I have a motherboard p4i65g and the system shuts down when the CPU overheats i have allready put thermal grease on all components the fan is working properly
    Scholar:
  • 152 Answers
Add more fan to your system. You can install this at the back of your CPU separately.
Posted on Aug 31, 2008
My computer keeps shutting down after a few minutes. I have replaced the powersupply as well as the cpu fan. I am being told now that it is the system/motherboard. Is that an accurate answer?
When the CPUoverheats it goes into thermal shutdown and will not boot up again until theCPU has cooled down.
The heat sink may be clogged with dust, which causes the CPU to overheat byreducing air circulation through the heat sink.When you replaced the CPU fan, did you put new thermal heatsink paste on the CPU/heatsink? If not then the CPU can overhest. Your computer fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.
Mar 21, 2012 | Computers & Internet
Shut down after 5 - 10 min.
the most likely case is CPU-OVERHEAT EMERGENCY POWEROFF command executed by motherboard in this case apply new thermoaste on cpu, and clean fan/replace on bigger if doesn't help/cpu is overclocked
Sep 22, 2009 | VIA ASRock K7VM3 Socket A/...
Pc shuts down ,reason cpu overheating
It seems to me that your pc is facing hardware problem.It is suggested that you contact local computer service to replace the faulty hardware..
Jul 25, 2009 | Computers & Internet
Same problem overheat and shut down 3611au
make sure your CPU is being properly cooled. and has thermal grease between the cooling fan's heatsink and the CPU. Also check any other onboard fans to make sure they are dust free / running properly. if the fan is not running quietly and smoothly, you will need to replace it.
Once replaced, if you still get thermal shut down, you may need to check with your manufacturer to determine if there is a faulty thermal probe on the board
Jun 21, 2009 | HP Compaq Motherboard
Pentium D problem
Hi oilian,
Be glad it did shut down. If it didn't, your new CPU could haveover heated. There are a few reasons for a CPU to over heat.
1.) There is no thermal grease or too little on the heat-sink assembly.
2.) The old thermal grease was not removed or the old thermal tape was not removed.
3.) The heat-sink assembly was not cleaned completely with alcohol before applying new thermal grease.
4.) The CPU fan is running too slowly.
5.) The heat-sink fins are possibly filled with dust build-up & the CPU fan can not cool the heat-sink assembly. Boot to the bios & go to Hardware Monitor. There you can check voltage, CPU fan speed, CPU temp & other bios monitored settings.
Good luck oilian!
Mike
Oct 01, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
Having trouble with my computer cannot open nero anymore erro box keeps opening
having trouble with the computer the cpu unit is overheating therefore closing the computer down i have put plenty of thermal grease on this component and it still does not work the motherboard is a asrock p4i65g the fan is working alwright
Aug 30, 2008 | Computers & Internet
CPU fan stops, computer shuts down
You must have the CPU fan plugged into the CPU fan power connector or the system can not monitor the fans speed. Your PC will shut down & give you that message. (The fan must be connected to the correct power plug).
If when you did replace the CPU's fan & had to remove the heat sink, which is where the fan screws into & did not clean the old thermal grease off the CPU & heatsink & replace with new thermal grease than your CPU will still overheat. If you add thermal grease over top of old thermal grease your CPU will over heat.
This is all a balancing act. If any one is not correct your system will shut down. (This is better than killing the CPU).
To remove old thermal grease use a clean cloth damped with house hold alcohol & use the same on the bottom of the heatsink. Please allow plenty of time for the alcohol to dry.
Good Luck! Take your time.
Mike
Mar 30, 2008 | HP (P2074-63003) Motherboard
Powering up problem
there is heating problem
remove cpu fan and put on cpu heat sink compound and
refitting cpu fan
Feb 28, 2008 | Computers & Internet
Mesh Matrix 64 start up problem
First there is an on off switch on the back of your power supply. Switch that off. Take out the memory chips, then re-insert them. Turn power switch back on. With the case still open. Power it up. If it comes on. Look to see if the cpu fan is still running. If it is not turning replace the fan. If it runs you may have other problems, possibly a power supply, CPU overheating, and or switch problems. Now in other cases high end video adapters tend to overheat and causes system freeze ups and causes possible shut downs. I would still have it checked out professionally if the problem persists. Hope this helps
Sep 16, 2007 | Computers & Internet
ASUS NCT-d
Hi, have you tried removing the CPU and using a Air Jet Spray can to clean all contact pins and pin holes? The problem sounds like a loose chip. So also check all on board chips are seated, including RAM chips. Air spray can be bought from most Computer stores. Goodluck mistyman
Sep 09, 2007 | ASUS NCT-D (90MSV430G0UAY) Motherboard
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
