Question about Haier hwr10xc6 Air Conditioner
Not cooling just feels like the fan is on.
*good morning....I been having problems with my AC it is not cooling & when it does decide to it blows out water . I seems as just the fan is working.
  • mkj1035 Oct 01, 2008
    My A/C is on the cold "A/C" setting but feels as though its on fan only mode; the air is circulating but not cold.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
HEY, sounds like it time for a full clean-up. Take the cover off and clean the drain ports, the filter in the front of the unit, the back inside coils, oil the fan motor, wash the front coils, ,, The water blowing out could be because its not leanning back enough, & the coils or filter is plugged and trying to **** air anywhere it can ,even thru the drainnage system! Thank-you-very-much!
Posted on Aug 30, 2008
Car blows heat driving cool idling
Could be the blend door under the dash. The doors direct air thru the heater core and out the vents.
Jun 25, 2013 | 1995 Ford Ranger Supercab
Ford focus 2006 engine overheating once ac swicth is on..
CHECK TO SEE IF COOLING FAN IS RUNNING.IF NO CHECK COOLING FAN FUSE AND RELAY.THE COOLING FAN NEED TO BE RUNNING WHEN AC ON BECAUSE AIR CONDITIONER PUT A LOAD ON ENGINE.COOLING FAN KEEP RADIATOR AND AC CONDENSOR COOL.FAN NEED TO RUNNING.
Sep 04, 2011 | Ford Focus Cars & Trucks
Have a 08 Ford Fusion SEL. Bought in May '10. Starting this summer, the AC seems to have been taking longer to actually come on when the car is started. The hotter it is outside (especially if the car...
First off is it manual or automatic climate control ? Single zone or duel zone ? It's probably the front blower motor speed control ! electronics .
Mar 09, 2017 | 2008 Ford Fusion
Air conditioner stop blowing in 2002 Dodge Caravan can feel cool air and vents when traveling down highway with ac power on. Just won't blow out
There is as blower motor resistor which is part of what makes your fan blow. So your fan isnt blowing but everything else works right? Thats what I would look @ first.
Jul 24, 2010 | 2002 Dodge Caravan
Ac system does not get cold
you should go to a mechanic and check the A/C if the freon id low it won't cool , some time at mornig it give you the semsation that is cooling but probably not..
Aug 01, 2009 | 1999 Volkswagen Cabrio
My fan isn't working
well there not enough data here to make a fairly good solution. but if all the fans are running! and no cool air then it is the compressor.
Jul 14, 2009 | Heating & Cooling
AC stops working when cabin temp reaches 109-110
indicates gas pressure and condenser cooling problems
check the condenser fan is working properly and have the gas pressures checked by gauges
check that the evaporator fins are clean and not blocked as ice build up will cause the same indications
Apr 07, 2017 | 1997 Audi A6
AC roof unit stops cooling after rain
No, the units are sealed and the rain should not have affected the system at all. I would remove the outer cover of the unit and access the capacitors. Your start capacitor may be bad. You can visually inspect this and tell if there is a problem. Small black relay on top of capacitor often burns out, if so, replace capacitor and relay. If this looks fine, then we need to start at the thermostat and work our way forward.
Thanks,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
2001 nissan altima limited edition
it is not engine thermostat.Your engine temp is normal right? doesnt sound like expansion valve. which is basically thermostat for a/c system. make sure your cooling fans are coming on and no trash on condensor this is in front of radiator.
Sep 08, 2008 | 2003 Nissan Maxima
HP PAVILION ZV 6000 SHUTS DOWN AFTER LESS THAN FIVE MINUTES
Is this on battery or power supply?
If on AC power supply, then it sounds like a heat related issue.
Make sure you can hear the cooling fan running and you may need to blowe the dust out of it with a can of compressed air.
Dec 31, 2007 | HP Pavillion ZV6000 Notebook
Haier hwr10xc6 Air Conditioner Logo
193 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
