Question about Ovens
Oven wont heat, shuts down in few seconds
Amana Elec Wall Oven ACOS3040SS, about 10 years old.
Checked power supply, have 240 and 120V across leads to panel..
Clock works, Conv Fan works.
Bake, Broil, and Conv all start, hear relays clicking, then oven shuts down with a click.
Xformer looks "cooked".
Worried because had a bizarre Electric Company Service issue, where they kept dropping 240 leg to my house over several months. No clue if my oven has low voltage cutoff, think my oven may have been operating and pulling higher current with this service issue.
I am an engineer, comfortable with a multimeter, could use a wiring diagram and expert advice.
  • jcliff1234 Aug 30, 2008
    ok. I assume I can measure resistance across that right? Can you give me a clue where the sensor is located?
  • jcliff1234 Sep 06, 2008
    Replaced sensor at advice of kevin. Same thing.
    Please advise on how I can check xformer under load.
  • 35 Answers
Should be the glow ignighter if ite worn or broken it will shut down everthing
Posted on Sep 06, 2008
  • 435 Answers
Should be an easy fix. If the hot surface glow ignitor (HSI) does not glow and all control selections and settings on the front control panel are set correctly, chances are the HSI is burned out.
Replacing the HSI part is likely to solve the problem. A very common part that burns out or becomes weak needing replacement. Reading a few of the existing questions pertaining to ovens with like or similar problems will explain how to replace the HSI. The below link will also provide helpful information.
Help Link: Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Site Links: http://forum.doityourself.com/showthread.php?t=159808
Retail parts dealers and appliances parts stores can also help determine what the possible problem may be based upon that specific brand and model. Bring the make, model and serial numbers. Dealers and appliances parts stores are listed in the phone book.
Additional Suggestions:
Read the manufacturers online web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, repair and or owners manuals which may be available online.
Cautionary Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Posted on Aug 30, 2008
    Genius:
  • 1,847 Answers
Sseem issue with the thermostatic.
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Gene
Aug 04, 2011 | Ovens
I have a Kenmore smooth cooktop electric range. It is about 3 years old. Recently i used the self clean function, and since then I can't get the oven door to unlock and I'm getting a F5 code on the read...
Press the "Off/Clear' button to cancel anything on the display, and reset the oven. This is a soft reset and will simply get you out of any program you have started. If the problem still persist,
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the oven back into the wall power supply to reset any anomalies with the oven memory.
Mar 02, 2011 | Kenmore Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Amana wall oven will not heat with new ERC
the heating element needs replacement.that the only solution.its common in this ovens as the heating element breaks down in between so it never heats up.
Mar 03, 2009 | Amana AOES3030 Electric Single Oven
Wont Heat at all
sounds like you have a bad wire connection someplace in the oven.
Dec 10, 2008 | Magic Chef 9815 Electric Single Oven
Double oven willnot light
Peace,
ngafm at your service,
It sounds like a bad igniter in that oven or a bad gas valve restricting the gas flow in that particular oven.
Unfortunately this will require hands on service!
How old is this wall oven?
ngafm
Please give me a good rating before you sign of!
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Sep 06, 2008 | Amana AOGD2750 Stainless Steel Gas Double...
OLD GE Wall Oven doesn't heat properly
On these older ovens ther is usually always 120 volts on the elements at all times.
If you check across the element ends with it in bake you should read 240V. If not, there is a problem with the control. With the voltage drop you describe, it sounds like you are losing power on one line of voltage coming to the element.
Post back to let me know what you find out or if you have any questions.
Nov 24, 2007 | Ovens
Oven not heating up properly
You could very well have an electrical problem. You may not be getting the full 220 volts needed to make the oven function correctly. Call a local appliance technician or electrician for service.
Dec 28, 2006 | GE Profile JTP56 Electric Double Oven
Ovens Logo
94 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
