if you have a little experience in taking those types of items apart, but I would definitely look into it.
Apr 05, 2011 | JVC AV-48WP30 48" Rear Projection...
I have a faded picture on my Magnovox 55 inch
You can get the service manual at
www.servicemanuals.vstore.ca
If the color are dim you most likely need the phillips coolant kit also available there which contains the CD with instructions.
Jan 01, 2010 | Televison & Video
Picture is still faded and new light was installed
HI,,
INCREASE CONTRAST OR SETUP CONTRAST ,BRIGHTNESS IN EQUAL POSITION..
TNKS
RABBANEES
Nov 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Panosonic 50" LCD 1080i HDTV screen picture faded
try setting your menu;s to adjust the picture settings
Aug 23, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
RCA 52" HDTV DLP tv
suspect the optical engine as the culprit. they can gather dust contamination internally and cause a "faded or washed out pic"
Apr 09, 2008 | RCA Scenium D40W20 40" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
74 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
