Question about Asko Washing Machines
My Asko washer 10504 is working but it is missing out parts of the programme like rinsing. I have checked the outlet pump and there is no blockage there. Any ideas..perhaps the circuits?
    Problem Solver:
  • 6 Answers
Check the strainer in the drain pump
Posted on Aug 30, 2008
My asko regardless of selected wash program stops after the main wash, it will drain the water, but then not start the rinse cycles. The washing machine will allow you to open the door. I thought it was...
When your rinse cycle does not work it is your outlet filter that is clogged. If this is a front loader the small door is in the bottom front side of machine. Be prepared for some water to come out when u open the door. Unscrew and clean out filter and refit.
Also please note
with the Asko there are several possible things that can interupt the cycle either during wash or drain/spin. Have you checked the pump insert/button trap for debris or obstruction of any kind ? ( below main door to the left ) Are you using "he" ( lo-sudsing ) detergent ? Does the machine provide any error code, i.e. If it's a mechanical timer model does it stop at "C" or "S" or if electronic a symbol in the display ? Will it complete a cycle without any items in the basket ( empty ) ? Will the unit rotate in both directions and will it spin if you try both parts of that specific cycle ? This will help determine if the problem is with the drive motor brushes.
Nov 29, 2010 | Asko W6021 Front Load Washer
Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Jul 12, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Overfilling fault
I believe the washer has had a flood type situation.there is normally a flood switch in the very bottom of the dishwasher right at the very floor,if water get into the bottom tray it floats a piece polystyrene foam wich triggers a little micro switch wich will run the pump continually & show Overfilling fault at the same time..The water in the tray needs to be mopped out with a rag or spunge so that the styrene foam can drop back down.The blockage you had may have caused this flood situation some how.The overfill fault was probably due to the washer not pumping out,So that may be ok now that you have cleared the blockage.hope this helped.
May 13, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
Front load washer, will not do final rinse
A lot of times it is the strainer clogged at the pump. Hope that helps.
Sep 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
My Asko W6441 front load washer F3 message
Hello. You said that you checked the drain line for obstructions, but did you check the pump? I would remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Check the pump for any obstructions (like the occasional stray sock) and check the pump impellers. Look for broken/missing blades and ensure that the impeller spins freely. If there are missing/broken blades or if you cannot get the impeller to spin freely, the pump is defective. You may have already done this, and if so I apologize. Anyway, hope this helped and best wishes.
Aug 28, 2009 | Asko W6441 Front Load Washer
Operation manual
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/10504-_E
I think this web site has a PDF of your manual. If not try to googe ASKO 10504 washer manual
good luck
Jan 30, 2009 | Asko W6021 Front Load Washer
Rinse cycle problem
if the water is still in the machine when it stops then yes there may be a blockage, if you can assure yourself 100% that there is not, then the pump should be faulty electrically, there is also the chance that the timer could be faulty, but check the pump works and there are no blockages or any objects are in any of the pipes, (remove them to check them) if blowing back up the pipe made it work, this confirms a blockage i have over 20 years experience in appliance repairs, double check what you believe you have checked before, it sometimes works, we all miss things sometimes
Sep 27, 2007 | LG WM-1485FHD Front Load Washer
Washer won't rinse
when yr washer does not rinse, it could be that your outlet is clogged. Ensure that yr outlet filter is free from any kind of blockage. Check this, it is a small door in front of the machine bottom. Plug off the wall & clean out, expect some water to come out when you open it. If this is not the case check out your outlet pump.
Sep 26, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Series 90 washer problem
i am a recently retired engineer of 20 years, this sounds like the outlet pump, maybe just a blockage, but could be a faulty unit, remove plug before checking, start with that and see how you go on, thank you, if this has worked rate me please
Sep 12, 2007 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
149 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
