Question about Brother CS-8150 Computerized Sewing Machine
Brother CS-8150 When I try sewing, the thred jamms up from the under and then a notice comes up saying "the safety lock has been activated.
    Problem Solver:
  • 16 Answers
When you say jams up from the under could you please tell me what exactly is jamming up. Is it the bobbin thread jamming? I've had the "safety lock" warning but I need to know exactly what you were doing. OK
Posted on Sep 15, 2008
My sister has gifted me a sewing machine. it's details are here--brother made in taiwan, 120v,60hz ac, 90w ,listed sewing machine ,ul 273c...i don't know how to use this machine..it is working with...
Hi
Manuals for Brother machines are usually available from the Brother site.
http://www.brother-usa.com/manuals/default.aspx?PGID=3
They have one for the CS-8150 but I'm not sure if this is your machine or if the model number is UL273C.
The manual for the CS-8150 is here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_8150_EN_183.PDF
The manual for ULT2001 is here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_ULT_2001_EN_200.PDF
Maybe one of them is similar enough to your machine.
Hope this helps!
Oct 28, 2010 | Brother CS-8150 Computerized Sewing...
My bobbin winder stopped working on my Brother CS-8150. spindle locks in, motor runs, but it seems that the winder is slipping. Can this be adjusted?
I think that I would call Brother at 1-877-276-8437 and ask them if this is a warranty issue. They may have a quick fix for you.
Oct 24, 2010 | Brother CS-8150 Computerized Sewing...
Brother CS-8150 Problems with bobbin thread
Double check to see if the bobbin is in upside down and the thread is feeding from the bobbin spool in the wrong direction.
I did this once after several years using the same machine, some days are just not as easy as they should be!
Mar 04, 2010 | Brother CS-8150 Computerized Sewing...
Wanted a maintenace manual
i was able to fnd manual at www.ifixmachines.com
Jan 25, 2010 | Brother CS-8150 Computerized Sewing...
I need to know how to change the bulb on a brother ps 33 sewing machine!
Hi, thank you for using FixYa! I don't see a model PS-33, however; you posted in the CS-8150 machine section, the link to the manual for a CS-8150 machine is attached. It has a section for winding and installing the bobbin and another section for upper threading. If your machine is not the CS-8150, please comment with the correct model number (PS machines start at number 1450 and increment upwards). If this is the correct manual, would you please take minute to rate this solution? Thank you! Gregg
Mar 29, 2009 | Brother CS-8150 Computerized Sewing...
Brother CS-8150 Won't Work in Reverse
Look at the feed dogs under the foot see if they are raised high enough to pull the material through.
Nov 13, 2008 | Brother CS-8150 Computerized Sewing...
How do I disassemble my Brother CS-8150 to get inside to find a nut that fell in there?
If you or someone you know is mechanically inclined, you will need to take five screws out of the back including a hard to find one under the foot raising lever (lower the foot), then one form the front that is under the thread cartridge, and you will have to remove the bobbin winding plate cover which is held by one small screw, and then remove a small screw from the support bar.
Nov 10, 2008 | Brother CS-8150 Computerized Sewing...
Machine makes a loud noise and will not make stitches.
sounds like something is broken. best to get it checked out. take to the sewing machine doctor.
Oct 16, 2008 | Brother CS-8150 Computerized Sewing...
Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Sep 26, 2008 | Brother CS-8150 Computerized Sewing...
Brother CS-8150 Computerized Sewing Machine Logo
153 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
