Problem setting up new dvd
We have a Phillips TV (only 6 months old) and have just bought a Samsung DVD recorder, model 2500GB HDD.
(We also have Sky).
We have followed the instructions to the letter, but TV screen says: "No signal or bad signal connection. Please check antenna connection and position".
Any help wou;d be much appreciated!
This myron davis dvd for a 2005 ford f150 supercrew , the screen is saying no signal
Posted on Oct 31, 2008
Philips DVDR3450H. How format the HD?
Found a document DVDR3450H_3452H_3460H_eurp FWUpgradewk635.pdf Describes procedure of firmware update and disc formatting. Some cut'n'paste from the document:
2. Preparations for new HDD
In the event when the set unable to boot up or recordings not stored due to an defective HDD, the HDD will have to be replaced with the steps describe below:
1. Replace the Faulty HDD with a new HDD.
2. Before connecting the new HDD on the Digital Board ,the jumper pin at the connector of the HDD is to be removed.
3. Connect the new HDD to the Digital Board.
4. Power up the set . It will open the tray and prompt to load the upgrading disc.(the upgrade disc is
the same disc under firmware upgrading.)
5. The set will display
“Load”.
6. Put the upgrade disc and close the tray and the set will show
“Copy” ……… “Boot”
7. The rest of the procedure follows the software upgrade given in 1B -Procedure to apply the firmware upgrade.
*Note : 1)Do not press any button or interrupt the main supply ,otherwise the set may
become defective.
2)When the HDD formatting is successful ,the set will go to standby mode.
Jan 17, 2010 | Philips DVDR3450H DVD Recorder/HDD...
Use an HDMI cable from my LG DVB-T HDD/DVD recorder
A quick google search of that model number turns up that tv doesn't have an HDMI port. Your next option would just use component cables instead. At 26 inches you will never notice the difference.
Dec 23, 2009 | Philips 26PF9956 26 in. Television
Rec from hdd to disc
Only use one of the disc types that is listed in the manual that they have actually tested on unit. If the HDD recordings were made in HQ mode, then you will only be able to fit a one-hour or less recording on a DVD. You cannot reverse this at this point. For future HDD recordings, set the record mode to 4hr or higher.
Jul 20, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Hdd recorder / recording & watching cable channels
yeah actually that is kinda simple. Like the old vcr recorders you can just put a splitter between the cable (input) and your dvd hdd and your tv.
that is an easy 3 dollar solution
Apr 23, 2008 | Philips DVDR3575H/37
Samsung DVD-SH855 DVD Recorder 250GB HDD playback freezes
Samsung dvd sh-855 i have the same problem wiht freezes when recording on timer mode.Recording in timermode with TV on is OK. But only connected whit HDMI cable, Component is OK in all modes!!!
My recorder is a XXE model = scandinavian.
Do anyone have a solution Please
Apr 20, 2008 | Samsung DVD-HR720 DVD Recorder
Samsung DVD-SH853M HDD/DVD Recorder/Digital Receiver
Make sure you are not using DVD+R dics - the player won't play these. It is OK with DVD-R.
Jan 21, 2008 | Samsung DVD-HD950 DVD Player
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Fan doesn't turn off in standby
HAve you checked to see if it is the fan or the actual rom drive that is spinning, I had this problem, email me for any help chickyxr@optusnet.com.au
Nov 08, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Can't record from hdd to recordable dvd
Had the same problem on my 6month old 3440H, its the degradation of the cheap Asatech Chinese DVD drive that is the source of the problem. . My 3440H HDD to DVD transfer sequentially degraded, It stopped recording DVD+ and -R's then on RW's it sometimes performed and some not.I gave up using cheap DVD's then with higher quality disks  it would frequently report task completed but then would not plaback or freeze in the way you describe. I bought the DVDR from the CO-OP Xmas 2006. Co-op no longer support electricals so when it went wrong Co-op gave me a service centre to take it to. Long story short Philips dont recognise the service centre and they declared my warrany void. Tried to re-engage with Philips but they basically were not interested in supporting their product..
Not an elegant fix but since Phillips were useless,  I opened the box nothing ....to lose ..I now run it on a bare external Sony DVD drive using extended ribbon and power cables as its a bit tricky to find space in the box to mount the drive.
Regards
Murray
Oct 13, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
