Question about Kodak EasyShare C633 Digital Camera
Pictures are green and pink
Every time I try to take a picture, the background is green and pink. I have all the settings on the correct mode and am unsure how to fix this.
    President:
  • 423 Answers
Looks like the CCD (image recording chip) has quit working. There is a lot of information regarding this phenomenon available at this link http://www.imaging-resource.com/badccds.html . The problem was widespread and affected almost all camera manufacturers. It does appear that most affected cameras are in the 3-5 year old range. The problem seems to have been rectified within the industry.
Posted on Aug 30, 2008
Pictures appear pink on camera screen and when downloaded to computer-what would cause this?
Perhaps you did select a SCN mode, with the main dial. Or chose a wrong white balance setting. Please switch the camera to the green loge on the main dial (auto mode) and check if that gives a better result. Start experimenting with other settings when you have a little more experience with the camera. Auto will give perfect pictures in 99% of all shots.
Jul 26, 2014 | Kodak Easyshare C813 Digital Camera
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
My daughter just got an apple ipod touch 4th generation 8gb and we are trying to set a photo to her ipod as wallpaper and it shows that it saves but when she goes to the home page it is not there in the...
Hi idiehl271...
To use any picture for your background you must have that picture installed in the Ipod.
To install a different picture as a background picture do the following:
1...Turn on Ipod
2...Touch "Settings"
3...Touch "Wallpaper"
4...Touch the arrow in the middle of the window, next to the current wallpaper
5...Select pictures from "Wallpaper",Photo Library, ect.
Please take time to rate me
Aug 23, 2011 | Apple iPod Touch 8GB 32GB 64GB 3rd...
Our Canon Power shot A95 is used to take close up photos of jewellery ,with a white background.We have been useing the TV mode with the MF to focus.Howerev the pictures are over enposed, what can we do to...
Instead of shutter priority "Tv" mode, try setting to program "P" mode instead. Also, turn off the flash, and set to macro if shooting close-in (press downward on the little flower icon on the back disk). If pictures come out blurry, try using a tripod to hold the camera steady, or set the camera down on an object so it doesn't move while taking the shot. Try using the timer to activate the shutter to allow the camera to remain even steadier for the shot.
Feb 13, 2011 | Canon PowerShot A95 Digital Camera
Pink sky in background.
Try and use the SCN. Mode.
Bright light is never recommended for any pics.
Contact KODAK they might have more ideas or can arrange a repair for you if needed.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 25, 2009 | Kodak EASYSHARE M1063 Digital Camera
Ryobi tek4 camera takes pink pictures and pictures look grainy. Anything white turns out bright pink in photo. Flash memory was reformatted to try and solve problem. Nothing improved. Camera is new. Is it...
You have to go to Menu and set up the Scene Mode as "Night Portrait" instead of "Default". Unfortunately you will have to do this every time you turn the camera off since it does not remember the change
Jul 13, 2009 | Cameras
Bad picture/colours on Samsung LCD TV
loretta change your power pack
entwined  try another cable
Aug 21, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Green Pictures
Depending on the tv that you have and how the image is translated on the screen can cause problems some times tring diffrent settings on you camera can make the image look better. Try setting the camera in indoor or firework mode. it helps on my TV.
Mar 24, 2008 | Kodak EasyShare C633 Digital Camera
Pictures appear with a pink background
I had the same problem with the Canon PowerShot S410. I called Canon and they said it was a known issue. They are going to send me a return, paid postage label and replace the sensor at no cost. Canon rocks!
Liz
Nov 11, 2007 | Canon PowerShot S500 IXUS 500 Digital...
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Kodak EasyShare  C633 Digital Camera Logo
64 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
