Question about Marvel (6SBARBSG) Wine Cooler
Marvel Cooler/Fridge Light Not Working
I have a Marvel model 6BAR wine cooler/fridge. The light in the back (a 15 watt bulb) does not come on. I have tried two brand new bulbs but it didn't help. Any idea?
    Novelist:
  • 101 Answers
It sounds like the bulb is not getting power. There is a door switch that turns it off when the door closes...this may be stuck. There is usually an optional (depending on age) ON/OFF switch that overrides the light to be on full time. If the light will also not turn on with that switch then there must be a disconnected or broken wire either going to the light switches or going to the light socket from the switches. I hope this helps.
Posted on Sep 15, 2009
Marvel 6BAR6004 not cooling
check you themoistat it may be coated with sofa
Jul 04, 2014 | Marvel 61WC Wine Cooler
I have a marvel wine cooler that frosts up and also tends to have temperture issues. Bottles on second shelf freeze. Temp adjustments to less cold make it too warm.
you have a restriction in the cooling side sounds like the filter line dryer is clogged up and will need to be replaced. Also the system will have to be recharged by a professional check to see if its in warranty.
Dec 17, 2010 | Marvel 6BAR Wine Cooler
Marvel 6BAR light does not illuminate. The bulb
More than likely your socket has a bad connection (probably the ground). There are two switches that can send the socket power...the door activaed switch and the manual override (ON/OFF button in the toe-kick). If you turn on the manual switch and the light is steady, then the door switch is bad. Otherwise I would trace out the connections on all the switches and on the back of the socket.
Dec 10, 2009 | Marvel 6BAR-BD Beverage Cooler
My light for my marvel wine fridge will not turn off?
There is also a light override ON/OFF button next to the door switch to allow the light to remain on for display setups. Make sure that switch is off. If it is off, then your door switch must be shorted out and should be replaced.
Jun 18, 2009 | Marvel (6SBARBSG) Wine Cooler
Refrigerator 50degrees; freezer 10degrees suspect fan outage/ge
I bought a wine cooler but I want to change the door I would prefare the door frame to be black
May 26, 2009 | GE Refrigerators
Marvel 6barbd undercounter fridge
marvel 6sbar-BD with wine storeage racks on the bottom and two glass shelves above. If I put sodas on the top shelf they expode. I have it on the lowest setting. Please advise.
Dec 22, 2008 | Marvel 6BAR-BD Beverage Cooler
I have Marvel 6bar beverage refrigerator that suddenly stopped cooling- any suggestions on how to fix- I am trying to avoid paying a couple hundred dollars for repair thank you for your time
If light work but not running at all, then change the temp control (thermostat). If compressor and condenser fan motor are running but not cooling, then you have sealed system problem
Dec 01, 2008 | Marvel 6BAR-BD Beverage Cooler
Wine fridge light does not turn off
You may know this already, but for what its worth. There is a small switch on the bottom vent grill for on/off of light. Check there first.....
Nov 27, 2008 | Danby Silhouette DWC512BL Wine Cooler
Haier Wine Cooler
Hi LinnieMcAdam,
I'm Harvey the Master Plumber.
Your question is: Where can you find a 10 Watt replacement light bulb for your Haier Wine Cooler?
I usually have success at the hardware store. Start there. Then you can try the store where you bought it or call Haier.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Refrigerators
Marvel (6SBARBSG) Wine Cooler Logo
223 people viewed this question
Top Marvel Furniture Experts
Sal De
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
Are you a Marvel Furniture Expert? Answer questions, earn points and help others
