Question about Nutrifaster Ruby 2000 Juicer
Nutrifaster N450 hex nut stuck
Hex nut stuck completely stuck and won't come off with the wrench even when hit with hammer. The basket continues to turn. In my opinion this is a very poor design fault as there should be a facility to lock the motor to enable the nut to be freed. Their web site is very poor and gives no support. Their USA numbers do not work in the UK. Oh what to do?
    Problem Solver:
  • 14 Answers
Your unit is a Nutrifaster not a Ruby juicer tray again their website of Nutrifaster in Seattle USA...good luck
Posted on Aug 01, 2013
2 Suggested Answers
SOURCE: how do i sharpen the plate on my commercial nutrifaster N450
The Nutrifaster blades do have to be sharpened every so often. You can send the blade into Nutrifaster and they will sharpen the blade for you. Go to Nutrifaster.com and look under spare parts.
Posted on Oct 16, 2009
Base motor
The Start capacitor in the motor is faulty or the centrifugal switch is worn out info@nutrifaster.com.au
Jul 13, 2013 | Nutrifaster Ruby 2000 Juicer
What is the difference between the Ruby 2000 and Nutrifaster N350? Were they once produced by the same manufacturer?
If both juicers were purchased in Australia the same the brand name changed in 2001 from Nutrifaster the company to The Ruby Juicer
Feb 25, 2013 | Nutrifaster Ruby 2000 Juicer
I am trying to disassemble. I have done it many times, but the basket won't come off the base this time. I have poured hot soapy water through in forward and reverse. Not working
Many times when juicing very fibourous produce the bowl(basket) can get stuck and you can loosen it by gently tapping on the pulp spout or juice spout to the counter clockwise motion(right), this will loosen the bowl.
Aug 07, 2011 | Omega Juicers VRT330
Have just bought a secondhand Ruby and replaced the blades and basket - still having problems with the basket collecting pulp (apples) and becoming noisy - unbalanced I assume. When I clean out the basket...
Hi Kathy, we had the same problem. You need to soak you basket overnight (every day) in a chlorinated solution/detergent. This will keep your filter basket clean. Also, make sure you rinse out your juicer if you know you are not going to use it much for a few hours as the pulp will dry up and clog your filter. Since adopting we started doing this we haven't had any more problems.
Feb 13, 2011 | Nutrifaster Ruby 2000 Juicer
I need a Ruby 2000 manual. How can I get it?
Go to the Nutrifaster Australia website and you will find it
Click on this link: http://nutrifaster.com.au/juicing-bar-equipment/multifruit-juice-extractors/4:1155/
Dec 28, 2010 | Nutrifaster Ruby 2000 Juicer
When I disassemble for cleanup, the basket is very difficult to get out of the bucket part. Any tips?
The basket may have cut into the hex shape top of the spindle creating little grooves which
the basket locks into. If that's the case you have to replace the part, it's called the impeller.
If you can purchase one from Omega, use a needle nose pliers to remove the flat hold down
washer/nut on top of the motor spindle, pull off the old impeller and push on the new. Line
it up correctly it only installs in one position. The impeller is the flat rotating part that the
basket sits on. I did it on my Acme but had to push a little for them to sell me one.
Nov 29, 2010 | Omega 1000 Juice Extractor
Bearing noise
Why don't you contact Nutrifaster as see if they can assist?
Nov 01, 2009 | Nutrifaster Ruby 2000 Juicer
How do i sharpen the plate on my commercial nutrifaster N450
Sep 22, 2009 | Nutrifaster N450 1056 Watts Juicer
Nutrifaster Ruby 2000 Juicer Logo
301 people viewed this question
Top Nutrifaster Juicers Experts
eyecam
David Payne
David Payne
Are you a Nutrifaster Juicer Expert? Answer questions, earn points and help others
