Having trouble with my computer cannot open nero anymore erro box keeps opening
Having trouble with the computer the cpu unit is overheating therefore closing the computer down i have put plenty of thermal grease on this component and it still does not work the motherboard is a asrock p4i65g the fan is working alwright
Posted on Aug 30, 2008
Soundtrax wont open my saved file anymore after windows 10 install. Why?
Many old programs will not work on windows 10 .SORRY that you did not check before doing the conversion
Nov 08, 2016 | MADE Computers & Internet
Tip
Burn a Bin without a CUE using NERO
You've downloaded a *. BIN file, but there was no *.CUE file associated and you still want to burn the *. BIN file using Nero.
Your options are:
1) Create yourself a *.CUE
2) Convert the *.BIN to an *.ISO
3) OR use Nero to burn without the *.CUE file! ! !
Yes, that`s possible...just follow these steps and you will be sorted. No need for *.CUE files anymore
ok, here we go...
1) Start Nero
2) File -> Burn Image
3) Browse to the *. BIN file that you want to burn and open it
4) A window saying "Foreign Image Settings" will open
5) Check the settings. They should be as followed:
* Type of image: leave it to Data Mode 1
* Select the Raw Data check box
Note->> The block size will change automatically from 2048 to 2352
* Leave Image Header and Image Trailer unchanged and set to 0
* Leave "Scrambled" and "Swapped" check boxes unchecked
6) Click on burn!
7) Enjoy
This tut was for Nero 5.x.x.x, I was told that "Burn Image" is under "recorder" in Nero 6.
The rest of the steps should be the same...xkalibur
on Dec 27, 2009 | Computers & Internet
My nero7 is not opening it is showing dialogue box what shall i do
It sounds like that when you are trying to install it that you are not doing so as an administrator on Windows. It's a funny quirk of Windows, that even if you are the only person that uses the computer it requires various sign ins to give you the rights to alter how the computer works.
Click help and support and type "administrator" in the search box.
Jan 07, 2012 | Ahead Software Nero 7 for PC
I have my nero installed but i did not enter the license key yet, how can i enter it?
You have to start Nero Control Center then select 2nd option License and there you have to put your product key and click on add.
iTechGuru
www.itechguru.in
Mar 29, 2010 | Ahead Software Nero Ultra Edition 6
My nero says i need runtime and says it is a error
you need java...umm ffs...let me give you a step by step guide on how to make your computer recognise java ok...
go to www.java.com
and download the jdk version 6 update 17
install it and what not..
then..go to your start menu then put the mouse on computer right click computer and click properties then another box should come up look for advanced system settings this should be on the left hand side clik on that and another box will pop up and on the top of that box there should be tabs..click on the advanced tab and at the bottom it should say environment variables click on that...and click on new then....leave tha box open....and go to your start menu and click on computer then open up your c: drive and open your program files(x86) or something like that and look for java open java and open the folder that says jdk6u17 then open the bin folder and right click any folder there and click properties...highlight the location afer you open the properties and then go back to that place where you were making the new path and paste it into the variable value and name the variable name Path with a capital P then press ok..or whatever...then go to your start menu and search in your search box cmd then press enter...then type in your command prompt javac and press enter...then alot of java binary and languages should come up...then your nero 9 should work...sorry for the essay :)
Mar 16, 2010 | Ahead Software Nero 9 Full Version for PC
Can someone send me what is serial number for nero 6 please or where i can find it
Your serial number ooks like this:
1A2x-xxxx-xxxx-xxxx-xxxx-xxxx
It is basically your "license" to use your game. It is issued by Nero to keep people from using the game illegally.
If you have the box or cd case for the game, check there first. If not, and you have the game installed do the following:
This is the customer service link where you can get help getting your SN:
https://register.nero.com/eng/login.asp customer service
If your copy of Nero is registered you can go to their web site and use their tools.
At Nero, click My Home tab and then the My Serials entry.
Registered Nero serials window opens.
Click the Display link behind the product name of the registered serial number.
Your serial number will be displayed.
If your copy of nero has not been uninstalled:
1. Launch Nero StartSmart.
2. To do that, double-click the icon "Nero StartSmart" on your desktop. If you do not have a shortcut to
Nero StartSmart on your desktop, open Nero StartSmart as follows: Click "Start" Programs"-"Nero
6"-"Nero StartSmart".
3. Nero StartSmart will open. Click the "Nero" logo in the upper left corner of the Nero StartSmart window.
4. The Nero ProductCenter will open. Click the "serial number” tab to see your serial number.
5. Your serial number is displayed in the window on the right. write down your serial.
If that doesn't work, try your registry: Sometimes this works even when it has been uninstalled.
1. Click "Start" in the Windows start menu.
2. Click the "Run" command.
3. The window "Run" will open. Enter "regedit" in the "Open" text field and click the "OK" button.
4. The registry window will open. You will find your serial number on the left side in the navigation tree.
Go to the path: HKEY_LOCAL_MACHINE\Software\ahead\Nero - Burning Rom_Info
and double-click the "Serial" entry.
5. Your serial number is listed in this location. It looks like this:
You can help me give better answers by letting me know if this was helpful or not. If you have a minute, please rate the solution so others that have your same problem will get the best answers. Thank you.
Dec 23, 2009 | Ahead Software Nero Express 6.0 (NERO6OEM)...
What the serianl number for nero6
should be listed on the box or cd label. If you downloaded it the place you downloaded nero would give you the seriel number.
Dec 20, 2009 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Nero Photosnap Viewer Suddenly stopped working.
Let's say you cannot open JPG pics. This is what you have to do. 1) In explorer (My Computer), click Tools > Folder Options. 2) In the dialog box, click 'File Types' tab. 3) Scroll down until you see the JPG extension. 4) Select it and click 'Change' button below. 5) Select a program you want to use to open JPG files. (Windows Picture and Fax Viewer is the default program: You can select it.) 6) Click OK button. 7) If you have trouble opening other graphic types (BMP, GIF, PNG etc.) look for those extensions and repeat steps 4 to 6. 8) Click 'OK' button to close Folder Options dialog.
Jul 21, 2009 | Computers & Internet
My nero 7 is not working properly.Pl repair on line the net is open.
It show that tere is a erro file somwhere that will not let me open nero
May 13, 2009 | Ahead Software Nero 7 Essentials Suite...
Computers & Internet Logo
David Payne
David Payne
