Question about Viking Kitchen Ranges
I have a VGR36 Viking Range. The ignition spark for each of the (4) top burners has stopped working. The stove does have power because the oven light works. I can also light each of the 4 burners with a match so the gas valve is working and releasing gas but no spark. What would make the (4) burner spark iginitons stop all at once?
  • 878 Answers
SOURCE: Viking Range
Juliac, the burner valve switch for that burner is either shorted or grounding out. Each burner control has a valve switch that controls the power to the igniter. Sometimes they just get full of gunk and short. Part number is PA020015. back.
Posted on Nov 10, 2006
  • 288 Answers
SOURCE: Viking stove top gas burners
When you say plug I'm assuming you mean the outlet in the wall. And you checked it for 220 volts with a meter? If all this is good then maybe you need a new ignition coil. I need more info.
Posted on Nov 05, 2007
  • 288 Answers
The clicking is the electrode arcing. when the burner lights, a sensor tells the electrode to stop sparking after is heats up a little, that's why is clicks a little after the burner lights, but then stops. If the spark keeps going, the sensor is not registering the flame. The ones that do not click could be the ignite coil, the wire, or the electrode.
Posted on Nov 15, 2007
  • 5568 Answers
SOURCE: Electric spark for gas range burner is non stop
Turning any knob starts the spark via a switch behind each which should disengage when the (any) knob is turn further.
One of your switches is stuck.
I think you should be able to remove the range-top for access and find the offending switch.
It is probably gummy from a spill and is no longer in solid contact with the cam that operates it.
A solvent/lubricant such as WD-40 sprayed on the plunger of the switch once you can see it and operating the knob back and forth should free it up.
It might be wise to turn off the gas supply while tinkering with the range - blow your house away and the range won't matter. :-(
Posted on Jun 19, 2008
  • 706 Answers
SOURCE: ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
Nov 12, 2010 - Uploaded by
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ... > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
Viking range burners not getting gas
Each burner has to have verification of ignition from the spark ignitor. If all burners will not light I would say it must be the control. Here is your Viking stove manual
Nov 20, 2012 | Viking VGIC485-6G Gas Kitchen Range
My Viking oven will not lite, the igniter glows, but it will not lite. I have to turn on the 4 stove top burners and then it will lite. Also, when the oven reaches temperature and the therastat shuts it...
That sounds like you have too high of gas pressure which keeps the oven gas valve from opening...turning on the burners lowers the gas pressure enough to allow the gas valve to open. this is a saftey feature on many gas valves.
To stop that you will need to install a gas pressure regulator which will hold back the gas pressure so the valve can open.
Here is a tip that I wrote about regulators and them failing on the low side, but it will give you and idea what I am talking about and what you need to install in the line to your range.
Apr 22, 2011 | Viking 27" Professional Select Built-in...
I have a jenn-air stove The igniter went out on all 4 eyes on the cook-top
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
Dec 25, 2010 | Microwave Ovens
The ignition feature seems to have stopped working on the range and stove. I do ot have a manual for this unit and the exterior labeling does not indicate a model number. What steps should I take to...
as both top and oven quit at the same time
if the lighting mechanism was a clicker type you used to her a snapping noise
for the top burners ovens are normally a hot surface ignition or glow rod the first thing i would make sure the outlet has power all four burners on top use same spark module and normally oven is separate module or control each burner control provides power to module separatly when turned on and you can test voltage at spark module mormally located behind a cover on back of stove
caution modules are wired 120volt and you would need a tester follow cord from outlet to where it enters back of stove normally wiring is close to cord entry point
Dec 07, 2009 | Sears Kitchen Range
Viking 6 burner range that keeps clicking after ignition
Spark ignition sparks until the flame starts. The flame ionizes the air between the igniter plug and the burner causing the small current to flow between the igniter and the burner. This shuts off sparking. But if there is a gap such as in the spark igniter under the porcelain, technically there still is a gap that the current has to jump and thus the stove keeps sparking. In my case changing the offending igniter plug fixed the problem.
Jul 05, 2009 | Viking VGSC366-6B Gas Kitchen Range
I have a VGR36 6 burner. All the spark ignitors stopped clicking after a major boilover spill. Liquid got into the spark module compartment and caused a short. The paper wiring diagram under the spark module protective cover was burned from the short. I had a Harper 6542 non-reignition spark module but the replacement part is now a Tytronics PA020041 Spark Module. I bought kit #000511-000 from which includes the module, a black jumper wire, a green ground wire and an instruction sheet.
It's not difficult to replace the spark module but the 2 screws holding down the module toward the back of the stove are not visable and accessible. I used a thumbwheel rachet with a long philips screw driver bit (for cordless drills) to remove and replace the screws. The wiring was simple. The 2 power wires need to be wired to the correct polarity on the module, but the remaining 4 ignition wires can be wired to any of the 4 terminals on the new module. All the wires have plug in connectors and no cutting and splicing is necessary, but I had to cut and splice because one wire shorted and the insulation was burned from the major spill on my stove.
Nov 05, 2007 | Kitchen Ranges
Kitchen Ranges Logo
188 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
