My tv will have ok reception for a couple of minutes then it goes to the "white snow" screen until I turn it off and back on again. Any idea what might cause this and how costly is the repair???
  • wwriii777 Aug 30, 2008
    How is a part and labor more than the tv would be new? How do tv repairmen stay in business?
    Genius:
  • 2,920 Answers
The tuner is going bad probably about 300 to fix
Posted on Aug 30, 2008
  • Ronnie Houston Aug 30, 2008
    most problems with tvs are not something a novice can fix at home so you have to take it to a shop and they inflate the cost of parts and labor for people that cant afford it and then if you cant pay for the repairs they sell the tv
Turn on TV is snow white screen
Check your aerial connection.
Ifit is combined digital/analogue set put it back to digital, white screen used to indicate analogue reception. There is no analogue broadcasting here anymore, only digital. The option should be on your remote.
Hope this issue and you can resolve it.
Good Luck
May 29, 2015 | Televison & Video
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Video is snow. no images just lines and snow. the only menu that appears on the screen is the net command set up menu. after a couple of minutes the TV powers OFF no matter what i try. i tried pushing the...
A suggestion: try with the original Mitsubishi remote to do the soft restore: Menu, 1,2,3, enter.
BEFORE YOU RATE THIS SOLUTION LET ME KNOW WHAT YOU FIND.
SD TECH
Jul 05, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Oct 22, 2009 | Samsung DLP HL-P5663W 56" TV
80GB PS3 displays Snow/White screen during playback
Did you ever figure out how to fix this. We simply took our system and hooked it up to a different tv and it stopped. I personally think the problem is with the HDMI cable and wether the cable and the socket are connecting.
Aug 29, 2009 | Sony Playstation 3 (PS3) Console
Snow screen
yes! your right! its a cable connector problem.
May 24, 2009 | Televison & Video
It gives an excellent reception but only for a while
There is a problem with the tuner section. I would first suspect poor solder connections. If resoldering the ground connections on the tuner fails to resolve the problem, a replacement can be purchased for $38.40 using part number: 8-598-594-30
Dan
Jan 05, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Loses reception
Is it a water damaged phone or dropped?
May 19, 2008 | Motorola Mobility RAZR V3
Mitsubishi CS31305 TV turns on then goes to snow and then back on
snow basically is a symptom of weak signal.
as you say it becomes ok after 5 minutes or so there no question of any components gone wrong except loose or print intermittent
please check.
1  input weak like cable or antenna or loose wire from the source..
2  in tv antennae socket loose.
3  near tuner any thing loose or track loose.
4  cable wire might be old.
hope this will help.
Oct 09, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
