Question about Toshiba P25-S670 Notebook
Power button issue
I am realizing my power button has a week connection, how can I fix it?
    Brigadier General:
  • 6,966 Answers
Often power buttons are the first among the so many buttons to fail. This is due to its constant usage compared to the others. In most instances, the fault could be a dirty/corroded contacts. What could be done is to remove the panel/cover of the laptop to expose the power button. Thereafter a careful spray of electronic contact cleaner should be enough to clean the contacts. if your particular switch is covered with a plastic/membrane, it may be necessary to find the edge of the said membrane to lift it off and spray thereafter. As added precaution, you may want to cover the LCD display panel and the keyboard (and other portions) with a paper towel or cloth to prevent the contact cleaner spray reaching them.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 30, 2008
Aiwa HS-PX303 HS-PX30 in Japan cassette walkman, powers on and starts running the moment that power is applied. Won't listen to the stop button.
This is a reach, but is the button pusher , the plastic piece that pushes the tact switch worn down and not actuating the switch? Have you tried a ceramic driver with the case open and actuating the physical switch instead of the button on the case to verify.
My razer mouse had the same issue , it took me a week poking around to realize the button pusher was worn. Super glued a piece of rubber to the worn pusher and its working fine to this day
Feb 13, 2018 | Aiwa Televison & Video
Daytek TV reset code
If nothing else works, connect your TV to a receiver ir an XBOX One or even a ROKU 3 device. Each of these will power on your tv set automatically when you power on the device.
Mar 24, 2014 | Televison & Video
2006 Cadillac cts is burning gas faster than the normal rate after i got an oil change at jiffy lube 2 weeks ago
I dont think there is a connection between an oil change and the gallons per mile.
With that age car, I suggest a Terra engine clean. It will blow away nine years of gunk from the spark plugs, fuel injectors, cylinders and exhaust. Should give you more power, more miles..
Mar 18, 2014 | Cadillac CTS Cars & Trucks
I have a gateway that has been having a dc jack issue. It started to not charge when the it was plugged in, I went through several power cords just to make sure there was nothing wrong with the power...
I have been living with this problem for 5 months now.
The first thing I suggest is to plucg in your laptop then pull the cord under your laptop tug it towards you if you are able to obtain a connection use your laptop to hold the cord. Thats what I am doing now
If that does not work find the spot where you can connect ( by tugging cord back and forth or up and down) and hold the connection with tape or a clamp.
Oct 18, 2009 | Gateway MX6440 Notebook
Low or no power even with new batteries
when you dropped it, it may have nocked something loose.
Apr 11, 2009 | Canon PowerShot A560 Digital Camera
PS2 Slim - Power Issue
It could be the power cord, but it could also be the connection where the cable connects to the system. The cheapest fix would be to try a new power cord. If it's the slim PS2 then it's only about a $15 fix. If it's the large older PS2, then it's more like a $5 fix for a cord.
blingbdog, do you have the slim or the old large system? Also, let me know if the warranty is still valid (have you had the console for more than 1 year).
Sep 14, 2008 | Sony PlayStation 2 Slimline Console
Verifone Trans 330 says "Printing" after the transaction but printer does not print.
First off, verify that the printer is powered on. This may be a basic thing, but many, many people don't realize that the printer either was turned off accidentally, or the power plug came loose.
Check that the cable connecting the terminal to the printer is securely connected at both ends. If this doesn't resolve the issue, pull the and check the ends of the plug on the cord at each end to make sure that the pins inside are not bent.
If you are running a Verifone printer, you can run a print test to make sure the printer is working by turning the printer's power off, and then while pressing and holding the paper feed button (green button on top) turning the power back on. The printer will start printing test characters (you can release the button when it starts printing). To stop the test, just power the printer off again and then back on.
If the above suggestions don't fix the problem and it was working fine at an earlier date - you most likely have a bad printer. You can also contact your processor's Help Desk and have them check to make sure the settings on the terminal and/or printer didn't changed somehow.
Hope that helped!
Sep 12, 2008 | Citizen IDP562-RSL2-120 Matrix Printer
Resource Conflict - PCI Network Controller in Slot 02
check for an update of bios on acer.com it will fix your laptop problem....
Apr 24, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Dishwasher stopped working
You have a board problem it came from a power surge.
Nov 11, 2007 | Maytag 24 in. MDB5600A Jetclean II...
My TV will not come on but the power button blinks red!
Very interesting. I have a Toshiba 53 H71. Same issue. It occurred to me after a move.. No one has offered any help on it. Posted about a week ago. Guess no one knows anything about these TV's....
Sep 02, 2006 | Toshiba 50HX81 50" Rear Projection...
Toshiba P25-S670 Notebook Logo
90 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
