Question about Singer 3116 Simple
Loose bobbin case in singer 9018
The bobbin case feels quite secure when I have positioned and locked it in place following instruction manual but as soon as I try to sew it comes loose again.
  • ggamuir Sep 06, 2008
    I took the machine to my local singer shop. I have damaged the bobbin case and upset the timing by trying to sew material which was too thick. Thanks for your help. ggamuir
  • yongspirit Jan 19, 2009
    can you send me the timing instructions for singer 9018 i really apreciate it
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
  • 323 Answers
SOURCE: singer 3820 How I replace
remove the 2 screws in the needle plate. Lift off the plate.Take out the bobbin case and examine it for rough spots or nicks. If there are any it will be necessary to buff them with an emery stick or fine sandpaper. Once the rough spot has has been smoothed, buff it with some very fine steel wool. There must be no rough spots on this bobbin case.Clean all the lint from inside the hook area. Do not pull the wick from the center of the hook. Place the bobbin case in the hook area so that it sits flush and does not bind when the handwheel is turned.Reinstall the needle plate, thread the machine, insert the bobbin and turn the wheel to pick up the bobbin thread and see that it doesn't bind.Test sew
Posted on Jun 12, 2008
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
  • 110 Answers
SOURCE: singer solid state-bobbin part
Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine. Also use a ball-point needle on t shirt material. Good luck!
Posted on Nov 03, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
I have a singer 600E. When I put the bobbin case back in place and returned the black metal position piece to the left. Now it will not hold bobbin case in place. Please help.
Please download the user's manual for your machine free at the Singer site, under support. On page 50, it shows you how to remove and replace the bobbin case. I have a feeling that it's not quite in place, and that's easy to do. Ask me how I know.
Mar 16, 2017 | Singer Sewing Machines
How to thread the bobbin of a singer 90s
First make sure that the needle is fully up (use the hand-wheel). Move the bobbin cover release button to the right and lift the bobbin cover out of the way. Remove the current bobbin, if needed. Hold the new, full bobbin so that the thread comes off the bobbin counter-clockwise when you pull the thread. Place the bobbin into the bobbin case. Pull the thread through the slot near the bottom of the case and to the left. Place a finger on top of the bobbin. Next bring the thread left further towards the back of the bobbin case until it stops in the second slot (near the 8 o'clock position if you compare the position to a 12-hour analog clock). Pull the thread back through the groove in the cover plate until it is cut by the thread cutter at the top left of the cover plate. (The thread will turn a "corner" to the cutter.) Replace the bobbin cover.
Singer has the manual for most of their sewing machines here: . The direct link to the manual for the 90S is . See pages 16-17 (page 18 in the PDF for the English description) and pictures that may be better than the verbal description.
I hope this helps.
Dec 23, 2016 | Singer Sewing Machines
I have a 2013 Singer one plus that I bought less than a year ago. My bobbin case keeps locking up. After I take plate off & take out bobbin case then put back in correct position & sta
Could be that your bobbin thread is wound too tightly and having a problem pulling thread from it. Try setting the pressure on bobbin a bit less and that may cure it.
Sep 30, 2014 | Singer One Plus Computerized Sewing...
The bobbin case on my t&s 758 keeps slipping. HELP! :)
make sure when you put the bobbin case in that the needle is all the way up. If it is down and in the way of the bobbing case, the case won't lock in place securely.
Aug 30, 2017 | Singer Sewing Machines
I have a Singer model 4562 T sewing machine, and threading the bobbin, the bobbin case just kind of popped out. I've tried just sliding it back in, but no matter which way I put it in it doesn't seem to...
The bobbin case is designed to be removed for cleaning. Take off the needle plate if it is still on the sewing machine. Make sure that the needle and presser foot are fully up. Guide the forked end of the bobbin case under the feed (more or less centered). Then pull the bobbin case under the rim of the position plate. Pull on the side opposite the forked end of the bobbin case. With a small screw driver, turn the lever (at about 10 o'clock on a 12-hour analog clock) towards you. This will lock the bobbin case into place. Make sure that the bobbin case isn't locked too tightly. It still needs to move slightly as the bobbin turns and the needle comes through that plate.
Replace the needle plate and lock it down. Then insert the bobbin and close the slide plate. The manual shows the procedure to remove and replace the bobbin case on the 4562 on page 39. Singer has the manual on the support page: . The direct link to the manual is .
I hope this helps.
(I hope that the locking lever hasn't broken. That may require a service person to solve the problem. I'm not entirely sure where that lever is connected to the machine. Some Singer part diagrams are here: . The 4562 may use the same diagram as the 4572, .)
Jul 01, 2017 | Singer Sewing Machines
Seat the bobbin & adjust tension on Singer 9018
basic tension instructions apply...bottom tension should be moderate, thread should pass when holding thread and dangle the case. Top tension should pull bottom thread JUST to the top side of fabric. thread bobbin case counter clockwise.
May 31, 2010 | Singer 3116 Simple
Can't get the bobbin case back in on my singer hd 110. It came out on it's own. The manual is not very helpful.
If this is a vertical/metal bobbin case; raise the needle to it's highest position. This will position the shuttle to accept the bobbin case.
If the bobbin case has a lever on the back, lift it and hold it open as you place the bobbin case back into the shuttle. It should click into place.
Mar 14, 2010 | Singer HD-110 Mechanical Sewing Machine
I have a Singer mod 9134 sewing machine. It keeps
Try inserting the bobbin in the reverse direction. Most machines take a bobbin clockwise or counterclockwise and it can make a difference. Also try a new needle, a bad needle is often the problem believe it or not.
Nov 10, 2009 | Sewing Machines
Singer 3116 Simple Logo
571 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
