Question about Sony Mavica MVC-FD95 Digital Camera
FD-95, F-stops & Strobes?
I have a FD-95 and am working with SP 3200 strobes with light boxes and umbrellas with 100W modeling bulbs. If I want to use a small F-stop like F-11 with out any exrtra flood lights there is not enough light to see the subject in the view finder. The 3200 stobes at the lowest put out too much light to work at auto setting or the lower F-stops. Is there a way to set a small F-stop and have good light in the view finder like at F-2.8 ?, with out adding floods or moving the strobes further back than 10 feet ? Changing the shutter speed does not help as it has the same effect in the view finder. The rear lcd screen can be brightened a bit but not the view finder. Any suggestions besides a more expensive digital camera ? (D-1, Minolta 3000CR etc...) Thanks for any help in advance. Well its off to the Studio to Play with my toys.
    Master:
  • 551 Answers
You might try adding an external view finder that is close to the FD-95 picture size. A lot of old cameras have them and it could also be used for sports as well, it could be added with Velcro or some other type of mounting. I am working on this problem myself. Good luck
Posted on Sep 11, 2005
My hunter cieling fan liht strobes ;what is causeing this ?
Make sure you're putting in the correct wattage.
Sep 15, 2014 | Dryers
Shooting in a studio with flash, frame 1 is exposed perfectly. Frames 2-12 severly underexposed if any image at all. This has now happened twice.
How fast are you popping off shots? Be sure you're allowing time for your strobes to recharge after each photo. Also, depending on your lense, there is a switch for X and M sync, X is for electronic flash, M for old flash bulbs - if you've managed to slip it off of X to M you'll get no use of the strobes. It's also possible that your sync cord has came unplugged or loose from the PC socket or the strobe/power pack itself, or that the cord is simply bad (it happens frequently) - try a new cord. But, be sure you're allowing 2-3 seconds at minimum for your strobes to recharge unless you're somewhere you're sure they're setup and able to cycle faster.
There is nothing electronic in this model to go wrong, including the lense, so whatever is wrong is either in a user setting, or in equipment from the cord on.
Jul 14, 2011 | Hasselblad 501CM Medium Format Camera
TV IS BLINKING LIKE A STROBE LIGHT AND WONT STOP EVEN IF I UNPLUG IT AND TRY IT AGIAN
Please make sure any device that is connected to the tv is disconnected.
Unplug the tv for 2 minutes. This will ensure all mechanics in the tv are given enough time to reset.
Plug it back in.
If the tv still strobes let me know.
Nov 20, 2010 | Proscan 42LA30H 42 in. LCD Television
Pentax K110d flash trigger problem, I have 2 flash trigger strobes set up and a flash on the hot shoe of the camera, but with shutter release the trigger strobe lights fire but do not show in the pic, only...
Your camera uses a PTTL flash system. That means the flash on the camera fires a "pre-flash" to set the exposure and then the main flash. Your flash trigger strobes are reacting to the pre-flash and firing before the shutter activates. This all happens in a millisecond.
Oct 25, 2010 | Pentax K110D Digital Camera
Pitch and Strobes
There is nothing wrong with your turntables. The Strobe dots are only a guide to give you an idea of the speed your platter is rotating. Nothing more, nothing less. The pitch control decal is not 100% accurate, it is simply a guide to tell you where the 6% position lies, 3.3%, etc.
As long as the quartz lock function works, and the large middle strobes are nice and solid, and do not move, your fine.
You can check out these videos for more insight into these wonderful turntables:
http://www.DJPROLAB.com
- Optic
Digital Analog Therapy
www.repairny.com
www.1200s.com
Sep 19, 2008 | Technics SL-1200MK5 Turntable
I cant use dsc h1 with strobe light
If you problem is that the double flash triggers the strobes early (on the first flash and the shot is made on the second flash - dark) you either:
1. Get a wire accessory to command the strobes
2. Put a simple external flash on top of the camera and use it to trigger strobes. If you don't need the light from this flash just point it up of backwards, it will still trigger the strobes. If it does not rotate, you can use tin foil. A very simple external flash will do, as the camera will flash only once with external flash.
Jan 09, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Canon D60 not focusing when hooked up to studio lights
1) Being connected to your studio lights is interfearing with the camera's electronics, disturbing its ability to focus. Does it focus if you're not actually connected to the studio strobes, but are trying to focus using just the modelling lights? 2) There may simply not be enough light for the camera to focus. Canon sells a red LED AF illuminator that sits in the hotshoe (can't remember the part number). That may help. Also, if your modelling lights are set to "tracking" or "proportional", try setting them to fixed full power. You've probably got the strobes set several stops lower than full power, so "tracking" modelling lights rob you of several stops of focusin light. Or try a faster lens.
Sep 14, 2005 | Canon PowerShot EOS D60 Digital Camera
My exposures come out inconsistent
You cannot use the E-10/20N in Program Mode with studio strobes. Studio strobes are not compatible with TTL (Through The Lens) metering. You will need to set the Mode Dial to Manual Mode. Exposure is determined by flash output , ISO and the distance from flash to subject. Proper exposure can be determined with a flash meter.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Sony Mavica MVC-FD95 Digital Camera Logo
64 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Syzys
Are you a Sony Camera Expert? Answer questions, earn points and help others
