Question about iRiver X20 MP3 Player
Iriver X20 switches off when using FM Recorder
My IRiver X20 turns off when using the FM recorder. There is plenty of memory space and the battery is charrged. The annoying thing is that sometimes it works fine. The recording is lost when the X20 switches off. Any ideas ? Thanks
  • 49 Answers
There may be a problem with the menu files...
Posted on Nov 06, 2008
IRiver X20 not reading SD card
yes this is correct, you can only have the same size memory card as what your iriver was originally. eg when I bought mine it was a 2GB so there for I could only add a 2GB memory card in it giving me a total of 4GB. if you buy a SD card of the same GB you wont have a problem
Nov 15, 2008 | iRiver X20 MP3 Player
External memory - sd card recognition on pc??
if it doesn't even appear on windows explorer either the sd card, usb link or iriver is defective. if all else fails try getting a memory card reader. this allows you to store files on the card through the computer and still be able to insert the card as external storage on the iriver x20. the only trouble with that is that its hard to get the card in and out of the iriver
Nov 02, 2008 | iRiver X20 MP3 Player
Iriver X20 database full
does the message stop you from using the iriver?
if it doesn't then there's a format function on the iriver in the settings menu...
if it does then there may be a problem with the usb connection...
either the iriver isnt responding or the computer can't read it!
for the user below there is most likely a format will fix it...
Aug 01, 2008 | iRiver X20 MP3 Player
Folders inside my IRIVER X20 no longer recognised!! HELP PLEASE!!!
Try making a new folder, under the same name as the ones lost, or missing. Since the X20 is flash memory based, you may have had some of your data go randomly corrupt. You MAY have to start things over. Sorry! Good Luck!
Apr 10, 2008 | iRiver X20 MP3 Player
Iriver x20
try and view hidden files...
it depends wat the folder is...
it might be a system folder, in which case you'd be better to just ignore it
Apr 05, 2008 | iRiver X20 MP3 Player
IRiver X20 Docking station
IRiver does not make a proprietary dock for this player; other manufacturers do not make them for IRiver because iRiver is a small player. You can take your IRiver into a Best Buy or other shop and test it in another company's dock, but it is not guaranteed to work. This is the only truthful answer I can give you.
Mar 17, 2008 | iRiver X20 MP3 Player
Transferring recordings from iRiver x20 to PC
Yes, it should work if you connect to the pc then click on my computer> iriver> then find the recordings and copy and paste them to a folder on your computer.
Jan 05, 2008 | iRiver X20 MP3 Player
Downloading movie length DVD to iriver x20
Yes, you need to convert all your movies to a format iRiver and understand and play.
Here's a link:
Movie Converter for iRiver and instructions
I'm not sure whether Movie Converter supports original DVD files. If that is not the case, then you'll have to convert DVD video into a format that iRiver X20 can use, and then feed that new video to Movie Converter.
However, that would be a bit redundant: to save on time and quality, you could use other video Conversion tools, such as SUPER:
http://www.erightsoft.com/SUPER.html
After loading your DVD, you set the parameters to mirror those accepted by your iRiver model. In case of iRiver X20, those parameters are:
Extension: AVI [[also known as container]]
Video Codec: WMV9 SP, MPEG-4 SP [[MPEG-4 = XVID, DIVX]]
Video Resolution: max 320 × 240
Video Framerate: max 30 fps
Video Bit Rate: max 512 kbps
After successful conversion, upload your new video file to your iRiver X20 and play it back. If it plays [and plays correctly] - then congratulations - it works! If it does not play, then you might have made a mistake while setting the output parameters in SUPER.
Hope it helps. Rate me. Thanks.
.:: Cyberneticus ::.
How do I delete voice recordings from my x20?
plug into pc and delete files via pc
that worked for me
Oct 25, 2007 | iRiver X20 MP3 Player
Frozen iriver x20
If your player freezes on "Building Library" (usually a result of putting certain type of .m3u playlists or too big images in id3 tag):
1. Turn the player off - you may need to take the battery out to do this.
2. Hold the menu button in.
3. Still holding the menu button in, press the power button.
4. Keep holding both buttons in until you get a dialogue asking if you want to format internal memory ... say yes.
5. Your internal memory will be formatted and you will now be able to start your X20.
Try to figure out what file is causing X20 to freeze - i've found that pretty much any .m3u file will make it freeze on building library ... only about 2-3 out of about 100 i've tried have worked.
Oct 20, 2007 | iRiver X20 MP3 Player
iRiver X20 MP3 Player Logo
81 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
