Question about Water Heaters
Hooking up Tandem Rinnai R94 LSi
Hi we need to connect our two Rinnai R94 LSi in tandem. DO you have a diagram on how it should be done? On a prior post I noticed you stated we would need a master controller or panel. Where do we find these?
Thanks.
Daniel Brown
dancbrownmd@yahoo.com
  • dancbrownmd Sep 02, 2008
    Thanks. Over the weekend while searching the net I found a technical web page from Rinnai and it had most of the information I needed including schematics. They have their own controllers integrated into the newer units and some you just have to use a link cable.
    President:
  • 1,263 Answers
You will find a master controler at a electrical lighting and hardware store you have to be specific with the model and voltage/amprage rating. they will give you a schematic with the controler. .............please rate this ........thanks
Posted on Sep 02, 2008
Rennai
TAKE OUT THE ELECTRODES AND EMERY CLOTH THEM TO A SHINE. THEY GET A BUILD UP ON THEM NOT LETTING THE BURNERS RUN AT THEIR FULL CAPACIATY.
Sep 09, 2014 | Water Heaters
How do I clean inside my rinnai convector 417?
The owner's manual at http://rinnai.co.nz/tradesmart/upload/files/productfile/portable_convector_rce417_operation_and_installation.pdf on page 10 says to vacuum both filters weekly. It also warns not to wait for the filter lamp to come on since overheating may occur.
May 03, 2014 | Rinnai Water Heaters
I do not have the user guide for my A.O.Smith EES52 - a 50 gallon electric water heater, so my questions is; are there one or two heating elements in the tank? If two, where are they located and which...
Your water heater has two heating elements. The Two elements work in tandem to bring the water up to temp. then the top element keeps the water at temp. Here is a >>> link
Aug 19, 2011 | Water Heaters
I have a Rinnai R75LS and have it hooked up to clean with vinegar. However the R75LS will not allow the vinegar to flow through. I have watched videos etc. and seem to be unable to get the vinegar to...
I'm assuming you heater will let water flow through and it's not completely blocked with scale. There is a motorised valve that needs to be open. Start with the heater connected normally and run a hot tap. While it is firing turn off the power, this will leave the valve in it's open state.Now connect up your heater to the vinegar supply; do not turn the power back on.
Sep 16, 2010 | Rinnai Webstone The isolator EXP tankless...
I need a service manual for a Rinnai Infinity 26 continuous flow hotwater system - REU-VR2626WG-AK Can you help me? Linda
I left Rinnai only about a year ago at a levle of State Service Manager. I had been asking for service manual for for many, many months. Basically as far as I am aware there is not a service manual for the WG. If you google Rinnai Infinity 26 manual you can get a PDF from the Rinnai NZ sales site but his dates baack to 2003. Unfortunately there are major changes to some of the components but it might be better than nothing. Just don't use part numbers, and you might find bits to check that now have voltage and resistance differences. Send a message to Rinnai complaining, I encouraged people to do so even when I worked for them!
Aug 26, 2010 | Water Heaters
Have 2 Rheem 50 gal NG water heaters in tandem. Neither pilot will stay lit. They are 17 years old and never had this problem before
the most common problem is the thermocouple being busted. If thats not the case then the gas valve may be busted but that isn't very common.
Eitherway this required the burner being taken out so I wouldn't recommend anyone to do this who isn't a proffessional.
Jun 23, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Hi, our plumber has hooked up a new infinity xr-26 but the existing remotes don't work. He says it's a simple 2 wire connection but ther's no cirrcuit
Check with Rinnai to see if the old remotes are compatible with the new heater. Might mean upgrading the remotes too but the wires should be OK. Double check that he has actually connected the wires to the heater. Rinnai in Australia recentyl changed the connection point for the wiring. I can help further with this if this is the issue (not sure where you are!)
Mar 07, 2010 | Rinnai Digital Remote Water Heater Control...
I am looking for a solenoid valve and sub-PC board for Rinnai 94 LSi tankless heater
There is a toll free number on the cover at the water heater.Call them and they will send you what you need.Or tell you where you can buy it.
Mar 23, 2009 | Rinnai Webstone The isolator EXP tankless...
INSTANT HOT WATER ISN'T HOT ENOUGH.
http://homeappliance.manualsonline.com/manuals/mfg/rinnai_corp/reuva3237ffu.html
http://www.houseneeds.com/shop/HeatingProducts/RoomHeaters/rinnai/rinnaimanuals.asp
Here are two links to get the manual for your unit. Since I don't have the model number for your unit, you can find this in one of the two links. If you have the manual, you will know if you are skipping a step or not. If you have done everything, then I would call Rinnai to find an authorized tech for your appliance. Hope this helps.
Mar 20, 2009 | Rinnai Digital Remote Water Heater Control...
Water Heaters Logo
665 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
