Bright colors cause tv to buzz - Televison & Video
  • cjh10520 Sep 04, 2008
    Thank-you, I had a feeling, but I just wanted confirmation.
  • 2,920 Answers
Color tubes are starting to go bad
Posted on Aug 30, 2008
  • Ronnie Houston Sep 04, 2008
    u are more than welcome
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
The TV just started making a loud buzzing noise last week, the buzzing sounds begins after the TV has been turned on for 15 or so minutes- the sound stops about 15 seconds after the TV is turned off. The...
This tv have a colors wheel. The tv colors wheel is dead.The buzzing noise is the cause of the colors wheel is spinning of is axis and rubbing sides of the motor.Hire a tv tech. for the job.Colors wheel is hard to replaced,because have to take out many other machanical parts,even before can change the colors wheel it self.
Aug 31, 2010 | Samsung HL-P6163W 61" TV
Samsung HL-P4663W/HL is making a buzzing noise
Color wheel needs replacement is the most likeliest cause.
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
My TV is buzzing nonstop. What will fix this??
is it buzzing when turned off or just on and is it buzzing durning bright scenes or just buzzing bright scene change buz is an If problem . in todays set , the best thing to do is change out the signal board sometimes
it could be a transfomer laminate buzz in the case your best bet would be to hire a tv tech to take a listen
Nov 20, 2009 | Akai PTH5498 54" Rear Projection...
Magnavox PTV910 projection TV has blurred blue gun. The coolant in looks ok as far as I can tell from looking with a flashlight or with the TV on. There is also a buzz in the audio which I suspect to be a...
I don't know about the buzz but when you need to replace the coolant it isn't the coolant that actually gets blurry, it is algae that grows over the crt. It kinda looks like snow if you look in there, maybe a tannish color on the blue tube. Usually only grows on green and blue tubes as plants don't grow under red light. Lots of directions available to replace the coolant but my recommendation would be to tip the tv over backwards, pull the plastic focusing assembly clean off catching the old coolant in a cake pan. Be sure not to let any leak on boards as it is conductive. Once those are off you will be able to wipe the CRTs off with a soft cloth. Pretty easy to fill them back up with a small funnel.
If you don't see any algae in there, there are six color coded dials that adjust focus electrically and brightness.
Apr 19, 2009 | Televison & Video
Hitachi c2114t loud buzz on bright screen
sounds like you have a gun or picture tube shorting. check the bottom of the tubes when you turn it on and see it one of them is lit up more then the other two if you find that then unplug the circut board thats pluged into the tube and turn on the tv again and see if you problem goes away minus that color.
Feb 23, 2008 | Televison & Video
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
Jan 27, 2008 | Toshiba 56HM195 56" Projection HDTV
Loud Buzzing Noise
Check filtr capacitor in power unit.
Check filter capacitor on supply to audio amp ic. or Amp ic itself is defective.
Apr 23, 2007 | JVC AV-30W475 30" TV
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
