I have a miele wt2670 which will not tumble dry, drum stays still and after 3 mins displays an inlet fault message, can anyone help?
  • bkmg1 May 16, 2009
    If your solution is free (no need to buy something) i will pay £30
How do I fix a Miele W 2653 Wasker.
Hi dear. You did not mention what fault code but regards rest of your information, I would say 3 factors play up with it.
1- Tacho generator or it's plug faulty on motor
2- Motor Carbon brushes worn out or
3- Power/control unit ELP151-KD faulty.
I can advised to contact your local Miele center to diagnose your machine.Thanks.
Mar 17, 2016 | Miele Washing Machines
How to fix Miele WT2670. No issue in doing the wash, but when it comes to drying, it seems to be stuck in the last 12 minutes . Then eventually the machine stops, but the clothes are still not dry
perhaps the timer has gone bad many times the washer does not spin out as fast as they should thereby making the dryer work even harder to dry the clothe completely .
Apr 06, 2015 | Miele Washing Machines
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
Miele tumble dryer
Maybe time to replace it. How can it be too much detergent? That would have the effect of lubricating the seals!
Mar 04, 2014 | Dryers
Water keeps filling up the drum and inlet light flashes
either the inlet water valve is bad and needs to be replaced or the controller for it is not cutting off the electricty to it, If you are going to replace something, replace the water inlet solenoid valve.
Feb 10, 2014 | Miele Washing Machines
My Miele T294C NOVOTRONIC TUMBLE DRYER KEEPS STOPPING AFTER A FEW MINUTES OF DRYING. I CAN SWITCH IT BACK ON IMMEDIATLY ONLY FOR IT TO STOP AGAIN. CAN YOU HELP?
Hi - it seems likely the moisture sensor unit is faulty, reason?
Well Miele dryers after you start up will actually try to work out the amount of moisture in the dryer, it will calcualte the time & temp required to correctly dry the load in the machine. I suspect the sensor is not functioning proper.
I will assume there are no messages or other indications or flashing lights on the right side of the knob - it would be nice to plug my laptop to it and find out for sure..
You have cleaned the heat exchanger unit in the bottom corner of the dryer, the filter in the door and the two on the bottom of the door opening..
Despite all of these I would lean on the faulty sensor as the most likely culprit.
You may have to locate the nearest Miele service agent to help you out...
cheers
Jun 22, 2011 | Miele Dryers
Does anyone know why a Miele diswasher will start to wash fine and then stop with the inlet/drain light flashing after a few mins? I looked at the pressure stat at the bottom of motor and when i blow in it...
hi,
you may have something rapped around the impellers of the circulation pump causing low water pressure. the unit will start and stop to try to clear the blockage. if the circulation pump is really jammed the inlet/drain light will light. it could be a faulty pressure switch but they are not common to fail.
Hope this helps
May 21, 2010 | Miele 24 in. G638 Plus Free-standing...
Miele WT2670 message on screen "waterproof system activated". How do I reset?
I've just had this fault on this model, Its caused by a leak of water into the tray at the bottom, which activates a sensor to shut the water in flow off and thus prevent a flood. The fix is as for a posting by halldor to a question about the w4146 - ie.
Turn off and unplug, drain by the filter plug, lean the machine forward - the water flows out the bottom, plug in and it should work.
You do need to establish the cause of the leak first. Mine was a draw cord on some trousers dangling out of the door, thus preventing a proper seal, the water dribbled down the front and into the tray. Miele stated it could only be fixed by their service mechanics - I'd have had to wait 10 days!
Jul 17, 2009 | Miele Washing Machines
Waterproof fault
I just received this error message on my Miele WPS 4146 (Waterproof Fault) Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
So here is the fix that worked for me.
1. Turn off the machine
2. Unplug it
3. Open the drain outlet and take out the plug.
4. Dry all the visible water with a cotton cloth.
5. Tilt the machine FORWARD and hold it until you see water gushing from underneath the machine.
6. Repeat this until you see no more water.
7. Plug the machine back inn.
8 VOILA no error message! I hope in your case :)
Jun 19, 2008 | Miele Washing Machines
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
489 people viewed this question
Top Washing Machines Experts
