Unable to hold picture settings?
When i change the zoom settings in the general menu page it resets itself once i turn the tv off, so have to change all the time?
  • Anonymous Jan 20, 2009
    i have the same problem my tv will not keep the settings i gave it
    Problem Solver:
  • 5 Answers
Unable to tell what u r working on....but are you missing a "save" option b4 u exit your menu?
Posted on Aug 30, 2008
INSIGNIA NS 19E310A13 after setting channel favorites will no longer respond to any controls
go into the setup menu and reprogram the channels using the controls on the tv itself..if its more than 2 years old, get a new one..repair costs are more than a new set is..
Mar 15, 2014 | Insignia Solutions NS-19E310A13 19" LED TV...
Hisense tv troubleshooting
Check the tv menu settings...go to where you set the date and time etc... usually in the general section..
Look for timer or timers...turn off sleep timer, turn off power on timer and turn off power off timer...cheers
Feb 06, 2018 | Televison & Video
How do you tune in a sense 51 - 19dvdw tv to channels
First check your aerial.
If other devices such as PVRs or other TVs can receive a signal then the Sense 51-19 should be OK also
Turn on the TV.
Press the "TV/.AV" button until the letters "DVB" (Digital Video Broadcast) appear on top right of screen.
Wait until patterned blue screen is displayed and the message "No Signal" is shown.
Press "SYS MENU" 3 times
"General Menu" should be displayed with Language option in highlight.
Press the "CH+" button once to move the highlight to the "Reset" option.
Press the "TV/TXT-DVB MENU" (this has the letters "SET" engraved on the button itself.
The TV will mute and a sub-menu will be displayed in the top left of screen.
Use the "CH+" or "CH-" to scroll to the desired option.
Cheers
May 23, 2012 | Televison & Video
I replaced the lamp on my Samsung HLS5086WX/XAA DLP set. How do I reset the timer on the lamp?
I have a Samsung DLP HLN617WX/XAA. After turning off by itself, the three indicator lights were blinking... signifying a defective lamp. I've re-seated the old lamp several times with no change. I bought a new lamp and reset the lamp hours through the "service menu" with no change. My television is still turning itself off and still blinking the same indicator lights. What should I look at, next?
Oct 26, 2010 | Samsung Televison & Video
My FZ18 will not zoom. Stuck at wide angle. A msg will sometimes flash when first turned on...CAMERA WILL RETURN TO PREVIOUS ZOOM SETTING...or something like that. It functions otherwise. I have been thru...
Set camera to P mode.
Press [MENU ] to display the [SETUP] menu
and select the item to set.
The [REC], [CUST. SET MEM.] or [SETUP]
menu settings are reset to the initial
settings.
• [FAVORITE] (P98) is fixed to [OFF] and
[ROTATE DISP.] (P97) is fixed to [ON].
• If the [SETUP] menu settings are reset,
the following settings are also reset.
See page 22 in manual.
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-FZ18K
This should reset whole camera to factory setting.
Cheers.
Jul 08, 2009 | Panasonic Lumix DMC-FZ18K Digital Camera
How to reset (manually) factory defaults?
Press Setup,Right Arrow,Press Down 3 Times,Then Enter 2 times this should reset factory settings, I Hope This Is Correct As I Realize You Cant See The Menu But I Studied The Manual And Wrote Out The Exact Key Movements To Navigate The Restore Factory Settings menu. Hope This Helps
Sincerely,
Michael Scott
Nov 16, 2008 | Protron PD-DVR100 DVD Recorder
Will not select menu
go to SETUP menu (Page 20 in my instruction book) and set ZOOM RESUME to OFF. Then it will open up at widest setting all the time.
Aug 15, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Casio exilim ex z75 zoom problem?
yes the easiest way to fix this is to go in to setup menu and do a reset on your camera once you reset it the digital zoom should come back make sure digital zoom is turned on.
Aug 04, 2008 | Casio Exilim EX-Z750 Digital Camera
Zoom Function and Verizon Fios TV
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
Apr 30, 2008 | Samsung HP-S5053 Television
Picture mode changes to zoom by itself
It sounds like an eeprom issue. But you can try to reset the set. Turn the set off by the main power on the set. wait a minute or two then together push both the main power button and the standby power button. This should resett the tv. If that doesnt work you will need service as the zoom and the various modes are all controled by the eeprom. Only hold the two buttons for a second. sometimes you will hear the crts discharge while resetting.Hope this helps
Jan 03, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
