Question about Nintendo Super Mario World: Super Mario Advance 2 for Game Boy Advance
Blue switch palace
Thanks for the advice but i've already done that for so many times and still i dont find any place to go next. i have already been through all the forest of illusion and i cant find the next way to pass through the blue switch palace. im left standing in the blue switch palace and nowhere to go. Please help me again. Thank you very much
  • 3 more comments
  • strawberrysh Aug 31, 2008
    Yes I've been to the Forest Ghost House, i've been wandering through all the forest of Illusion. i dont know how to go to Castle #5, i cant find a way to go there. Please help me. Thank you so much
  • strawberrysh Sep 02, 2008
    Please help me how to find/go to Castle #5. Thanks
  • strawberrysh Sep 29, 2008
    Thank you very much!
  • Anonymous Sep 30, 2008
    i can't figure out how to get the blue and green switch and i can't get to castle number 5
  • tazboy13rpg May 11, 2010
    Have you been to the Forest Ghost House?
    Have you been to Roy's Castle #5?
The blue switch palace is on the second way out of the forest of illusion 2 level
Posted on Sep 26, 2008
  • 28 Answers
When you get to the end of the Forest of illusion 3 it splits. Don't step off the pipe.
Enter the green pipe to reach a small cave area. Smash the yellow blocks with
the spin jump (this can be done with any Mario sans Small Mario) and grab
the Key and poop it into the Keyhole. This will then unlock a path to
'#5 Roy's Castle', and the proper way to go to continue the game.
Posted on Sep 02, 2008
Good morning,we have a 1997 polo fuel injector car and it just dont want to start.We`ve already replaced the distributer and still nothing.Someone please help :-(
have the fault codes read . there are a few sensors that control the starting of the car including the engine immobiliser.
Apr 05, 2013 | Cars & Trucks
Hi I've just got a Honda cb250n and there now
Hi if you havent already checked the fuse at the starter solenoide 30amp check it first. Next locate the rectifier this will have 3yellow wires these come from the alternator and provide AC voltage to the rectifier which is then converted to DC voltage used for charging the battery, at the rectifier you have green wire/s this is the earth and red wire/s this is the voltage in and out, it is here at the connecting block you must inspect the condition of the wires do not unplug the block simply check for oxidiseing which is visible to the eye and is green in colour, simply twist and pull gently on each of the wires to check for conectivity, if any break off you can bypass the block by removing the wire from each end .next it is not uncommon on the old 250n for the ignition switch to become faulty, using a test light if you dont have one make one up by removing one of your indicators, the coloured wire orange or blue depending on which side you remove is the indicator live wire, at the ignition switch using your test lamp check for 12 volts by placing the coloured wire on the red ignition wire your lamp should light if you have voltage here, if you dont have power trace the wire back and look for breakages in the wire, you could also run a new wire from the battery to the switch and with this connected the switch should opperate normaly
Oct 20, 2011 | 1972 Honda CB 250
Hello, i have a problm. with the reward from Summer Quest I . I complete the quest, and than i've been forced to refresh ( out of sync) and when i return to my farm and looked into the gift box,...
if you finished the game and then the out of sync pops out, try checking that quest again. maybe it is not saved so try doing it again. and if its already done, dont worry youpll see the reward in your gift box soon when the game server is already okay
Jul 19, 2011 | Zynga Facebook Apps
In the Rose of Athena game pencil not working in Buckingham palace to find Rose picture.
Buckingham Palace
London, UK
Level 1
  1. place the ladder on the two benches to the right.
  2. use the pencil on the painting.
  3. push the button and exit to next level.
Jul 04, 2011 | MumboJumbo Samantha Swift and the Hidden...
Hello guys, please only reply if you have a realistic solution. I have a JVC HM100 camcorder and I have recently attached a cheap wide angle converter. Since then, my trouble started. When I take it off,...
When was the last time you white balanced your camera? I can't say for certain, but it sounds very similar to a problem I use to deal with all the time.
  1. set the ND filter according to the lighting
  2. set the WHT.BAL. switch to A or B
  3. locate a place with similar lighting conditions as the subject, place a white object near the center of the screen and zoom in to fill the screen with white
  4. press the auto white balance button
I got all of this from the manual. starting on page 35. I hope this turns out to be it. Let me know how it works out!
May 10, 2011 | JVC GY-HM100U High Definition Camcorder
How do I activate the 'Ultimate Heist' Quest?
these are the steps to complete the ULTIMATE HEIST quest.
  1. After fencing at least 1000 gold in stolen items, the Gray Fox will contact you for a mission.
  2. Sneak into the "Imperial Palace Basement" and activate the Glass of Time to enter the Imperial City's sewers.
  3. Make your way through "The Old Way" and "The Lost Catacombs" to the "Hall of Epochs".
  4. Sneak through the "Imperial Palace" to the "Elder Library".
  5. After receiving the Elder Scroll, escape from the "Imperial Battlemage's Room" and return to the Gray Fox.
  6. Take the ring the Gray Fox gave you to the Countess of Anvil, Millona Umbranox.
  7. After details are revealed, accept the Gray Cowl of Nocturnal to become the new Thieves Guild Guildmaster and Gray Fox.
Oct 03, 2009 | Bethesda Softworks The Elder Scrolls IV:...
Blue switch palace
Blue Switch Palace: In Forest of Illusion 2, before the exit, go left and stay
at the bottom. When you do find this, you should see a Yellow "!" block. Hit it
and grab the Mushroom if you need to, and then head left. Grab the key, go left
some more and shove it in the keyhole.
Aug 21, 2008 | Nintendo Super Mario World: Super Mario...
Lcd tv Wharfedale 37 F1080P
everything fine got further advice, its a convergence blow out.
TV Already on its way back to shop, replacement already in place.
Although Im not holding my breath, I have heard that Wharfedale hav megga defects
And lots of people dont rate them. Thanks for the reply...Soulsister
May 22, 2008 | Televison & Video
Camera wont stay on
No it is a switching issue and is not going to get better. Kodak technical support will tell you more be prepared though -if you have had this for some time then the next camera purchase looms I guess
Nov 06, 2006 | Kodak EasyShare V550 Digital Camera
Nintendo Super Mario World: Super Mario Advance 2 for Game Boy Advance Logo
272 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
